有沒(méi)有大佬能不能幫我把這個(gè)接地才能用的矩陣按鍵改成上拉電阻可用的!
單片機(jī)源程序如下:
- #include "key4_4.h"
- #include "delay.h"
- #include "sys.h"
- //平臺(tái):STM32F103
- //實(shí)驗(yàn)名稱(chēng):不連續(xù)I/O矩陣鍵盤(pán)實(shí)驗(yàn)
- //Author:GXNU_LPK_20512700***
- //使用說(shuō)明:矩陣鍵盤(pán)所用引腳都已經(jīng)用宏定義定義好了,移植只需根據(jù)實(shí)際需要在key4_4.c中修改對(duì)應(yīng)的時(shí)鐘、引腳和端口即可,其余都不用修改。
- //矩陣鍵盤(pán)所用的8個(gè)引腳可連續(xù)可不連續(xù),看實(shí)際需要和個(gè)人愛(ài)好自己定義。
- int main(void)
- uart_init(9600);
- Key_Init();
- delay_init();
- printf("不連續(xù)I/O口矩陣鍵盤(pán)測(cè)試\r\n");
- while(1)
- Key_Test();
復(fù)制代碼- #include "key4_4.h"
- #include "sys.h"
- //8個(gè)引腳 4個(gè)為行 4個(gè)為列
- //行輸出端口定義
- #define X1_GPIO_PORT GPIOA
- #define X2_GPIO_PORT GPIOA
- #define X3_GPIO_PORT GPIOA
- #define X4_GPIO_PORT GPIOB
- //列輸入端口定義
- #define Y1_GPIO_PORT GPIOB
- #define Y2_GPIO_PORT GPIOB
- #define Y3_GPIO_PORT GPIOB
- #define Y4_GPIO_PORT GPIOB
- //行輸出引腳定義
- #define X1_GPIO_PIN GPIO_Pin_11
- #define X2_GPIO_PIN GPIO_Pin_12
- #define X3_GPIO_PIN GPIO_Pin_15
- #define X4_GPIO_PIN GPIO_Pin_3
- //列輸入引腳定義
- #define Y1_GPIO_PIN GPIO_Pin_4
- #define Y2_GPIO_PIN GPIO_Pin_5
- #define Y3_GPIO_PIN GPIO_Pin_6
- #define Y4_GPIO_PIN GPIO_Pin_7
- //行輸出時(shí)鐘定義
- #define X1_RCC RCC_APB2Periph_GPIOA
- #define X2_RCC RCC_APB2Periph_GPIOA
- #define X3_RCC RCC_APB2Periph_GPIOA
- #define X4_RCC RCC_APB2Periph_GPIOB
- //列輸入時(shí)鐘定義
- #define Y1_RCC RCC_APB2Periph_GPIOB
- #define Y2_RCC RCC_APB2Periph_GPIOB
- #define Y3_RCC RCC_APB2Periph_GPIOB
- #define Y4_RCC RCC_APB2Periph_GPIOB
- //移植代碼只需要修改上面的端口和引腳和時(shí)鐘即可,下面的代碼不用修改。
- unsigned char Y1,Y2,Y3,Y4;
- void Key_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(X1_RCC|X2_RCC|X3_RCC|X4_RCC|Y1_RCC|Y2_RCC|Y3_RCC|Y4_RCC|RCC_APB2Periph_AFIO, ENABLE);
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
- /*****************************4行輸出*********************************************/
- GPIO_InitStructure.GPIO_Pin = X1_GPIO_PIN ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(X1_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = X2_GPIO_PIN ;
- GPIO_Init(X2_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = X3_GPIO_PIN ;
- GPIO_Init(X3_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = X4_GPIO_PIN ;
- GPIO_Init(X4_GPIO_PORT, &GPIO_InitStructure);
- /**************************************4列輸入*************************************/
- GPIO_InitStructure.GPIO_Pin = Y1_GPIO_PIN ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
- GPIO_Init(Y1_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = Y2_GPIO_PIN ;
- GPIO_Init(Y2_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = Y3_GPIO_PIN ;
- GPIO_Init(Y3_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = Y4_GPIO_PIN;
- GPIO_Init(Y4_GPIO_PORT, &GPIO_InitStructure);
- int Key_Scan(void)
- uchar KeyVal;
- GPIO_SetBits(X1_GPIO_PORT,X1_GPIO_PIN); //先讓X1輸出高
- GPIO_SetBits(X2_GPIO_PORT,X2_GPIO_PIN); //先讓X2輸出高
- GPIO_SetBits(X3_GPIO_PORT,X3_GPIO_PIN); //先讓X3輸出高
- GPIO_SetBits(X4_GPIO_PORT,X4_GPIO_PIN); //先讓X4輸出高
- if((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN)|GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN)|GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN)|GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))==0x0000)
- return -1; //如果X1到X4全為零則沒(méi)有按鍵按下
- else
- delay_ms(5); //延時(shí)5ms去抖動(dòng)
- return -1;
- GPIO_ResetBits(X1_GPIO_PORT,X1_GPIO_PIN);
- GPIO_ResetBits(X2_GPIO_PORT,X2_GPIO_PIN);
- GPIO_ResetBits(X3_GPIO_PORT,X3_GPIO_PIN);
- Y1=GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN);Y2=GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN);
- Y3=GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN);Y4=GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN);
- if(Y1==1&&Y2==0&&Y3==0&&Y4==0)
- KeyVal='*';
- if(Y1==0&&Y2==1&&Y3==0&&Y4==0)
- KeyVal=0;
- if(Y1==0&&Y2==0&&Y3==0&&Y4==1)
- KeyVal='D';
- if(Y1==0&&Y2==0&&Y3==1&&Y4==0)
- KeyVal='#';
- while(((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN))|(GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN))|(GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN))|(GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))) > 0);
- //等待按鍵釋放
- GPIO_ResetBits(X4_GPIO_PORT,X4_GPIO_PIN);
- KeyVal=1;
- KeyVal=2;
- KeyVal=3;
- KeyVal='A';
- KeyVal=4;
- KeyVal=5;
- KeyVal=6;
- KeyVal='B';
- KeyVal=7;
- KeyVal=8;
- KeyVal=9;
- KeyVal='C';
- return KeyVal;
- 按鍵表盤(pán)為: 1 2 3 A
- 4 5 6 B
- 7 8 9 C
- * 0 # D
- void Key_Test(void)
- int num;
- num = Key_Scan();
- switch(num)
- case 0: printf("0\n"); break;
- case 1: printf("1\n"); break;
- case 2: printf("2\n"); break;
- case 3: printf("3\n"); break;
- case 4: printf("4\n"); break;
- case 5: printf("5\n"); break;
- case 6: printf("6\n"); break;
- case 7: printf("7\n"); break;
- case 8: printf("8\n"); break;
- case 9: printf("9\n"); break;
- case 'A': printf("A\n"); break;
- case 'B': printf("B\n"); break;
- case 'C': printf("C\n"); break;
- case 'D': printf("D\n"); break;
- case '#': printf("#\n"); break;
- case '*': printf("*\n"); break;
可移植的不連續(xù)IO口矩陣鍵盤(pán)(接地).7z
(214.93 KB, 下載次數(shù): 8)
2019-12-13 08:55 上傳
點(diǎn)擊文件名下載附件
