/* 開(kāi)關(guān)的作用:P02 -----計(jì)價(jià)器啟動(dòng)開(kāi)關(guān) (K3=0 跑馬 ;K3=1 計(jì)價(jià)器清0)
P03 -----汽車啟動(dòng)計(jì)價(jià)開(kāi)關(guān) (K4=0 計(jì)價(jià)器開(kāi)實(shí)時(shí)計(jì)價(jià);K4=1顯示總價(jià)和總時(shí)間)
P04 -----清0鍵 (K5=0 回到跑馬;K5=1 全部清0 )
程序的功能:車子在啟動(dòng)前顯示P型跑馬,汽車啟動(dòng)后顯示價(jià)格0,按下開(kāi)關(guān)K4開(kāi)始實(shí)
時(shí)計(jì)價(jià),前兩位顯示時(shí)間,后四位顯示價(jià)格;2秒以內(nèi)按3元計(jì)價(jià),以后
每增加2秒,價(jià)格增加0.7,當(dāng)超過(guò)6秒時(shí),按每增加1秒價(jià)格增加1元,以
“元”作為計(jì)價(jià)單位,以小數(shù)點(diǎn)隔開(kāi)元和角。按下中斷鍵時(shí)示顯故障提示
“STOP"且響鈴,再次按中斷鍵時(shí),故障排除,恢復(fù)程序正常的工作。
#include<reg51.h>
#include<intrins.h>
sbit P02=P0^2; //啟動(dòng)開(kāi)關(guān)
sbit P03=P0^3; //顯示最終價(jià)格
sbit P04=P0^4;
sbit P32=P3^2;
sbit P37=P3^7; //清零開(kāi)關(guān)
uchar code
table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //0~9不帶小數(shù)點(diǎn)
uchar codetable2[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};//0~9
帶小數(shù)點(diǎn)
void delay(uint z);
uchar a,fen,miao,shu; //定義時(shí)間參數(shù)
uchar a=0;
unsigned char temp;
int m,i; //m表示價(jià)錢
uint temp1,temp2;
timer1() interrupt 0 //外部中斷,顯示STOP
P37=0;
P1=0x01;
P2=0x6d;
delay(5);
P1=0x02;
P2=0x31;
delay(5);
P1=0x04;
P2=0x3f;
delay(5);
P1=0x08;
P2=0x73;
delay(5);
P37=~P37; //響鈴
void main() //主程序
{uchar k;uint i;
TMOD=0x01;
TH0=(65536-50000)/256; //定時(shí)50MS
TL0=(65536-50000)%256;
EA=1; //開(kāi)中斷總控開(kāi)關(guān)
IT0=0; //INT0零電平觸發(fā)
EX0=1; //開(kāi)INT0中斷
TR0=1; //T0開(kāi)始計(jì)時(shí)
ET0=1; //開(kāi)T0中斷
ag: { TR0=0;
if(P02==0) //啟動(dòng)跑馬開(kāi)關(guān),開(kāi)始跑馬
{ P1=0x01;
P2=0x73;
for(k=0;k<6;k++)
for(i=0;i<20000;i++);
P1<<=1; //跑馬程序
if(P02==1) //車子啟動(dòng),全部歸零,準(zhǔn)備計(jì)時(shí)計(jì)價(jià)
P2=0x3f;
P1=0xff;
delay(2);
P1=0x00;
delay(2);
} //設(shè)置T0定時(shí)器
/*if(P02==0) //啟動(dòng)跑馬開(kāi)關(guān)
{ P1=0x01;
P2=0x73;
for(k=0;k<6;k++)
P1<<=1; //跑馬程序
if(P02==1)
P1=0xff;
P2=0x3f;
delay(2);
P1=0x00;
delay(2);
if(P03==1) //啟動(dòng)計(jì)時(shí)計(jì)價(jià)
{TR0=1;
temp1=shu;temp2=m;
P1=0x01;
P2=table[shu/10];
delay(2);//延時(shí)5毫秒
P1=0x00;
delay(2); //顯示時(shí)間
P1=0x02;
P2=table[shu%10];
P1=0x00;
P1=0x04;
P2=0X3f;
delay(2);
P1=0x00;
delay(2); //顯示價(jià)格(百位)
if(0<shu<=2)
m=30;
else if(shu==3)
m=30;
if(shu==4)
m=37;
if(shu==5)
m=37;
if(shu==6)
m=44;
if(shu>6)
m=10*shu-16; //價(jià)格計(jì)算程序
P2=table[m/100];
P1=0x08;
//P2=table[m/100];
delay(2);
P1=0x00;
delay(2); //顯示價(jià)格(十位)
P2=table2[(m%100)/10];
P1=0x10;
//P2=table2[(m%100)/10];
delay(2);
P1=0x00;
delay(2); //顯示價(jià)格(個(gè)位)
P2=table[m%10];
P1=0x20;
//P2=table[m%10];
delay(2);
P1=0x00;
delay(2); //顯示價(jià)格(角位)
if(P04==1)
m=0;shu=0;temp1=0;temp2=0;
P1=0xff;
P2=0x3f; //清零程序
while(P03==0) // 顯示最終價(jià)格和時(shí)間
P2=table[temp1/10];
P1=0x01;
//P2=table[temp1/10];
delay(1);
P1=0x00;
delay(1);
P2=table[temp1%10];
P1=0x02;
//P2=table[temp1%10];
delay(1);
P1=0x00;
delay(1);
P1=0x04;
P2=0X3f;
delay(1);
P1=0x00;
delay(1);
P2=table[temp2/100];
P1=0x08;
//P2=table[temp2/100];
delay(1);
P1=0x00;
delay(1);
P2=table2[(temp2%100)/10];
P1=0x10;
//P2=table2[(temp2%100)/10];
delay(1);
P1=0x00;
delay(1);
P2=table[temp2%10];
P1=0x20;
//P2=table[temp2%10];
delay(1);
P1=0x00;
delay(1);
if(P04==1)
/*m=0;shu=0;temp1=0;temp2=0; */
P1=0xff;
P2=0x3f;
for(i=0;i<2000;i++);
goto ag; //清零時(shí),所有開(kāi)關(guān)全零
/*if(P04==1)
{ for(i=0;i<200;i++);
P1=0xff;
P2=0x3f;
goto ag;
void timer0() interrupt1 //設(shè)置定時(shí)器初值
TL0=(65536-50000)%256; //0.05s溢出
a++;
if(a==20)
a=0;
shu++;
if(shu==99)
shu=0;
void delay(uint z) //延遲函數(shù)
uint x,y;
for(x=z;x>0;x--)
for(y=80;y>0;y--);
