2019-12-31 11:55 上傳
- #include<reg51.h>
- sbit DIN=P3^0;//??max7219??????
- sbit LOAD=P3^1;
- sbit CLK=P3^2;
- sbit S1=P3^6;
- sbit key0=P1^0;//8·??????????
- sbit key1=P1^1;
- sbit key2=P1^2;
- sbit key3=P1^3;
- sbit key4=P1^4;
- sbit key5=P1^5;
- sbit key6=P1^6;
- sbit key7=P1^7;
- sbit zhi=P3^6;//????
- sbit key_clear=P2^0;//????????????á????
- sbit begin=P2^1;//????????????
- sbit sounder=P3^7;//??????
- unsigned char second=30;//???????
- unsigned char counter=0;//counter?100??minite??1
- unsigned char people=0;//??????
- unsigned char num_add[]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08};//max7219??д?????????
- unsigned char num_dat[]={0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89};
- unsigned char keyscan()//??????軀??
- unsigned char keyvalue,temp;
- keyvalue=0;
- P1=0xff;
- temp=P1;
- if(~(P1&temp))
- switch(temp)
- case 0xfe:
- keyvalue=1;zhi=0;
- break;
- case 0xfd:
- keyvalue=2;zhi=0;
- break;
- case 0xfb:
- keyvalue=3;zhi=0;
- break;
- case 0xf7:
- keyvalue=4;zhi=0;
- break;
- case 0xef:
- keyvalue=5;zhi=0;
- break;
- case 0xdf:
- keyvalue=6;zhi=0;
- break;
- case 0xbf:
- keyvalue=7;zhi=0;
- break;
- case 0x7f:
- keyvalue=8;zhi=0;
- break;
- default:
- keyvalue=0;zhi=0;
- break;
- return keyvalue;
- void max7219_send(unsigned char add,unsigned char dat)//??max7219д?????
- unsigned char ADS,i,j;
- LOAD=0;
- i=0;
- while(i<16)
- if(i<8)
- ADS=add;
- else
- ADS=dat;
- for(j=8;j>=1;j--)
- DIN=ADS&0x80;
- ADS=ADS<<1;
- CLK=1;
- CLK=0;
- i=i+8;
- LOAD=1;
- void max7219_init()//max7219?????????
- max7219_send(0x0c,0x01);
- max7219_send(0x0b,0x07);
- max7219_send(0x0a,0xf5);
- max7219_send(0x09,0xff);
- void time_display(unsigned char x)//??????
- unsigned char i,j;
- i=x/10;
- j=x%10;
- max7219_send(num_add[1],num_dat[j]);
- max7219_send(num_add[0],num_dat[i]);
- void scare_display(unsigned char x)//?????????
- i=x/10;
- j=x%10;
- max7219_send(num_add[3],num_dat[j]);
- max7219_send(num_add[2],num_dat[i]);
- void holderscan()//????????????0-60s
- time_display(second);
- scare_display(people);
- if(~key_clear)//????м????£???????????
- while(~key_clear);
- if(people)//??????????????????????????
- second=30;
- people=0;
- if(second<60)
- second++;
- else
- second=0;
- void timer_init()
- { S1=0;
- EA=1;
- ET0=1;
- TMOD=0x01;
- TH0=0xd8;//?趨10ms?ж????
- TL0=0xef;
- void main()
- while(1)
- do{
- holderscan();
- }while(begin);//????????????,??δ????????
- while(~begin);//????
- max7219_init(); //о??????
- timer_init(); //?ж?????
- TR0=1;//????ж?
- S1=1;
- do{
- people=keyscan();
- }while((!people)&&(second));//????????????????????????
- TR0=0;}
- void timer0() interrupt 1
- if(counter<100)
- counter++;
- if(counter==50)
- sounder=0;
- else
- sounder=1;
- counter=0;
- second=second-1;
- TH0=0xd8;//???????
- TL0=0xef;
- TR0=1;
