只需一步,快速開(kāi)始
查看: 5400|回復(fù): 4
通過(guò)arduino 控制 Arduino CNC 拓展板驅(qū)動(dòng)42步步進(jìn)電機(jī),通過(guò)紅外遙控以及藍(lán)搖a'...
ID:670217 發(fā)表于 2019-12-22 00:13 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
本帖最后由 L_L 于 2019-12-29 00:10 編輯
* Date:2019/12/20
* Content:HC-05 or Ir control Stepper motor
* Author : L.L
#include <IRremote.h>
#define EN 8 //步進(jìn)電機(jī)使能端,低電平有效
#define X_DIR 5 //X軸 步進(jìn)電機(jī)方向控制
#define Y_DIR 6 //y軸 步進(jìn)電機(jī)方向控制
#define Z_DIR 7 //z軸 步進(jìn)電機(jī)方向控制
#define A_DIR 13 //A軸 步進(jìn)電機(jī)方向控制
#define X_STP 2 //x軸 步進(jìn)控制
#define Y_STP 3 //y軸 步進(jìn)控制
#define Z_STP 4 //z軸 步進(jìn)控制
#define A_STP 12 //z軸 步進(jìn)控制
#define LEN 8 //緩沖區(qū)長(zhǎng)度,建議大于5
unsigned int keyVal = 8;//按鍵的值,彈起不會(huì)變0(1-8)
unsigned int rockerVal = 521;//搖桿的值,停下變0xff 0xff(0-360)
unsigned int seekBarVal = 50;//滑塊的值(0-100)
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long results_value = 0;
unsigned long Flag0 = 0,Flag1 = 0,Flag2 = 0,Flag3 = 0,Flag4 = 0,Flag5 = 0,Flag6 = 0,Flag7 = 0;
unsigned long Flag8 = 0,Flag9 = 0,Flag10 = 0,Flag11 = 0,Flag12 = 0,Flag13 = 0,Flag14 = 0,Flag15 = 0;
unsigned long flag0 = 0,flag1 = 0,flag2 = 0,flag3 = 0,flag4 = 0,flag5 = 0,flag6 = 0;
void Rocker_Data_Analyze(unsigned char *str,unsigned char len)
  if(str[0] == 'y')
    switch(str[1])
      case 'd':
          rockerVal = str[2] + str[3];
          XY_judge();
          //Serial.println(rockerVal);
          break;
      case 'b':
          keyVal = str[2];
          //Serial.println(keyVal);
          break;
      case 'v':
          seekBarVal = str[2];
          //Serial.println(seekBarVal);
          Z_judge();
          break;
      default :break;
void Uart_Receive(unsigned char cha)
  static unsigned char str[8];
  static unsigned char sta = 0;
  if((sta & 0x80) == 0)
    if(sta & 0x40)
      if(cha != 0x0D)
        sta = 0;
        sta |= 0x80;
        sta <<= 2;
        sta >>= 2;
        Rocker_Data_Analyze(str,sta);
        sta = 0;
      if(cha == 0x0A)
        sta |= 0x40;
        str[sta & 0x3F] = cha;
        sta++;
        if(sta > (LEN - 1))
          sta = 0;
//函數(shù):step 功能:控制步進(jìn)電機(jī)方向,步數(shù)。
//參數(shù):dir 方向控制, dirPin對(duì)應(yīng)步進(jìn)電機(jī)的DIR引腳,stepperPin 對(duì)應(yīng)步進(jìn)電機(jī)的step引腳, steps 步進(jìn)的步數(shù)
//無(wú)返回值
void step(boolean dir, byte dirPin, byte stepperPin, unsigned long int steps,unsigned int TIME)
  digitalWrite(dirPin,dir);//dir為true 則dirPin引腳輸出高電平,dir為false則dirPin引腳輸出低電平
  //delay(50);
  for (unsigned long int i = 0; i < steps; i++) //脈沖信號(hào)需<1kHz
    judge();
    digitalWrite(stepperPin, HIGH);//stepperPin引腳輸出高電平
    delayMicroseconds(TIME);//延時(shí)300us
    digitalWrite(stepperPin, LOW);//stepperPin引腳輸出高電平
void setup()
{ //將步進(jìn)電機(jī)用到的IO管腳設(shè)置成輸出
  Serial.begin(9600);//設(shè)置串口波特率為9600
  irrecv.enableIRIn(); // Start the receiver
  pinMode(X_DIR, OUTPUT); pinMode(X_STP, OUTPUT);
  pinMode(Y_DIR, OUTPUT); pinMode(Y_STP, OUTPUT);
  pinMode(Z_DIR, OUTPUT); pinMode(Z_STP, OUTPUT);
  pinMode(A_DIR, OUTPUT); pinMode(A_STP, OUTPUT);
