查看: 2339|回復: 4
為什么我單片機一上電幾個按鍵功能同時導通且不能關閉
ID:667709 發表于 2019-12-26 23:19 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#include"i2c.h"
#include"ds1302.h"
//--定義使用的IO口--//
//數碼管IO
#define GPIO_DIG        P0
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
typedef unsigned char u8;
typedef unsigned int u16;
//按鍵IO
sbit LED1=P2^0;
sbit LED2=P2^1;
sbit LED3=P2^5;
sbit K6=P3^5;
sbit K1=P3^0;
sbit K2=P3^1;
sbit K3=P3^2;
sbit K4=P3^3;
sbit K5=P3^4;
sbit K7=P3^6;
sbit beep=P2^6;
//--定義全局變量--//
unsigned char code GPIO_DIG_CODE[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
//0、1、2、3、4、5、6、7、8、9、A、b、C、d、E、F的顯示碼
unsigned char Num=0;
unsigned int DisplayData[8] = {0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f};
unsigned char KEYNUMA=0;
unsigned char KEYNUM=0;
unsigned char KEYNUM1=0;
//--聲明全局函數--//
void At24c02Write(unsigned char ,unsigned char );
unsigned char At24c02Read(unsigned char );
void Delay10ms(unsigned int c);   //誤差 0us
void Timer0Configuration();
void delay(u16 i);
* 函 數 名         : main
* 函數功能                   : 主函數
* 輸    入         : 無
* 輸    出         : 無
        unsigned int num0 = 0,num1 = 0,n;
        Ds1302Init();
* K1-K4         功能
* K1,K2         模擬
* K3     存
* K4     讀
                        if(K1 == 0)                 //按鍵1按下
                        Delay10ms(1);
                        if(K1 == 0)
                                num0=01;
                        while((n < 50)&&(K1 == 0))
                                n++;
                                Delay10ms(1);
                        n=0;
                        if(num0==256)
                                num0=0;
                        if(K2 == 0)                 //按鍵2按下
                        Delay10ms(1);
                        if(K2 == 0)
                                num0=02;
                        while((n < 50)&&(K2 == 0))
                                n++;
                                Delay10ms(1);
                        n=0;
                        if(num0==256)
                                num0=0;
                if(K3 == 0)                 //按鍵3按下
                        Delay10ms(1);
                        if(K3 == 0)
                                At24c02Write(2,num0);
                        while((n < 50)&&(K3==0))
                                n++;
                                Delay10ms(1);
                        n=0;
                if(K4 == 0)                 //按鍵4按下
                        Delay10ms(1);
                        if(K4 == 0)
                                num1 = At24c02Read(2);
                        while((n < 50)&&(K4 == 0))
                                n++;
                                Delay10ms(1);
                        n=0;
                DisplayData[0] = GPIO_DIG_CODE[num1/1000];//千位
                DisplayData[1] = GPIO_DIG_CODE[num1%1000/100];//百位
                DisplayData[2] = GPIO_DIG_CODE[num1%1000%100/10];//十位
                DisplayData[3] = GPIO_DIG_CODE[num1%1000%100%10];//個位
                DisplayData[4] = GPIO_DIG_CODE[num0/1000];//千位
                DisplayData[5] = GPIO_DIG_CODE[num0%1000/100];//百位
                DisplayData[6] = GPIO_DIG_CODE[num0%1000%100/10];//十位
                DisplayData[7] = GPIO_DIG_CODE[num0%1000%100%10];
* K6   按下顯示日期
                if(K6==0)
                        delay(50);
                        if(K6==0)//開關按下;
                        KEYNUMA++;
        if(KEYNUMA==1)//第一次按下;
                Ds1302ReadTime();
                DisplayData[0] =num1=TIME[2]/16;                                //時
                DisplayData[1] =num1=TIME[2]&0x0f;
                DisplayData[2] = 0x40;
                DisplayData[3] =num1=TIME[1]/16;                                //分
                DisplayData[4] =num0=TIME[1]&0x0f;
                DisplayData[5] = 0x40;
                DisplayData[6] =num0=TIME[0]/16;                                //秒
                DisplayData[7] =num0=TIME[0]&0x0f;
                if(KEYNUMA==2)
                 num1=0;num0=0;
                        KEYNUMA=0;
* K5 第一次按下蜂鳴器鳴叫
* K5 第二次按下蜂鳴器關閉
                if(K5==0)
                        delay(20);
                        if(K5==0)//開關按下;
                        KEYNUM++;
                if(KEYNUM==1)//第一次按下;
                        beep=1;
                        delay(10);
                        beep=0;
                        delay(10);
                                if(KEYNUM==2)
                                beep=0; //蜂鳴器不響
                                KEYNUM=0;
                        beep=~beep;
                        delay(1000);//控制音調頻率
                        beep=~beep;//控制聲音大小
                        delay(10);
