查看: 3071|回復: 0
51單片機正反轉程序
ID:669441 發表于 2019-12-20 20:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define uint  unsigned int
//------8拍-----
uchar code zz[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09};                        //正轉
uchar code fz[]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01};                        //反轉
sbit K1=P3^0;        //停止
sbit K2=P3^1;        //正轉
sbit K3=P3^2;        //反轉
sbit K4=P3^3;        //加速
sbit K5=P3^4;        //減速
uchar state=0;        //狀態變量
uint Time=60;         //延時時間,用于調速
unsigned char receiveData='0';
void UsartConfiguration();           //初始化串口
void delay(uint ms)                           //延時,用于調速
        uint t;
        while(ms--)
                for(t=0;t<120;t++);
void motor_zz()                  //正傳函數
        uint j;
        for(j=0;j<8;j++)
                if(P3==0xfb)
                        break;
                P1=zz[j];
                delay(Time);
void motor_fz()                  //反轉函數
        uint j;
        for(j=0;j<8;j++)
                if(P3==0xfb)
                        break;
                P1=fz[j];
                delay(Time);
                while(state==0)                        //狀態0,停止
                        if((K2==0)||(receiveData=='z'))           //按下K2或串口接收到'z',電機正轉
                                state=1;
                                receiveData='0';
                                break;
                        if((K3==0)||(receiveData=='f'))           //按下K3或串口接收到'f',電機反轉
                                state=2;
                                receiveData='0';
                                break;
                        P0=0xfb;
                        P1=0x03;
                while(state==1)                        //狀態1,正轉
                        if((K1==0)||(receiveData=='t'))           //按下K1或串口接收到'f',電機反轉
                                state=0;
                                receiveData='0';
                                break;
                                state=1;
                                receiveData='0';
                                break;
                                state=2;
                                receiveData='0';
                                break;
                        if((K4==0)||(receiveData=='+'))                //按下K4或串口接收到'+',電機加速
                                Time=Time-5;
                                if(Time<20)
                                Time=20;
                                while(K4==0);
                        if((K5==0)||(receiveData=='-'))                //按下K5或串口接收到'-',電機減速
                                Time=Time+5;
                                if(Time>100)
                                Time=100;
                                while(K5==0);
                        motor_zz();                 //狀態1,正轉
                while(state==2)                   //狀態2,反轉
                                state=0;
                                receiveData='0';
                                break;
                                state=1;
                                receiveData='0';
                                break;
                                state=2;
                                receiveData='0';
                                break;
                                Time=Time-5;
                                if(Time<20)
                                Time=20;
                                while(K4==0);
                                Time=Time+5;
                                if(Time>100)
                                Time=100;
                                while(K5==0);
                        motor_fz();                //狀態2,反轉