  pinMode(EN, OUTPUT);
  digitalWrite(EN, LOW);//使能
void Stop()//停止轉(zhuǎn)動(dòng)
  {//X,Y,Z,A步進(jìn)引腳均輸出低電平
    digitalWrite(X_STP, LOW);
    digitalWrite(Y_STP, LOW);
    digitalWrite(Z_STP, LOW);
    digitalWrite(A_STP, LOW);
    judge();
void XY_Stop()//停止轉(zhuǎn)動(dòng)
  {//X,Y步進(jìn)引腳均輸出低電平
    judge();
void Z_Stop()//停止轉(zhuǎn)動(dòng)
  {//Z軸停止運(yùn)動(dòng)
    judge();
void XY_judge()
    if((((rockerVal >= 0) && (rockerVal <= 30)) || ((rockerVal >= 330) && (rockerVal < 360))) && (flag0 == 0))
      flag1 = flag2 = flag3 = flag4 = flag5 = flag6 = 0;
      flag0++;
      if(flag0 > 60000) flag0 = 1;
      Serial.print("X+");Serial.print('\t');Serial.print("Speed:");Serial.println(900 - keyVal * 100);
      step(true, X_DIR, X_STP, 160000,900 - keyVal * 100);
    if(((rockerVal >= 60) && (rockerVal<= 120))&& (flag1 == 0))
      flag0 =flag2 = flag3 = flag4 = flag5 = flag6 = 0;
      flag1++;
      if(flag1 > 60000) flag1 = 1;
      Serial.print("Y- and A-");Serial.print('\t');Serial.print("Speed:");Serial.println(900 - keyVal * 100);
      step(false, Y_DIR, Y_STP, 160000,900 - keyVal * 100);
    if(((rockerVal >= 150) && (rockerVal<= 210)) && (flag2 == 0))
      flag0 = flag1 = flag3 = flag4 = flag5 = flag6 = 0;
      flag2++;
      if(flag2 > 60000) flag2 = 1;
      Serial.print("X-");Serial.print('\t');Serial.print("Speed:");Serial.println(900 - keyVal * 100);
      step(false, X_DIR, X_STP, 160000,900 - keyVal * 100);
    if(((rockerVal >= 240) && (rockerVal<= 300))&& (flag3 == 0))
      flag0 = flag1 =flag2 = flag4 = flag5 = flag6 = 0;
      flag3++;
      if(flag3 > 60000) flag3 = 1;
      Serial.print("Y+ and A+");Serial.print('\t');Serial.print("Speed:");Serial.println(900 - keyVal * 100);
      step(true, Y_DIR, Y_STP, 160000,900 - keyVal * 100);
    if((rockerVal == 510) && (flag4 == 0))
       flag0 = flag1 =flag2 = flag3 = flag5 = flag6 = 0;
       flag4++;
       if(flag4 > 60000)  flag4 = 1;
       Serial.println("XY_Stop");
       XY_Stop();
void Z_judge()
    if((seekBarVal >= 0) && (seekBarVal <= 25))
      flag0 = flag1 =flag2 = flag3 = flag4 = flag5 = flag6 = 0;
      Serial.println("Z-");
      step(false, Z_DIR, Z_STP, 80000,150);
    if((seekBarVal >= 75) && (seekBarVal <= 100))
      Serial.println("Z+");
      step(true, Z_DIR, Z_STP, 80000,150);
    if(((seekBarVal > 25) && (seekBarVal < 75)) && (flag5 == 0))
      flag0 = flag1 = flag2 = flag3 = flag4 = flag6 = 0;
      flag5++;
      if(flag5 > 60000)flag5 = 1;
      Serial.println("Z_Stop");
      Z_Stop();
void loop()//死循環(huán)
  judge();
void BT_judge()
  while(Serial.available())//若檢測(cè)到串口有數(shù)據(jù),則進(jìn)入循環(huán)
    char data = Serial.read();//讀取串口數(shù)據(jù)
    Uart_Receive(data);
void IR_judge()
   if (irrecv.decode(&results))
    //Serial.println(results.value, HEX);
    results.value = results.value;
    switch(results.value)
      case 0xFFC23D:
                    if(Flag0 == 0)
                      Flag0++;
                      if(Flag0 >60000) Flag0 = 1;
