查看: 3930|回復: 0
ARM流水燈實驗 LPC213芯片
#include  "config.h"
#include "lpc213x.h"
void DelayNs(uint32 dly)
{        uint32        i;
        for(;dly;dly--)
                for(i=0;i<5000;i++);
void Left()
        uint8        i;
        uint32  MOVE ;
        for (i=0;i<8;i++)
                MOVE  = 1 << i;
                IO0CLR = MOVE ;
                DelayNs(10);
                IO0SET = MOVE ;
                DelayNs(10);
void Right()
        uint8        i;
        uint32  MOVE;
        for (i=0;i<8;i++)
                MOVE  = 0X80 >> i;
                IO0CLR = MOVE ;
                DelayNs(10);
                IO0SET = MOVE ;
                DelayNs(10);
int main(void)
        PINSEL0        = 0x00000000;
        PINSEL1        = 0x00000000;
        IO0DIR = 0x000000FF;
        IO0SET = 0x000000FF; //高電平為關燈.
          if(IO0PIN&0x20000000)
                  Left();
                  Right();
收藏收藏2 分享淘帖 頂 踩
