查看: 1910|回復: 0
51單片機顯示時間可調時間
ID:671942 發表于 2019-12-24 03:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define lcd1602data P0
typedef unsigned char u8;
typedef unsigned int u16;
sbit E=P2^7;
sbit RW=P2^5;
sbit RS=P2^6;
sbit  key1=P3^1;
sbit  key2=P3^0;
sbit  key3=P3^2;
sbit SCLK=P3^6;
sbit IO=P3^4;
sbit RST=P3^5;
u16 read[]={0x81,0x83,0x85,0x87,0x89,0x8b,0x8d};
u16 write[]={0x80,0x82,0x84,0x86,0x88,0x8a,0x8c};
u8 time[]={0x30,0x30,0x22,0x08,0x02,0x05,0x19};
u16 setmark,setplace;
void delay_ms(u16 n);
void initConfiguration();
void lcdDisplay();
void lcdwrite_com(u8 datas);
void lcdwrite_datas(u8 datas);
void lcdinit();
void writebyte(u8 address,u8 datas);
u8 readbyte(u8 address);
void ds1302init();
void read_time();
         u16 i;
         lcdinit();
         ds1302init();
                 if(setmark==0)
                         read_time();
                          if(key1==0)
                                 delay_ms(1);
                                if(key1==0)
                                          setplace++;
                                         setplace%=7;
                                while(i<50&&key1==0)
                                        i++;
                                        delay_ms(10);
                                 i=0;
                         if(key2==0)
                                  delay_ms(1);
                                 if(key2==0)
                                          time[setplace]++;
                                        if((time[setplace]&0x0f)>9)
                                                time[setplace]=time[setplace]+6;
                                        if((time[setplace]>=0x60)&&(setplace<2))
                                                time[setplace]=0;
                                        if((time[setplace]>=0x24)&&(setplace==2))
                                                time[setplace]=0;
                                        if((time[setplace]>=0x32)&&(setplace==3))
                                                time[setplace]=0;
                                        if((time[setplace]>=0x13)&&(setplace==4))
                                                time[setplace]=0;
                                        if((time[setplace]>=0x7)&&(setplace==5))
                                                time[setplace]=1;
                                 while((i<50)&&(0==key2))
                                         i++;
                                        delay_ms(10);
                                 i=0;
                 lcdDisplay();
        u16 a,b;
        for(;n>0;n--)
                for(a=199;a>0;a--)
                        for(b=1;b>0;b--)
        EA=1;
        IT0=1;
        EX0=1;
void init0() interrupt 0
         delay_ms(10);
         if(key3==0)
                 setmark=~setmark;
                setplace=0;
                ds1302init();
void lcdDisplay()
        lcdwrite_com(0x80+0x00);
        lcdwrite_datas('2');
        lcdwrite_datas('0');
        lcdwrite_datas('0'+time[6]/16);
        lcdwrite_datas('0'+(time[6]&0x0f));
        lcdwrite_datas('-');
        lcdwrite_datas('0'+time[4]/16);
        lcdwrite_datas('0'+(time[4]&0x0f));
        lcdwrite_datas('0'+time[3]/16);
        lcdwrite_datas('0'+(time[3]&0x0f));
        lcdwrite_com(0x8c);
        lcdwrite_datas('0'+(time[5]&0x07));
        lcdwrite_com(0xc0);
        lcdwrite_datas('0'+time[2]/16);
        lcdwrite_datas('0'+(time[2]&0x0f));
        lcdwrite_datas('0'+time[1]/16);
        lcdwrite_datas('0'+(time[1]&0x0f));
        lcdwrite_datas('0'+time[0]/16);
        lcdwrite_datas('0'+(time[0]&0x0f));
        E=0;
        RW=0;
        RS=0;
        lcd1602data=datas;
        delay_ms(1);
        E=1;
        //delay_ms(1);
        E=0;
        E=0;
        RW=0;
        RS=1;
        lcd1602data=datas;
        delay_ms(1);
        E=1;
        //delay_ms(1);
        E=0;
void lcdinit()
        lcdwrite_com(0x38);
        lcdwrite_com(0x0c);
        lcdwrite_com(0x06);
        lcdwrite_com(0x01);
        lcdwrite_com(0x80);
        u8 i;
        RST=0;
        _nop_();
        SCLK=0;
        _nop_();
        RST=1;
        _nop_();
        for(i=0;i<8;i++)
                IO=address&0x01;
                address>>=1;
                SCLK=1;
                _nop_();
                SCLK=0;
                _nop_();
        for(i=0;i<8;i++)
                IO=datas&0x01;
                datas>>=1;
                SCLK=1;
                _nop_();
                SCLK=0;
                _nop_();
        RST=0;
        u8 i,datas,dat;
        RST=0;
        //_nop_();
        SCLK=0;
        //_nop_();
        RST=1;
        //_nop_();
        for(i=0;i<8;i++)
                IO=address&0x01;
                address>>=1;
                SCLK=1;
                _nop_();
                SCLK=0;
                _nop_();
        //_nop_();
        for(i=0;i<8;i++)
                dat=IO;
                datas=(datas>>1)|(dat<<7);
                SCLK=1;
                _nop_();
                SCLK=0;
                _nop_();
        RST=0;
        //_nop_();
        SCLK=1;
        //_nop_();
        IO=0;
        //_nop_();
        IO=1;
        //_nop_();
        return datas;
void ds1302init()
        u8 i;
        writebyte(0x8e,0x00);
        for(i=0;i<7;i++)
                writebyte(write[i],time[i]);
        writebyte(0x8e,0x80);
void read_time()
        u8 i;
        for(i=0;i<7;i++)
                time[i]=readbyte(read[i]);