                      Serial.println("STOP");
                      Stop();
                    break;
      case 0xFF02FD:
                    if(Flag1 == 0)
                      Flag0 = 0,Flag2 = 0,Flag3 = 0,Flag4 = 0,Flag5 = 0,Flag6 = 0,Flag7 = 0;
                      Flag1++;
                      if(Flag1 >60000) Flag1 = 1;
                      Serial.println("X+");
                      step(true, X_DIR, X_STP, 160000,300);
                    break;
      case 0xFF5AA5:
                    if(Flag2 == 0)
                      Flag0 = 0,Flag1 = 0,Flag3 = 0,Flag4 = 0,Flag5 = 0,Flag6 = 0,Flag7 = 0;
                      Flag2++;
                      if(Flag2 >60000) Flag2 = 1;
                      Serial.println("X++");
                      step(true, X_DIR, X_STP, 160000,200);
                    break;
      case 0xFF30CF:
                     if(Flag3 == 0)
                      Flag0 = 0,Flag1 = 0,Flag2 = 0,Flag4 = 0,Flag5 = 0,Flag6 = 0,Flag7 = 0;
                      Flag3++;
                      if(Flag3 >60000) Flag3 = 1;
                      Serial.println("X+++");
                      step(true, X_DIR, X_STP, 160000,100);
                    break;
      case 0xFF22DD:
                    if(Flag4 == 0)
                      Flag0 = 0,Flag1 = 0,Flag2 = 0,Flag3 = 0,Flag5 = 0,Flag6 = 0,Flag7 = 0;
                      Flag4++;
                      if(Flag4 >60000) Flag4 = 1;
                      Serial.println("X-");
                      step(false, X_DIR, X_STP, 160000,300);
                    break;
      case 0xFF10EF:
                    if(Flag5 == 0)
                      Flag0 = 0,Flag1 = 0,Flag2 = 0,Flag3 = 0,Flag4 = 0,Flag6 = 0,Flag7 = 0;
                      Flag5++;
                      if(Flag5 >60000) Flag5 = 1;
                      Serial.println("X--");
                      step(false, X_DIR, X_STP, 160000,200);
                    break;
      case 0xFF7A85:
                     if(Flag6 == 0)
                      Flag0 = 0,Flag1 = 0,Flag2 = 0,Flag3 = 0,Flag4 = 0,Flag5 = 0,Flag7 = 0;
                      Flag6++;
                      if(Flag6 >60000) Flag6 = 1;
                    Serial.println("X---");
                    step(false, X_DIR, X_STP, 160000,100);
                    break;
      case 0xFFA857:
                    if(Flag7 == 0)
                      Flag0 = 0,Flag1 = 0,Flag2 = 0,Flag3 = 0,Flag4 = 0,Flag5 = 0,Flag6 = 0;
                      Flag7++;
                      if(Flag7 >60000) Flag7 = 1;
                    Serial.println("Y+ and A+");
                    step(true, Y_DIR, Y_STP, 160000,300);
                    break;
      case 0xFF18E7:
                    if(Flag8 == 0)
                      Flag3 = 0,Flag9 = 0,Flag10 = 0,Flag11 = 0,Flag12 = 0,Flag13 = 0,Flag14 = 0,Flag15 = 0;
                      Flag8++;
                      if(Flag8 >60000) Flag8 = 1;
                    Serial.println("Y++ and A++");
                    step(true, Y_DIR, Y_STP, 160000,200);
                    break;
      case 0xFF42BD:
                    if(Flag9 == 0)
