查看: 2828|回復: 1
stm32通過tim定時器中斷,進行周期性任務
ID:663293 發表于 2019-12-13 15:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//下面是定時器TIM3_CH3的初始化,如果需要更換或添加TIM的其他通道,直接修改管腳和下面的注釋即可
void TIM3_Cap_Init(u16 arr,u16 psc)
    NVIC_InitTypeDef NVIC_InitStructure;
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    TIM_OCInitTypeDef TIM_OCInitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //使能 TIM3 時鐘
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能 GPIOB 時鐘
    //TIM3_CH3-->PB0
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
      GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
      GPIO_Init(GPIOB , &GPIO_InitStructure);
/* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 65535;         //這里必須是65535
  TIM_TimeBaseStructure.TIM_Prescaler = 71;            //72(71+1)分頻,也就是1MHz(主頻72MHz)
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;      //
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上計數模式
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);          //初始化TIM3
  /* Output Compare Toggle Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;    //輸出比較翻轉模式,產生中斷后,輸出管腳電平翻轉,可設置成其他模式,百度一下就好
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;         //輸出為負邏輯
  /*TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;   //使能通道1
  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;                       //待裝入輸出比較寄存器中的脈沖值,也就是計時器達到多少后產生中斷
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);        //寫入配置
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Disable);*/          //使能或者失能TIMx在CCR1上的預裝載寄存器
  /* Output Compare Toggle Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
  TIM_OC2Init(TIM3, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Disable);*/
  /* Output Compare Toggle Mode configuration: Channel3 */
  TIM_OCInitStructure.TIM_Pulse = PPM_IN[ppm_i];
  TIM_OC3Init(TIM3, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Disable);
  /* Output Compare Toggle Mode configuration: Channel4 */
  TIM_OCInitStructure.TIM_Pulse = CCR4_Val;
  TIM_OC4Init(TIM3, &TIM_OCInitStructure);
  TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Disable);*/
    //中斷分組初始化
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3 中斷
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //先占優先級 2 級
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //從優先級 0 級
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ 通道被使能
NVIC_Init(&NVIC_InitStructure); //初始化外設 NVIC 寄存器
TIM_ITConfig(TIM3,TIM_IT_CC3,ENABLE);
  /* TIM enable counter */
  TIM_Cmd(TIM3, ENABLE);      //開啟計數器
  /* TIM IT enable */                //TIM1中斷源設置,開啟相應通道的捕捉比較中斷
  //TIM_ITConfig(TIM3, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 | TIM_IT_CC4, ENABLE);
    //TIM_ITConfig(TIM3, TIM_IT_CC3, ENABLE);
//定時器 3 中斷服務程序
void TIM3_IRQHandler(void)
    /*if (TIM_GetITStatus(TIM3, TIM_IT_CC3) != RESET)      //檢查指定的TIM(3通道)中斷發生與否
    TIM_ClearITPendingBit(TIM3, TIM_IT_CC3 );          //清除TIMx的中斷待處理位
    capture = TIM_GetCapture3(TIM3);                   //獲得輸入捕獲值,即計數器中的計數值
    TIM_SetCompare3(TIM3, capture + 500 );        //將計數值加上翻轉的脈沖值寫入輸出比較寄存器中,以保證下一個TIM事件,可以實現周期性產生中斷
     if (TIM_GetITStatus(TIM3, TIM_IT_CC3) != RESET)//(tim3,3通道),這部分是我工程中用到的,也可以改成上面的內容,實現周期性中斷
  {    //outdata();
    TIM_ClearITPendingBit(TIM3, TIM_IT_CC3);
        if(ppm_i==nPPM*2+1){
            ppm_i=0;
        }else{
            ppm_i++;
    TIM_SetCompare3(TIM3, capture + PPM_IN[ppm_i]);
APP.zip
1.92 KB, 下載次數: 10, 下載積分: 黑幣 -5
收藏收藏3 分享淘帖 頂 踩
ID:663370 發表于 2019-12-13 16:51 | 只看該作者
感謝,對我幫助很大,挺你
