當(dāng)前已完成時鐘的走停,現(xiàn)在要讓時分秒數(shù)據(jù)發(fā)送到串口助手上,不知道如何寫程序了?年月日暫時先不弄,時分秒的數(shù)據(jù)只能分別發(fā)送到串口助手上顯示,有沒有大佬幫忙看看如何還你那個時分秒整體數(shù)據(jù)發(fā)送到串口助手上
#include<reg51.h>
#include"lcd.h"
sbit key1=P1^4;
sbit key2=P1^5;
sbit key3=P1^6;
extern uchar code table[]=" 2020-01-01 THU";
extern uchar code table1[]=" 00:00:00";
uchar count,key1num;
char shi,fen,miao;
char ri,yue,nian;
void delay(uint z) /延時
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void Init () /初始化
{ uchar num;
P1=0xf0;
InitLcd1602();
EA=1;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
ET0=1;
TR0=1;
for(num=0;num<15;num++)
Lcd1602_Write_Data(table[num]);
delay(5);
Lcd1602_Write_Cmd(0x80+0x40);
for(num=0;num<12;num++)
Lcd1602_Write_Data(table1[num]);
delay(5);
void write_sfm(uchar add,uchar date) //時分秒
uchar shi1,ge;
shi1=date/10;
ge=date%10;
Lcd1602_Write_Cmd(0x80+0x40+add);
Lcd1602_Write_Data(0x30+shi1);
Lcd1602_Write_Data(0x30+ge);
SBUF=0x30+shi1;
while (!TI);
TI = 0;
SBUF=0x30+ge;
while (!TI);
TI = 0;
void write_nyr(uchar add,uchar date)
char shi2,ge2;
shi2=date/10;
ge2=date%10;
Lcd1602_Write_Cmd(0x80+add);
Lcd1602_Write_Data(0x30+shi2);
Lcd1602_Write_Data(0x30+ge2);
void timer0() interrupt 1
count++;
if(count==20)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
ri++;
if(ri==31)
ri=0;
yue++;
if(yue==13)
yue=0;
nian++;
write_nyr(3,nian);
write_nyr(6,yue);
write_nyr(9,ri);
write_sfm(4,shi);
void KEY()
if(key1==0)
delay(5);
if(key1==0)
{ key1num++;
while(!key1);
if( key1num==1)
TR0=0;
Lcd1602_Write_Cmd(0x80+0X40+11);
Lcd1602_Write_Cmd(0x0f);
if( key1num==2)
Lcd1602_Write_Cmd(0x80+0X40+8);
if( key1num==3)
Lcd1602_Write_Cmd(0x80+0X40+5);
if( key1num==4)
key1num=0;
Lcd1602_Write_Cmd(0x0c);
TR0=1;
if(key1num!=0)
if(key2==0)
delay(5);
if(key2==0)
{ while(!key2);
if(key1num==1)
miao++;
if(miao==60)
miao=0;
write_sfm(10,miao);
if(key1num==2)
{ fen++;
if(fen==60)
fen=0;
write_sfm(7,fen);
if(key1num==3)
{ shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
if(key3==0)
delay(5);
if(key3==0)
while(!key3);
if(key1num==1)
miao--;
if(miao==-1)
miao=59;
write_sfm(10,miao);
if(key1num==2)
{ fen--;
if(fen==-1)
fen=59;
write_sfm(7,fen);
if(key1num==3)
{ shi--;
if(shi==-1)
shi=23;
write_sfm(4,shi);
void main(void)
Init();
UsartConfiguration();
// write_sfm(0x80+0x40+5,shi);
// SBUF=shi;
// while (!TI);
// TI = 0;
// write_sfm(0x80+0x40+8,fen);
// SBUF=fen;
// while (!TI);
// TI = 0;
// write_sfm(0x80+0x40+11,miao);
// SBUF=miao;
// while (!TI);
// TI = 0;
// Lcd1602_Write_Cmd(0x80+0x40+5);
// SBUF=shi;
// while (!TI);
// TI = 0;
// Lcd1602_Write_Cmd(0x80+0x40+8);
// SBUF=fen;
// while (!TI);
// TI = 0;
// Lcd1602_Write_Cmd(0x80+0x40+11);
// SBUF=miao;
// while (!TI);
// TI = 0;
KEY();
