查看: 4258|回復: 0
51單片機點陣實現箭頭移動代碼+仿真
#include<reg51.h>
#include<intrins.h>
#define uchar unsigned char;
#define uint unsigned int;
uchar code M[]={0xff,0xff,0xfe,0xfd,0xf8,0xfd,0xfe,0xff,
                                0xff,0xff,0xfd,0xfb,0xf0,0xfb,0xfd,0xff,
                                0xff,0xff,0xfb,0xf7,0xe0,0xf7,0xfb,0xff,
                                0xff,0xff,0xf7,0xef,0xc0,0xef,0xf7,0xff,
                                0xff,0xff,0xef,0xdf,0x80,0xdf,0xef,0xff,
                                0xff,0xff,0xdf,0xbf,0x00,0xbf,0xdf,0xff};
uchar i,num,t;
int main(){
        TMOD=0x01;
        TH0=(65536-2000)/256;
        TL0=(65536-2000)%256;
        TR0=1;
        EA=1;
        ET0=1;
        P3=0x80;
        while(1);
        return 0;
完整代碼及仿真見附件 點陣箭頭.rar (15.69 KB, 下載次數: 62)