* K7第一次按下,LED燈亮
* K7第二次按下,LED燈滅
                if(K7==0)
                        delay(50);
                        if(K7==0)
                        KEYNUM1++;
                if(KEYNUM1==1)
                        LED1=1;
                        LED2=1;
                        LED3=1;
                        if(KEYNUM1==2)
                LED1=0;
                LED2=0;
                LED3=0;
/*        void LcdDisplay(int temp)          //lcd顯示
           float tp;
        if(temp< 0)                                //當溫度值為負數
                DisplayData[0] = 0x40;
                //因為讀取的溫度是實際溫度的補碼,所以減1,再取反求出原碼
                temp=temp-1;
                temp=~temp;
                tp=temp;
                temp=tp*0.0625*100+0.5;
                //留兩個小數點就*100,+0.5是四舍五入,因為C語言浮點數轉換為整型的時候把小數點
                //后面的數自動去掉,不管是否大于0.5,而+0.5之后大于0.5的就是進1了,小于0.5的就
                //算由?.5,還是在小數點后面。
                DisplayData[0] = 0x00;
                tp=temp;//因為數據處理有小數點所以將溫度賦給一個浮點型變量
                //如果溫度是正的那么,那么正數的原碼就是補碼它本身
/*        DisplayData[1 ] = GPIO_DIG_CODE[temp / 10000];
        DisplayData[2  ] = GPIO_DIG_CODE[temp % 10000 / 1000];
        DisplayData[ 3 ] = GPIO_DIG_CODE[temp % 1000 / 100] | 0x80;
        DisplayData[ 4] =GPIO_DIG_CODE[temp % 100 / 10];
        DisplayData[5  ] = GPIO_DIG_CODE[temp % 10];
         DigDisplay();                                           //掃描顯示
                if (temp==35)
                                beep=1;
                                delay(10);
                                beep=0;
                                delay(10);
                if (temp==-5)
                                beep=1;
                                delay(50);
                                beep=0;
                                delay(50);
        TMOD=0X02;  //選擇為定時器模式,工作方式2,僅用TRX打開啟動。
        TH0=0X9C;        //給定時器賦初值,定時100us
        TL0=0X9C;
        ET0=1;      //打開定時器0中斷允許
        EA=1;       //打開總中斷
        TR0=1;      //打開定時器
* 函 數 名         : Delay10ms
* 函數功能                   : 延時函數,延時10ms
* 輸    入         : 無
* 輸    出         : 無
void Delay10ms(unsigned int c)   //誤差 0us
    unsigned char a, b;
        //--c已經在傳遞過來的時候已經賦值了,所以在for語句第一句就不用賦值了--//
    for (;c>0;c--)
                for (b=38;b>0;b--)
                        for (a=130;a>0;a--);
* 函 數 名         : void At24c02Write(unsigned char addr,unsigned char dat)
* 函數功能                   : 往24c02的一個地址寫入一個數據
* 輸    入         : 無
* 輸    出         : 無
        I2C_Start();
        I2C_SendByte(0xa0, 1);//發送寫器件地址
        I2C_SendByte(addr, 1);//發送要寫入內存地址
        I2C_SendByte(dat, 0);        //發送數據
        I2C_Stop();
* 函 數 名         : unsigned char At24c02Read(unsigned char addr)
* 函數功能                   : 讀取24c02的一個地址的一個數據
* 輸    入         : 無
* 輸    出         : 無
        unsigned char num;
        I2C_Start();
        I2C_SendByte(0xa0, 1); //發送寫器件地址
        I2C_SendByte(addr, 1); //發送要讀取的地址
        I2C_Start();
        I2C_SendByte(0xa1, 1); //發送讀器件地址
        num=I2C_ReadByte(); //讀取數據
        I2C_Stop();
        return num;
void delay(u16 i)
        while(i--);
* 函 數 名         : GPIO_DIGDisplayDatalay() interrupt 1
* 函數功能                   : 中斷數碼管顯示
* 輸    入         : 無
* 輸    出         : 無
void GPIO_DIGDisplayDatalay() interrupt 1
//定時器在工作方式二會自動重裝初,所以不用在賦值。
//        TH0=0X9c;//給定時器賦初值,定時1ms
//        TL0=0X00;
        GPIO_DIG=0; //消隱
        switch(Num)         //位選,選擇點亮的數碼管,
                case(0):
                        LSA=0;LSB=0;LSC=0; break;//顯示第0位
                case(1):
                        LSA=1;LSB=0;LSC=0; break;//顯示第1位
                case(2):
                        LSA=0;LSB=1;LSC=0; break;//顯示第2位
                case(3):
                        LSA=1;LSB=1;LSC=0; break;//顯示第3位
                case(4):
                        LSA=0;LSB=0;LSC=1; break;//顯示第4位
                case(5):
                        LSA=1;LSB=0;LSC=1; break;//顯示第5位
                case(6):
                        LSA=0;LSB=1;LSC=1; break;//顯示第6位
                case(7):
                        LSA=1;LSB=1;LSC=1; break;//顯示第7位
        GPIO_DIG = DisplayData[Num]; //段選,選擇顯示的數字。
        Num++;
        if(Num>7)
                Num=0;
ID:584814 發表于 2019-12-27 07:30 | 顯示全部樓層
按鍵都是通的可能與程序無關罷
ID:675118 發表于 2019-12-27 10:11 | 顯示全部樓層
按鍵接通與斷開和程序無關,在仿真圖里按鍵旁邊有一個小點,點一下閉合,再點一下斷開,試一下看管用嗎
ID:667709 發表于 2019-12-27 19:08 | 顯示全部樓層
man1234567 發表于 2019-12-27 07:30
按鍵都是通的可能與程序無關罷
我之前一直都是直接往練習板上燒,燒出來的結果就是蜂鳴器一直響,然后按下蜂鳴器控制按鈕開始出現雜音,。LED控制按鈕只能點亮不能熄滅。八位數碼管上面按鍵K1按下顯示01過幾秒又跳回去。數碼管上電顯示的結果是00010003。我認為可能是          DisplayData[1]=num1=TIME[2]&0x0f;      那一段出錯,但是排不出來。
ID:667709 發表于 2019-12-27 19:09 | 顯示全部樓層
吃瓜群眾985 發表于 2019-12-27 10:11
我一直是在練習板上燒,然后看結果,
