查看: 2812|回復(fù): 0
單片機(jī)計(jì)算器 可以實(shí)現(xiàn)加減乘除,以及常見進(jìn)制轉(zhuǎn)換
ID:600240 發(fā)表于 2019-12-14 10:48 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<stdio.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
sbit rs=P2^0;
sbit rw=P2^1;
sbit e=P2^2;
sbit K2=P3^6;
sbit K1=P3^7;
uint8 key,num;
uint8 fuhao;//定義具體的那個(gè)符號(hào),是加減還是乘除。
uint8 flag;        //定義有沒有按下符號(hào)鍵,這個(gè)是統(tǒng)稱
long a,b,c,d;        //定義運(yùn)算數(shù)據(jù)的第一個(gè)和第二個(gè)及等于的數(shù)變量
uint8 k; //定義小數(shù)點(diǎn)后面顯示的位數(shù)
uint8 biao;
uint8 dat1[]={1,2,3,0x2b-0x30, 4,5,6,0x2d-0x30, 7,8,9,0x2a-0x30, 0,0x01-0x30,0x3d-0x30,0x2b-0x30 };//保存顯示的數(shù)據(jù)
void delay(uint16 i)
        while(i--);
void lcdwrc(uint8 c)
        delay(1000);
        rs=0;
        rw=0;
        e=0;
        P0=c;
        e=1;
        delay(1000);
        e=0;
void lcdwrd(uint8 dat)
        delay(1000);
        rs=1;
        rw=0;
        e=0;
        P0=dat;
        e=1;
        delay(1000);
        e=0;
        rs=0;
void lcdinit()
        delay(1500);
        lcdwrc(0x38);
        delay(500);
        lcdwrc(0x38);
        delay(500);
        lcdwrc(0x38);
        delay(500);
        lcdwrc(0x38);
        lcdwrc(0x08);
        lcdwrc(0x01);
        lcdwrc(0x06);
        lcdwrc(0x0c);
        key=0;
        num=0;
        flag=0;
        fuhao=0;
        a=0;
        b=0;
        c=0;
        d=0;
        biao=0;
void keyscan()
        P1=0xfe;   //令第一行為0,然后判斷是哪一列按下
        if(P1!=0xfe)
                delay(1000);
                if(P1!=0xfe)
                        key=P1&0xf0;
                        switch(key)
                                case 0xe0: num=0;break;          //1
                                case 0xd0: num=1;break;          //2
                                case 0xb0: num=2;break;          //3
                                case 0x70: num=3;break;          //加
                while(P1!=0xfe);
                if(num==0||num==1||num==2)         //確認(rèn)第一行的數(shù)1,2,3
                        if(flag==0)         //沒有按下符號(hào)鍵
                                //led=1;
                                a=a*10+dat1[num];
                                //led=1;
                                b=b*10+dat1[num];
                if(num==3)
                        //led=0;
                        flag=1;
                        fuhao=1;//加號(hào)+
                lcdwrd(0x30+dat1[num]);
        P1=0xfd;                                //令第二行為0,判斷是哪一列按下
        if(P1!=0xfd)
                delay(1000);
                if(P1!=0xfd)
                        key=P1&0xf0;
                        switch(key)
                                case 0xe0: num=4;break;          //4
                                case 0xd0: num=5;break;          //5
                                case 0xb0: num=6;break;          //6
                                case 0x70: num=7;break;          //減—
                while(P1!=0xfd);
                if(num==4||num==5||num==6)
                                //led=1;
                                a=a*10+dat1[num];
                                //led=1;
                                b=b*10+dat1[num];
                        flag=1;
                        fuhao=2;//帶表減號(hào)
        P1=0xfb;                 //令第三行為0,判斷哪一列按下
        if(P1!=0xfb)
                delay(1000);
                if(P1!=0xfb)
                        key=P1&0xf0;
                        switch(key)
                                case 0xe0: num=8;break;          //7
                                case 0xd0: num=9;break;          //8
                                case 0xb0: num=10;break;  //9
                                case 0x70: num=11;break;  //乘*
                while(P1!=0xfb);
                if(num==8||num==9||num==10)
                                //led=1;
                                a=a*10+dat1[num];
                                //led=1;
                                b=b*10+dat1[num];
                        flag=1;
                        fuhao=3;//帶表乘號(hào)*
        P1=0xf7;                 //令第四行為0,判斷哪一列按下
        if(P1!=0xf7)
                delay(1000);
                if(P1!=0xf7)
                        key=P1&0xf0;
                        switch(key)
                                case 0xe0: num=12;break;  //0
                                case 0xd0: num=13;break;  //清除rst
                                case 0xb0: num=14;break;  //等號(hào)=
                                case 0x70: num=15;break;  //除/
                while(P1!=0xf7);
                switch(num)
                        case 12:
                                                //led=1;
                                                a=a*10+dat1[num];
                                                lcdwrd(0x30);
                                                //led=1;
                                                b=b*10+dat1[num];
                                                lcdwrd(0x30);
                                        break;
                        case 13:
                                        lcdwrc(0x01);        //清屏指令
                                        a=0;
                                        b=0;
                                        flag=0;
                                        fuhao=0;
