查看: 1639|回復: 0
單片機萬年歷程序全部顯示00 求幫助
實物如圖
#include"reg51.h"
#define        uint unsigned int
sbit rs=P1^2;
sbit rw=P1^1;
sbit lcden=P1^0;
sbit s1=P3^4;
sbit s2=P3^5;
sbit s3=P3^6;
sbit s4=P3^2;
sbit rd=P3^7;
sbit beep=P2^0;
sbit dscs=P1^7;
sbit dsas=P1^6;
sbit dsrw=P1^5;
sbit dsds=P1^4;
sbit dsirq=P3^3;
bit flag1,flag_ri;                   //定義兩個位變量
uchar count,s1num,flag,t0_num;       //其他變量定義
char miao,shi,fen,year,month,day,week,amiao,afen,ashi;
uchar code table[]=" 20  -  -       "; //液晶固定顯示內容
uchar code table1[]="      :  :      ";         //
void write_ds(uchar,uchar);
void set_alarm(uchar,uchar,uchar);
void read_alarm();
uchar read_ds(uchar);
void set_time();
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void di()
beep=0;
delay(100);
beep=1;
void write_com(uchar com)           //寫液晶命令函數
rs=0;
lcden=0;
P0=com;
delay(3);
lcden=1;
delay(3);
lcden=0;
#include <REGX51.H>
void write_date(uchar date)           //寫液晶數據函數
rs=1;
lcden=0;
P0=date;
delay(3);
lcden=1;
delay(3);
lcden=0;
void init()
uchar num;
EA=1;
EX1=1;
IT1=1;
flag1=0;
t0_num=0;
s1num=0;
week=1;
lcden=0;
rw=0;
rd=0;
write_ds(0x0A,0x20);
write_ds(0x0B,0x26);
set_time();
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<15;num++)
  write_date(table[num]);
  delay(1);
write_com(0x80+0x40);
for(num=0;num<11;num++)
  write_date(table1[num]);
  delay(1);
void write_sfm(uchar add,char date)//1602刷新時分秒函數4為時,7為分,10為妙
char shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void write_nyr(uchar add,char date)//1602刷新時分秒函數3為年,6為分,9為妙
char shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+add);
void write_week(char we)   //寫液晶顯示函數
write_com(0x80+12);
switch(we)
  case 1: write_date('M');delay(5);
                  write_date('O');delay(5);
                  write_date('N');
                  break;
  case 2: write_date('T');delay(5);
                  write_date('U');delay(5);
                  write_date('E');
                  break;
  case 3: write_date('W');delay(5);
                  write_date('E');delay(5);
                  write_date('D');
                  break;
  case 4: write_date('T');delay(5);
                  write_date('H');delay(5);
                  write_date('U');
                  break;
  case 5: write_date('F');delay(5);
                  write_date('R');delay(5);
                  write_date('I');
                  break;
  case 6: write_date('S');delay(5);
                  write_date('A');delay(5);
                  write_date('T');
                  break;
  case 7: write_date('S');delay(5);
                  write_date('N');
                  break;
void keyscan()
if(flag_ri==1)
  if((s1==0)||(s2==0)||(s3==0)||(s4==0))
   delay(5);
        while(!(s1&&s2&&s3&&s4));
        di();
        flag_ri=0;
if(s1==0)
  delay(5);
  if(s1==0)
   s1num++;
   if(flag1==1)
    if(s1num==4)
         s1num=1;
   flag=1;
   while(!s1);
   di();
   switch(s1num)
    case 1:        write_com(0x80+0x40+10);
                write_com(0xf0);
                        break;
        case 2:        write_com(0x80+0x40+7);
                        break;
        case 3:        write_com(0x80+0x40+4);
                        break;
        case 4:        write_com(0x80+12);
                        break;
        case 5:        write_com(0x80+9);
                        break;
        case 6:        write_com(0x80+6);
                        break;
        case 7:        write_com(0x80+3);
                        break;
        case 8:        s1num=0;
                     write_com(0x0c);
                        flag=0;
                        write_ds(0,miao);
                        write_ds(2,fen);
                        write_ds(4,shi);
                        write_ds(6,week);
                        write_ds(7,day);
                        write_ds(8,month);
                        write_ds(9,year);
                        break;
if(s1num!=0)
  if(s2==0)
   delay(1);
   if(s2==0)
        while(!s2);
        di();
        switch(s1num)        //根據功能鍵次數調節相應數值
         case 1: miao++;
                 if(miao==60)
                          miao=0;
