查看: 1609|回復: 0
數碼管顯示1~999
ID:625141 發表于 2019-12-29 17:35 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar num,disnum;
uchar code table_du[]={
0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,
                        0xf8,0x80,0x90};
void display(uint);
void delay(uchar);
        EA=1;
        ET0=1;
        TMOD=0X01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TR0=1;
                if(num==20)
                        num=0;
                        if(disnum==1000)
                        disnum=0;
                        disnum++;
                display(disnum);
void time0() interrupt 1
        num++;
void display(uint disnum)
        P0=table_du[disnum/1000];
        dula=1;
        dula=0;
        P2=0xfe;
        wela=1;
        wela=0;
        delay(10);
        P0=table_du[disnum/100];
        dula=1;
        dula=0;
        P2=0xfd;
        wela=1;
        wela=0;
        delay(10);
        P0=table_du[disnum%100/10];
        dula=1;
        dula=0;
        P2=0xfb;
        wela=1;
        wela=0;
        delay(10);
        P0=table_du[disnum%100%10];
        dula=1;
        dula=0;
        P2=0xf7;
        wela=1;
        wela=0;
        delay(10);
void delay(uchar x)
        uchar a,b;
        for(a=x;a>0;a--)
                for(b=200;b>0;b--);