                      Flag8 = 0,Flag3 = 0,Flag10 = 0,Flag11 = 0,Flag12 = 0,Flag13 = 0,Flag14 = 0,Flag15 = 0;
                      Flag9++;
                      if(Flag9 >60000) Flag9 = 1;
                    Serial.println("Y+++ and A+++");
                    step(true, Y_DIR, Y_STP, 160000,100);
                    break;
      case 0xFFE01F:
                    if(Flag10 == 0)
                      Flag8 = 0,Flag9 = 0,Flag3 = 0,Flag11 = 0,Flag12 = 0,Flag13 = 0,Flag14 = 0,Flag15 = 0;
                      Flag10++;
                      if(Flag10 >60000) Flag10 = 1;
                    Serial.println("Y- and A-");
                    step(false, Y_DIR, Y_STP, 160000,300);
                    break;
      case 0xFF4AB5:
                    if(Flag11 == 0)
                      Flag8 = 0,Flag9 = 0,Flag10 = 0,Flag3 = 0,Flag12 = 0,Flag13 = 0,Flag14 = 0,Flag15 = 0;
                      Flag11++;
                      if(Flag11 >60000) Flag11 = 1;
                    Serial.println("Y-- and A--");
                    step(false, Y_DIR, Y_STP, 160000,200);
                    break;
      case 0xFF52AD:
                    if(Flag12 == 0)
                      Flag8 = 0,Flag9 = 0,Flag10 = 0,Flag11 = 0,Flag3 = 0,Flag13 = 0,Flag14 = 0,Flag15 = 0;
                      Flag12++;
                      if(Flag12 >60000) Flag12 = 1;
                    Serial.println("Y--- and A---");
                    step(false, Y_DIR, Y_STP, 160000,100);
                    break;
      case 0xFFE21D:
                     if(Flag13 == 0)
                      Flag8 = 0,Flag9 = 0,Flag10 = 0,Flag11 = 0,Flag12 = 0,Flag3 = 0,Flag14 = 0,Flag15 = 0;
                      Flag13++;
                      if(Flag13 >60000) Flag13 = 1;
                    Serial.println("Z++");
                    step(true, Z_DIR, Z_STP, 160000,150);
                    break;
      case 0xFFA25D:
                     if(Flag14 == 0)
                      Flag8 = 0,Flag9 = 0,Flag10 = 0,Flag11 = 0,Flag12 = 0,Flag13 = 0,Flag3 = 0,Flag15 = 0;
                      Flag14++;
                      if(Flag14 >60000) Flag14 = 1;
                    Serial.println("Z--");
                    step(false, Z_DIR, Z_STP, 160000,150);
                    break;
      default :break;
    irrecv.resume(); // Receive the next value
void judge()
     if(Serial.available())
        BT_judge();
        IR_judge();
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏3 分享淘帖 頂 踩
ID:709180 發(fā)表于 2020-3-26 04:47 | 只看該作者
沒(méi)人試試嗎?
ID:185255 發(fā)表于 2020-4-13 19:45 | 只看該作者
樓主用的步進(jìn)電機(jī)型號(hào)能不能發(fā)出來(lái)看看啊
ID:670217 發(fā)表于 2021-6-6 01:15 | 只看該作者
利維亞的工程師 發(fā)表于 2020-4-13 19:45
42步進(jìn)電機(jī)
ID:1094297 發(fā)表于 2023-9-22 23:24 | 只看該作者
Arduino:1.8.19 (Windows 10), 開(kāi)發(fā)板:"WEMOS D1 MINI ESP32, 80MHz, Default, 240MHz (WiFi/BT), 921600, None, Disabled"
sketch_sep22a:7:10: fatal error: IRremote.h: No such file or directory
compilation terminated.
exit status 1
在文件 -> 首選項(xiàng)開(kāi)啟
“編譯過(guò)程中顯示詳細(xì)輸出”選項(xiàng)
這份報(bào)告會(huì)包含更多信息。
