打開程序,加載hex文件運行成功后是這個界面 這個時候長按設置鍵,就會出現一個#的光標。如下圖 這時候就是調整波形的情況,按下波形轉換按鍵,就會轉變輸出波形。 短按設置按鍵就會變化成調整頻率的狀態,如下圖 出現的光標就是調整當前位置的數字,按增加和減少按鍵可以調整,短按波形轉換按鍵可以調光標位置,具體如下圖  再短按設置按鍵就會變化成調整其他參數的狀態,出現的光標就是調整當前位置的數字,按增加和減少按鍵可以調整,短按波形轉換按鍵可以調光標位置。
- #include "reg52.h"
- #include "LCD1602.h"
- #include "key.h"
- #define DAPort P2 //這里是P2
- sbit IO = P3^0;
- unsigned int count;
- unsigned int freqtemp=1000;
- static unsigned char code TableSin[256]={
- 128,131,134,137,140,143,146,149,152,155,158,162,165,167,170,173,
- 176,179,182,185,188,190,193,196,198,201,203,206,208,211,213,215,
- 218,220,222,224,226,228,230,232,234,235,237,238,240,241,243,244,
- 245,246,248,249,250,250,251,252,253,253,254,254,254,255,255,255,
- 255,255,255,255,254,254,254,253,253,252,251,250,250,249,248,246,
- 245,244,243,241,240,238,237,235,234,232,230,228,226,224,222,220,
- 218,215,213,211,208,206,203,201,198,196,193,190,188,185,182,179,
- 176,173,170,167,165,162,158,155,152,149,146,143,140,137,134,131,
- 127,124,121,118,115,112,109,106,103,100, 97, 93, 90, 88, 85, 82,
- 79, 76, 73, 70, 67, 65, 62, 59, 57, 54, 52, 49, 47, 44, 42, 40,
- 37, 35, 33, 31, 29, 27, 25, 23, 21, 20, 18, 17, 15, 14, 12, 11,
- 10, 9, 7, 6, 5, 5, 4, 3, 2, 2, 1, 1, 1, 0, 0, 0,
- 0, 0, 0, 0, 1, 1, 1, 2, 2, 3, 4, 5, 5, 6, 7, 9,
- 10, 11, 12, 14, 15, 17, 18, 20, 21, 23, 25, 27, 29, 31, 33, 35,
- 37, 40, 42, 44, 47, 49, 52, 54, 57, 59, 62, 65, 67, 70, 73, 76,
- 79, 82, 85, 88, 90, 93, 97,100,103,106,109,112,115,118,121,124
- static unsigned char code TableTriangle[256]={
- 128,130,132,134,136,138,140,142,144,146,148,150,152,154,156,158,
- 160,162,164,166,168,170,172,174,176,178,180,182,184,186,188,190,
- 192,194,196,198,200,202,204,206,208,210,212,214,216,218,220,222,
- 224,226,228,230,232,234,236,238,240,242,244,246,248,250,252,254,
- 255,254,252,250,248,246,244,242,240,238,236,234,232,230,228,226,
- 224,222,220,218,216,214,212,210,208,206,204,202,200,198,196,194,
- 192,190,188,186,184,182,180,178,176,174,172,170,168,166,164,162,
- 160,158,156,154,152,150,148,146,144,142,140,138,136,134,132,130,
- 128,126,124,122,120,118,116,114,112,110,108,106,104,102,100, 98,
- 96, 94, 92, 90, 88, 86, 84, 82, 80, 78, 76, 74, 72, 70, 68, 66,
- 64, 62, 60, 58, 56, 54, 52, 50, 48, 46, 44, 42, 40, 38, 36, 34,
- 32, 30, 28, 26, 24, 22, 20, 18, 16, 14, 12, 10, 8, 6, 4, 2,
- 0, 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30,
- 32, 34, 36, 38, 40, 42, 44, 46, 48, 50, 52, 54, 56, 58, 60, 62,
- 64, 66, 68, 70, 72, 74, 76, 78, 80, 82, 84, 86, 88, 90, 92, 94,
- 96, 98,100,102,104,106,108,110,112,114,116,118,120,122,124,126
- static unsigned char code TableSaw[256]={
- 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15,
- 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31,
- 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47,
- 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63,
- 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79,
- 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95,
- 96, 97, 98, 99,100,101,102,103,104,105,106,107,108,109,110,111,
- 112,113,114,115,116,117,118,119,120,121,122,123,124,125,126,127,
- 128,129,130,131,132,133,134,135,136,137,138,139,140,141,142,143,
- 144,145,146,147,148,149,150,151,152,153,154,155,156,157,158,159,
- 160,161,162,163,164,165,166,167,168,169,170,171,172,173,174,175,
- 176,177,178,179,180,181,182,183,184,185,186,187,188,189,190,191,
- 192,193,194,195,196,197,198,199,200,201,202,203,204,205,206,207,
- 208,209,210,211,212,213,214,215,216,217,218,219,220,221,222,223,
- 224,225,226,227,228,229,230,231,232,233,234,235,236,237,238,239,
- 240,241,242,243,244,245,246,247,248,249,250,251,252,253,254,255
- void main(void)
- LCDInit();
- AmPort = 0xff;
- fword = 1009;
- TMOD= 0x02;
- TH0 = 0xf0;
- TL0 = 0xf0;
- TR0=1; //計數器停止計數
- ET0=1; //開啟計數器0中斷
- LCDDispString(0,1,"wave:Sin Vo:5.0V");
- LCDDispString(0,2,"f: 01000Hz D:--%");
- EA=1; //開總中斷
- fword = (unsigned int)(freqtemp*1.05);
- while(1)
- key_scan();
- //gType=0:正弦波
- //gType=1:方波
- //gType=2:三角波
- //gType=3:鋸齒波
- void timer0(void) interrupt 1 //計數器0中斷
- count = count + fword;
- switch(gType)
- case 0: DAPort = TableSin[count>>8];
- break;
- case 1: if(count>Duty*655)
- DAPort = 0xff;
- else
- DAPort = 0x00;
- break;
- case 2: DAPort = TableTriangle[count>>8];
- break;
- case 3: DAPort = TableSaw[256-(count>>8)];
- break;
- default:DAPort = TableSin[count>>8];
所有資料51hei提供下載(只有程序,仿真文件暫不分享):
源程序.zip
(66.26 KB, 下載次數: 44)
2019-12-16 14:07 上傳
下載積分: 黑幣 -5
源程序WORD版.doc
(133.5 KB, 下載次數: 8)
2019-12-16 14:07 上傳
下載積分: 黑幣 -5
