查看: 2466|回復: 0
藍牙串口助手調試藍牙模塊控制led燈不亮
ID:136379 發表于 2019-12-11 21:06 | 顯示全部樓層 |閱讀模式
我用藍牙串口助手輸入1,2,3,4和其他字符都是執行default里的語句,大哥們,幫忙給看看。
#include"reg52.h"
sbit led1=P2^0;
sbit led2=P2^1;
sbit led3=P2^2;
sbit led4=P2^3;
sbit led5=P2^4;
sbit led6=P2^7;
uchar tmp;
void xingtai1()
         led1=0;
         led2=1;
         led3=1;
         led4=1;
void xingtai2()
         led1=1;
         led2=0;
         led3=1;
         led4=1;
void xingtai3()
         led1=1;
         led2=1;
         led3=0;
         led4=1;
void xingtai4()
         led1=1;
         led2=1;
         led3=1;
         led4=0;
void init()
                                TMOD = 0x20;
                                PCON = 0x00;
                                SCON = 0x50;
                                TH1 = 0xFd; //設置波特率 9600
                                TL1 = 0xFd;
                                TR1 = 1; //啟動定時器1
                                ES = 1; //開串口中斷
                                EA = 1; //開總中斷
        led6=0;
        init();
                        if(RI)                                                // 是否有數據到來
                                RI = 0;
                                // 暫存接收到的數據
                                switch(SBUF)
                                        case '1': xingtai1();break;
                                        case '2': xingtai2();break;
                                        case '3': xingtai3();break;
                                        case '4':  led1=0;
        led2=0;
        led3=0;break;
                                        default:         led1=0;
        led2=0;
        led3=0;
        led4=0;
        led5=0;
