查看: 1358|回復: 0
51單片機A-F動態數碼管源程序
仿真程序:
  1. #include<reg51.h>
  2. #define uint unsigned int
  4. uchar code table[]={0x77,0x7c,0x39,0x5e,0x79,0x71};
  5. uchar code table1[]={0x7c,0x39,0x5e,0x79,0x71,0x76};
  6. uchar code table2[]={0x39,0x5e,0x79,0x71,0x76,0x38};
  7. uchar code table3[]={0x5e,0x79,0x71,0x76,0x38,0x73};
  8. uchar code table4[]={0x79,0x71,0x76,0x38,0x73,0x77};
  9. uchar code table5[]={0x71,0x76,0x38,0x73,0x77,0x7c};
  10. uchar code table6[]={0x76,0x38,0x73,0x77,0x7c,0x39};
  11. uchar code table7[]={0x38,0x73,0x77,0x7c,0x39,0x5e};
  12. uchar code table8[]={0x73,0x77,0x7c,0x39,0x5e,0x79};
  13. void delay(uint);
  14. void main()
  15.   {
  16.   uchar i,wei,k;
  17.   while(1)
  18.   {
  19.   for(k=0;k<20;k++)
  20.   {
  21.   wei=0xfe;
  22.   for(i=0;i<7;i++)
  23.   {
  24.         P3=0xff;
  25.         P2=table[i];
  26.         P3=wei;
  27.         wei=(wei<<1)|0x01;
  28.         delay(5);
  29.         }
  30.         }
  31. for(k=0;k<20;k++)
  32.   {
  33.   wei=0xfe;
  34.   for(i=0;i<7;i++)
  35.   {
  36.         P3=0xff;
  37.         P2=table1[i];
  38.         P3=wei;
  39.         wei=(wei<<1)|0x01;
  40.         delay(5);
  41.         }
  42.         }
  43. for(k=0;k<20;k++)
  44.   {
  45.   wei=0xfe;
  46.   for(i=0;i<7;i++)
  47.   {
  48.         P3=0xff;
  49.         P2=table2[i];
  50.         P3=wei;
  51.         wei=(wei<<1)|0x01;
  52.         delay(5);
  53.         }
  54.         }
  55. for(k=0;k<20;k++)
  56.   {
  57.   wei=0xfe;
  58.   for(i=0;i<7;i++)
  59.   {
  60.         P3=0xff;
  61.         P2=table3[i];
  62.         P3=wei;
  63.         wei=(wei<<1)|0x01;
  64.         delay(5);
  65.         }
  66.         }
  67. for(k=0;k<20;k++)
  68.   {
  69.   wei=0xfe;
  70.   for(i=0;i<7;i++)
  71.   {
  72.         P3=0xff;
  73.         P2=table4[i];
  74.         P3=wei;
  75.         wei=(wei<<1)|0x01;
  76.         delay(5);
  77.         }
  78.         }
  79. for(k=0;k<20;k++)
  80.   {
  81.   wei=0xfe;
  82.   for(i=0;i<7;i++)
  83.   {
  84.         P3=0xff;
  85.         P2=table5[i];
  86.         P3=wei;
  87.         wei=(wei<<1)|0x01;
  88.         delay(5);
  89.         }
  90.         }
  91. for(k=0;k<20;k++)
  92.   {
  93.   wei=0xfe;
  94.   for(i=0;i<7;i++)
  95.   {
  96.         P3=0xff;
  97.         P2=table6[i];
  98.         P3=wei;
  99.         wei=(wei<<1)|0x01;
  100.         delay(5);
  101.         }
  102.         }
  103. for(k=0;k<20;k++)
  104.   {
  105.   wei=0xfe;
  106.   for(i=0;i<7;i++)
  107.   {
  108.         P3=0xff;
  109.         P2=table7[i];
  110.         P3=wei;
  111.         wei=(wei<<1)|0x01;
  112.         delay(5);
  113.         }
  114.         }
  115. for(k=0;k<20;k++)
  116.   {
  117.   wei=0xfe;
  118.   for(i=0;i<7;i++)
  119.   {
  120.         P3=0xff;
  121.         P2=table8[i];
  122.         P3=wei;
  123.         wei=(wei<<1)|0x01;
  124.         delay(5);
  125.         }
  126.         }
  127.         }
  128.         }
  129.
  130. void delay(uint z)
  131. {
  132.     uint x,y;
  133.     for(x=z;x>0;x--)
  134.           for(y=110;y>0;y--);
  135.           }
單片機動態數碼A-P.zip
40.71 KB, 下載次數: 3, 下載積分: 黑幣 -5
仿真圖,程序