                         write_sfm(10,miao);
                         break;
         case 2: fen++;
                 if(fen==60)
                          fen=0;
                         write_sfm(7,fen);
                         break;
         case 3: shi++;
                 if(shi==24)
                          shi=0;
                         write_sfm(4,shi);
                         break;
         case 4: week++;
                 if(week==8)
                          week=1;
                         write_week(week);
                         write_com(0x80+12);
                         break;
         case 5: day++;
                 if(day==32)
                          day=1;
                         write_nyr(6,month);
                         write_com(0x80+9);
                         break;
         case 6: month++;
                 if(month==13)
                          month=1;
                         write_nyr(6,month);
                         write_com(0x80+6);
                         break;
         case 7: year++;
                 if(year==100)
                          year=0;
                         write_nyr(3,year);
                         write_com(0x80+3);
                         break;
  if(s3==0)
   delay(1);
   if(s3==0)
        while(!s3);
        di();
        switch(s1num)
         case 1: miao--;
                 if(miao==-1)
                          miao=59;
                         write_sfm(10,miao);
                         break;
         case 2: fen--;
                 if(fen==-1)
                          fen=59;
                         write_sfm(7,fen);
                         break;
         case 3: shi--;
                 if(shi==1)
                          shi=23;
                         write_sfm(4,shi);
                         break;
         case 4: week--;
                 if(week==0)
                          week=7;
                         write_week(week);
                         write_com(0x80+12);
                         break;
         case 5: day--;
                 if(day==0)
                          day=31;
                         write_nyr(6,month);
                         write_com(0x80+9);
                         break;
         case 6: month--;
                 if(month==0)
                          month=12;
                         write_nyr(6,month);
                         write_com(0x80+6);
                         break;
         case 7: year--;
                 if(year==-1)
                          year=99;
                         write_nyr(3,year);
                         write_com(0x80+3);
                         break;
if(s4==0)
  delay(5);
  if(s4==0)
   flag1=~flag1;
   while(!s4);
   di();
   if(flag1==0)
        flag=0;
        write_date(' ');
    write_date(' ');
        write_com(0x0c);
        write_ds(1,miao);
        write_ds(3,fen);
        write_ds(5,shi);
        read_alarm();
        miao=amiao;
        fen=afen;
        shi=ashi;
        write_date('R');
        write_date('i');
        write_com(0x80+0x40+3);
        write_sfm(4,ashi);
        write_sfm(7,afen);
    write_sfm(10,amiao);
void write_ds(uchar add,uchar date)
dscs=0;
dsas=1;
dsds=1;
dsrw=1;
P0=add;
dsas=0;
dsrw=0;
P0=date;
dsrw=1;
dsas=1;
dscs=1;
uchar read_ds(uchar add)
uchar ds_date;
dsas=1;
dsds=1;
dsrw=1;
dscs=0;
P0=add;
dsas=0;
dsds=0;
P0=0xff;
ds_date=P0;
dsds=1;
dsas=1;
dscs=1;
return ds_date;
void set_time()
write_ds(0,0);
write_ds(1,0);
write_ds(2,0);
write_ds(3,0);
write_ds(4,0);
write_ds(5,0);
write_ds(6,0);
write_ds(7,0);
write_ds(8,0);
write_ds(9,0);
void read_alarm()
amiao=read_ds(1);
afen=read_ds(3);
ashi=read_ds(5);
init();
  keyscan();
  if(flag_ri==1)
   di();
   delay(100);
   di();
   delay(500);
  if(flag==0&&flag1==0)
   keyscan();
   year=read_ds(9);
   month=read_ds(8);
   day=read_ds(7);
   shi=read_ds(6);
   fen=read_ds(4);
   miao=read_ds(2);
   write_sfm(10,miao);
   write_sfm(7,fen);
   write_sfm(4,shi);
   write_week(week);
   write_nyr(3,year);
   write_nyr(6,month);
   write_nyr(9,day);
void exter() interrupt 2
uchar c;
flag_ri=1;
c=read_ds(0x0c);
