查看: 1516|回復: 0
單片機IIC驅動協議程序
ID:613800 發表于 2019-12-19 21:01 | 顯示全部樓層 |閱讀模式
練手學習,僅供參考
sbit a0=ACC^0;//定義ACC的位,利用ACC操作速度最快
sbit a1=ACC^1;
sbit a2=ACC^2;
sbit a3=ACC^3;
sbit a4=ACC^4;
sbit a5=ACC^5;
sbit a6=ACC^6;
sbit a7=ACC^7;
void s24(void)
_nop_();scl=0;sda=1;scl=1;_nop_();sda=0;_nop_();scl=0;
void s240(void)
_nop_();scl0=0;sda0=1;scl0=1;_nop_();sda0=0;_nop_();scl0=0;
void p24(void)
sda=0;scl=1;_nop_();sda=1;
void p240(void) {
sda0=0;scl0=1;_nop_();sda0=1;
unsigned char rd24(void)
sda=1;
scl=1;a7=sda;scl=0;
scl=1;a6=sda;scl=0;
scl=1;a5=sda;scl=0;
scl=1;a4=sda;scl=0;
scl=1;a3=sda;scl=0;
scl=1;a2=sda;scl=0;
scl=1;a1=sda;scl=0;
scl=1;a0=sda;scl=0;
sda=1;scl=1;scl=0;
return(ACC);
void wd24(unsigned char dd)
ACC=dd;
sda=a7;scl=1;scl=0;
sda=a6;scl=1;scl=0;
sda=a5;scl=1;scl=0;
sda=a4;scl=1;scl=0;
sda=a3;scl=1;scl=0;
sda=a2;scl=1;scl=0;
sda=a1;scl=1;scl=0;
sda=a0;scl=1;scl=0;
sda=1;scl=1;
unsigned char read(unsigned int address)
unsigned char dd;
dd=((address&0x7ff)/256)<<1;
s24();wd24(0xa0|dd);scl=0;wd24(address);scl=0;
s24();wd24(0xa1|dd);scl=0;dd=rd24();p24();return(dd);
void write(unsigned int address,unsigned char dd)
unsigned char ddd;
ddd=((address&0x7ff)/256)<<1;
s24();wd24(0xa0|ddd);scl=0;wd24(address);scl=0;wd24(dd);scl=0;p24();
time=0;             //time為定時器時間參考,time增加1代
//表1ms,如果沒有用定時器,取消該行
while (1)
s24();
wd24(0xa0|ddd);
sda=1;
if (sda==0) break;
if (time>10) break;           //此行防止由于eeprom器件損壞后的死循環
scl=0;
