查看: 1211|回復: 0
proteus仿真的幾個實例教程
ID:667253 發表于 2019-12-18 16:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#include <absacc.h>
sbit p10=P1^0;
sbit p11=P1^1;
sbit p12=P1^2;
#define UP 20
#define DOWN 30
#define STOP 40
void delay()
        unsigned i,j,k;
        for(i=0;i<0x02;i++)
        for(j=0;j<0x02;j++)
        for(k=0;k<0xff;k++);
main()
        unsigned char temp;
                if(p10==0)
                        temp=UP;
                        P2=0xff;
                        delay();
                        if(p11==0)
                        temp=DOWN;
                        P2=0xff;
                        delay();
                        if(p12==0)
                        temp=STOP;
                switch(temp)
                        case DOWN:P2=0x03;
                                  delay();
                                  delay();
                                  P2=0x06;
                                  delay();
                                  delay();
                                                    P2=0x0c;
                                  delay();
                                  delay();
                                                    P2=0x09;
                                  delay();
                                  delay();
                                  break;
                        case UP: P2=0x03;
                                  delay();
                                  delay();
                                  P2=0x09;
                                  delay();
                                  delay();
                                                    P2=0x0c;
                                  delay();
                                  delay();
                                                    P2=0x06;
                                  delay();
                                  delay();
                                  break;
                        case STOP:
                                       P2=0xff;
                                                   delay();
                                 delay();
                                 break;
嵌入式作業.zip
1.16 MB, 下載次數: 2, 下載積分: 黑幣 -5
proteus代碼加圖片