                                        break;
                        case 15:
                                        flag=1;
                                        fuhao=4;
                                        lcdwrd(0x2f);//除號(hào)/
                                        break;
                        case 14:
                                        if(fuhao==1)//加
                                                lcdwrc(0x4f+0x80);
                                                lcdwrc(0x04);//設(shè)置光標(biāo)左移,屏幕不移動(dòng)
                                                c=a+b;
                                                if(c<99999999)
                                                        while(c!=0)         //一位一位顯示
        lcdwrd(0x30+c%10);//顯示結(jié)果的最后一位在0x4f的位置
        c=c/10;//取前面的結(jié)果數(shù)據(jù)
                                                        lcdwrd(0x3d); //顯示等于號(hào)=
                                                        lcdwrd('!');
                                                        lcdwrd('R');
                                                        lcdwrd('O');
                                                        lcdwrd('R');
                                                        lcdwrd('R');
                                                        lcdwrd('E');
                                                a=0;
                                                b=0;
                                                flag=0;
                                                fuhao=0;//全部清除為0
                                        if(fuhao==2)   //減
                                                lcdwrc(0x4f+0x80);
                                                if(a>b)
                                                        c=a-b;
                                                        c=b-a;
                                                if(a<b)        lcdwrd(0x2d); //顯示-號(hào)
                                                a=0;
                                                b=0;
                                                flag=0;
                                                fuhao=0;//全部清除為0
                                        if(fuhao==3)//乘法
                                                lcdwrc(0x4f+0x80);
                                                c=a*b;
                                                if(c<99999999)
                                                        lcdwrd('!');
                                                        lcdwrd('R');
                                                        lcdwrd('O');
                                                        lcdwrd('R');
                                                        lcdwrd('R');
                                                        lcdwrd('E');
                                                a=0;
                                                b=0;
                                                flag=0;
                                                fuhao=0;//全部清除為0
                                        if(fuhao==4)
                                                k=0;
                                                lcdwrc(0x4f+0x80);
                                                c=(long)(((float)a/b)*1000);//強(qiáng)制轉(zhuǎn)換為long。
                                                        k++;
                                                        if(k==3)
        lcdwrd(0x2e);
        k=0;
                                                if(a/b<0)          //如果a比b小的話那么除的結(jié)果最高位是0
                                                        lcdwrd(0x30);
                                                lcdwrd(0x3d); //顯示等號(hào)
                                                a=0;
                                                b=0;
                                                flag=0;
                                                fuhao=0;//全部清除為0
                                        break;
    int n=0,j=0,m=0,l=0;
        lcdinit();
                keyscan();
                         if((K2==0)&&(flag==0)&&(a!=0))
                        lcdwrc(0x4f+0x80);
                        c=a;
                                lcdwrd(0x30+c%2);//顯示結(jié)果的最后一位在0x4f的位置
                                c=c/2;//取前面的結(jié)果數(shù)據(jù)
                                                //顯示結(jié)果的最后一位在0x4f的位置//取前面的結(jié)果數(shù)據(jù)
                        a=0;
                        b=0;
                        flag=0;
                        fuhao=0;//全部清除為0
                if((K1==0)&&(flag==0)&&(a!=0))
                        lcdwrc(0x4f+0x80);
                        c=a;
                        {m=c&0x01;
                         j=l;
                        while(j)
                        m=m*2;
                        j--;
                        n=n+m;
                        if(l==3)
                        while(n!=0)
            lcdwrd(0x30+n%10);
                         n=n/10;
                        c=c>>2;
                        l++;
                        a=0;
                        b=0;
                        flag=0;
                        fuhao=0;//全部清除為0
程序.zip
71.06 KB, 下載次數(shù): 33, 下載積分: 黑幣 -5
