查看: 2352|回復(fù): 1
土壤數(shù)據(jù)模塊的數(shù)值為啥要經(jīng)過*9.90/255 然后通過1000- 求大佬幫助
ID:667804 發(fā)表于 2019-12-18 21:38 | 顯示全部樓層 |閱讀模式
#include <reg51.H>
#include "intrins.h"
#define ulong unsigned long
#define     LCDIO      P0         //液晶屏數(shù)據(jù)口
//ADC0832的引腳
sbit ADCLK =P1^1;  //ADC0832 clock signal
sbit ADDIO =P1^3;  //ADC0832 k in
sbit ADCS =P1^4;  //ADC0832 chip seclect
sbit rs=P1^0;  //定義1602 RS
sbit lcden=P1^2; //定義1602 EN
sbit key1=P3^0;    //設(shè)定
sbit key2=P3^1;    //加
sbit key3=P3^2;    //減
sbit motor=P3^7;   //繼電器接口
sbit speak=P1^5;        //蜂鳴器接口
uchar key;         //設(shè)定指針
uint RH=400,RL=200;//水位上下限
float temp_f;
ulong temp;
uchar v;
uchar count,s1num;
uchar code table[]= " moisture:          ";
uchar code table1[]="RH:  %              ";
uchar getdata; //獲取ADC轉(zhuǎn)換回來的值
void delay(uint z)                  //延時(shí)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(uchar com)
        rs=0;
//        rd=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        rs=1;
//        rd=0;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void lcdinit()
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
void init()
        uchar num;
        for(num=0;num<15;num++)
                        write_date(table[num]);
                        delay(5);
        write_com(0x80+0x40);
                        write_date(table1[num]);
                        delay(5);
讀ADC0832函數(shù)
//采集并返回
函數(shù)功能:AD轉(zhuǎn)換子程序
入口參數(shù):CH(如果讀取CH0,channel的值為0x01,如果讀取CH1則channel的值為0x03)
出口參數(shù):adval
uchar Adc0832()     //AD轉(zhuǎn)換,返回結(jié)果
    uchar i;
    uchar dat=0;
    ADCLK=0;
    ADDIO=1;
    ADCS=0;                  //拉低CS端
    ADCLK=1;
    ADCLK=0;                 //拉低CLK端,形成下降沿1
    ADDIO=1;//指定轉(zhuǎn)換通道是CH1還是CH2,指定值位與0x1,取最后一位的值
    ADCLK=1;
    ADCLK=0;                 //拉低CLK端,形成下降沿2
    ADDIO=0;//指定值右移一位,再取最后一位的值
    ADCLK=1;
    ADCLK=0;                //拉低CLK端,形成下降沿3
    ADDIO=1;
        for(i=0;i<8;i++)
        ADCLK=1;
        ADCLK=0;           //形成一次時(shí)鐘脈沖
        if(ADDIO)
                   dat|= 0x80>>i;  //收數(shù)據(jù),最高位置1,
    ADCS=1;                //拉低CS端
    ADCLK=1;
    ADDIO=1;               //拉高數(shù)據(jù)端,回到初始狀態(tài)
    return(dat);           //return dat
void displayRH()                        //下限顯示
{write_com(0xc0+3);
write_date(RH/100%10+0x30);//上限百位
write_date(RH/10%10+0x30);//上限十位
//write_date('.');
//write_date(RH%10+0x30);
void displayRL()          //下限顯示
{write_com(0xca);
  write_date('R');
  write_date('L');
  write_date(':');
write_date(RL/100%10+0x30);//下限百位
write_date(RL/10%10+0x30);//下限十位
write_date('%');
void keyscan()                 //按鍵處理
{bit kk1=0,kk2=0;
if(key1==0)
{delay(30);
  while(key1==0);
   if(key>=2)
   {key=0;
   {key++;
   switch(key)
   {speak=1;kk2=motor;motor=1;
    case 1:{write_com(0x0f);write_com(0xce); //光標(biāo)閃爍
        while(key1!=0)         //等待按鍵松開
    if(key2==0)                //key2按鍵下
   {delay(30);                //按鍵延時(shí)消抖
   if(key2==0)                //確定key2按下
    while(key2==0); //等待松開
        if(RL>=998)
        {RL=999;                //RL下限最大設(shè)置為99
        {RL+=10;                //RL加1
   displayRL();                //調(diào)用RL下限顯示函數(shù)
   write_com(0xce);
   if(key3==0)                //key3按下
   if(key3==0)                //確定key3按下
    while(key3==0);         //等待key3按鍵松開
        if(RL<=1)                 //RL最小設(shè)置為1
        {RL=0;
        {RL-=10;                 //RL下限減1
   write_com(0xce);
   }while(key1==0);
        case 2:{write_com(0x0f);write_com(0xc4);  //RH設(shè)置數(shù)據(jù),光標(biāo)閃爍
   while(key1==1)
    if(key2==0)           //key2按下
        if(RH>=998)                //RH最大設(shè)置為99
        {RH=999;
        {RH+=10;                //RH加1
   displayRH();                //RH上限顯示函數(shù)
    write_com(0xc4);
   if(key3==0)          //確定按下
    while(key3==0);//等待松開
        if(RH<=1)           //RH最小設(shè)置為1
        {RH=0;
        {RH-=10;                //RH減1
   displayRH();                //調(diào)用RH顯示函數(shù)
    write_com(0xc4);
   while(key1==0);
        case 0:{write_com(0x0c);
                        motor=kk2;
            break;}
void Conut(void)          //土壤檢測(cè)數(shù)據(jù)轉(zhuǎn)換
      v=Adc0832();
          temp=v;
      temp_f=temp*9.90/2.55;
      temp=temp_f;
          temp=1000-temp;
          write_com(0x80+10);
          write_date(temp/100%10+0x30);//千位
          write_date(temp/10%10+0x30);//百位
          write_date('.');
          write_date(temp%10+0x30);
          write_date('%');//顯示符號(hào)位
/********void Conut(void)          //土壤檢測(cè)數(shù)據(jù)轉(zhuǎn)換
      v=Adc0832();
          temp=v;
      temp=temp_f;
          temp=1000-temp;
          write_com(0x80+10);
          write_date('.');
void main(void)
        lcdinit();
        init();
        displayRH();   //顯示上限
        displyRL();   //顯示下限
        delay(50);         //啟動(dòng)等待,等LCD講入工作狀態(tài)
        delay(50);         //延時(shí)片刻(可不要)
        delay(50);
        Conut();           //顯示函數(shù)
        delay(150);
             Conut();        //顯示當(dāng)前濕度
                 keyscan();
                 if(temp>RH)  //如果濕度大于上限停止?jié)菜?br />                  {motor=1;          //關(guān)閉繼電器
                 else if(temp<RL) //如果濕度小于RL下限啟動(dòng)澆水
                 {motor=0;                 //啟動(dòng)繼電器
                 if(temp<RL)           //小于下限啟動(dòng)報(bào)警并澆水
                 {speak=0;                                //啟動(dòng)報(bào)警
                  delay(150);                         //延時(shí)
                  speak=1;
                 keyscan();                 //按鍵檢測(cè)
                 delay(150);                         //延時(shí)50MS
ID:584814 發(fā)表于 2019-12-19 15:54 | 顯示全部樓層
ADC0832是個(gè)8位器件,輸出值為0-255,你除256也是對(duì)的;
至于9.9,感覺是怕爆表了(990/255=9.9/2.55)。
