只需一步,快速開(kāi)始
查看: 3067|回復(fù): 4
為何我的單片機(jī)矩陣鍵盤(pán)不論按那個(gè)鍵12864都只是顯示1
ID:653709 發(fā)表于 2019-12-9 19:12 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
200黑幣
#include "reg52.h"                         //此文件中定義了單片機(jī)的一些特殊功能寄存器
#include"intrins.h"
#define GPIO_KEY P1
#define lcd_data P0         //數(shù)據(jù)口
sbit lcd_psb = P3^2; //串/并口選擇
sbit lcd_rw = P2^5;         //讀寫(xiě)控制
sbit lcd_rs = P2^6;  //寄存器選擇  0為指令  1為數(shù)據(jù)
sbit lcd_EN = P2^7;  //lcd使能信號(hào)(并口)
void lcd_wcmd(uchar cmd);
void delay(int ms);
void DisplayDdram(uchar *hz);
void lcd_wdata(uint dat);
uchar KeyValue;        //用來(lái)存放讀取到的鍵值
void delay(int ms)
    while(ms--)
uchar i;
          for(i=0;i<250;i++)
            _nop_();
                _nop_();
                _nop_();
                _nop_();
bit lcd_busy()
    bit result;
    P0=0X00;              //關(guān)掉數(shù)碼管的信號(hào)。阻止數(shù)碼管受到P0口信號(hào)的影響
lcd_rs = 0;
lcd_rw = 1;
lcd_EN = 1;
delay(1);
    result = (bit)(P0&0x80);
lcd_EN = 0;
    return(result);
void lcd_init(void)
        lcd_psb = 1;                //并口方式
        lcd_wcmd(0x34);                 //擴(kuò)展指令
        delay(5);
        lcd_wcmd(0x30);                //基本指令
        delay(5);
        lcd_wcmd(0x0c);                 //顯示光標(biāo)開(kāi)關(guān)
        delay(5);
        lcd_wcmd(0x01);                 //清除lcd的顯示內(nèi)容
        delay(5);
        while(lcd_busy());
        lcd_rs = 0;
        lcd_rw = 0;
        lcd_EN = 0;
        lcd_data=cmd;
        delay(1);
        lcd_EN = 1;
        delay(1);
        lcd_EN = 0;
        while(*hz!= '\0')
                lcd_wdata(*hz);//地址里面的值
                hz++;
        while(lcd_busy());
        lcd_rs = 1;
        lcd_rw = 0;
        lcd_EN = 0;
        lcd_data = dat;
        delay(1);
        lcd_EN = 1;
        delay(1);
        lcd_EN = 0;
void lcd_pos(uchar x,uchar y)
        uchar pos;
        if(x==0)
                x = 0x80;
        }else if(x==1)
                x= 0x90;
        }else if(x==2)
                x = 0x88;
        }else if(x==3)
                x = 0x98;
        pos = x + y;
        lcd_wcmd(pos);
uchar KeyDown()
        GPIO_KEY=0x0f;
        if(GPIO_KEY!=0x0f)//讀取按鍵是否按下
                delay(10);//延時(shí)10ms進(jìn)行消抖
                if(GPIO_KEY!=0x0f)//再次檢測(cè)鍵盤(pán)是否按下
                        //測(cè)試列
                        GPIO_KEY=0X0f;
                        switch(GPIO_KEY)
                                case(0X07):KeyValue=0;break;
                                case(0X0b):KeyValue=1;break;
                                case(0X0d):KeyValue=2;break;
                                case(0X0e):KeyValue=3;break;
                        //測(cè)試行
                        GPIO_KEY=0Xf0;
                        switch(GPIO_KEY)
                                case(0X70):KeyValue=KeyValue;break;
                                case(0Xb0):KeyValue=KeyValue+4;break;
                                case(0Xd0): KeyValue=KeyValue+8;break;
                                case(0Xe0):KeyValue=KeyValue+12;break;
                    return KeyValue;
    uchar q;
   lcd_init();
     q=KeyDown();                   //按鍵判斷函數(shù)
        lcd_pos(2,1);
switch(q)
case 0:DisplayDdram("1");break;
case 1:DisplayDdram("2");break;
case 2:DisplayDdram("3");break;
case 3:DisplayDdram("4");break;
case 4:DisplayDdram("5");break;
case 5:DisplayDdram("6");break;
case 6:DisplayDdram("7");break;
case 7:DisplayDdram("8");break;
case 8:DisplayDdram("9");break;
case 9:DisplayDdram("10");break;
case 10:DisplayDdram("11");break;
case 11:DisplayDdram("12");break;
        delay(1000);
        lcd_wcmd(0x01);
最佳答案
查看完整內(nèi)容
更據(jù)你的程序改了一下 親測(cè)可用。使用時(shí)把后綴名rar改成.c或者txt
ID:90663 發(fā)表于 2019-12-9 19:12 | 只看該作者
main.rar
3.91 KB, 下載次數(shù): 13
評(píng)分
參與人數(shù) 1黑幣 +60 收起 理由
admin + 60 回帖助人的獎(jiǎng)勵(lì)!
查看全部評(píng)分
ID:235200 發(fā)表于 2019-12-9 23:30 | 只看該作者
因?yàn)閟witch(q)的分類(lèi)未包含所有可能出現(xiàn)的情況
ID:213173 發(fā)表于 2019-12-10 07:47 | 只看該作者
顯示單字符用單引號(hào),字符串用雙引號(hào)。
ID:660858 發(fā)表于 2019-12-10 18:54 | 只看該作者
     這個(gè)是我之前實(shí)驗(yàn)做出來(lái)程序
#include<reg52.h>
void delay(unsigned char t);
bit key_certain(void);
*          實(shí)現(xiàn)功能:4×4鍵盤(pán)檢測(cè)
*        現(xiàn)象描述:按下4×4按鍵數(shù)碼管上顯示相應(yīng)的值
*                          K1(0)  K2(1)  K3(2)  K4(3)  K9(8)   K10(9)  K11(A)  K12(B)
*                          K5(4)  K6(5)  K7(6)  K8(7)  K13(C)  K14(D)  K15(E)  K16(F)          *
sbit wei1=P0^7;//位定義數(shù)碼管用到的片選,高電平有效
unsigned char code tab[ ]={0x3f, 0x06, 0x5b, 0x4f,
                                                   0x66, 0x6d, 0x7d, 0x07,
                                               0x7f, 0x6f, 0x77, 0x7c,
                                                   0x39, 0x5e, 0x79, 0x71};//0到F的16個(gè)鍵植
*   名稱(chēng) : Main()        *
void main(void)//主函數(shù)
        unsigned char key, j ,k, s;
                   if(key_certain()== 1)                //確定鍵被按下后,掃描是那個(gè)鍵被按下
                    P2=0xfe;                                //送第一行為低電平
                        k=0xfe;                                        //保留這次掃描數(shù)值,備移位用
                    for(j=0;j<4;j++)                //四次掃描處理
              s=P2&0xf0;                        //屏蔽低四位,取高四位,根據(jù)s數(shù)值確定那一列,根據(jù)掃描的j行確定行數(shù),
                          switch(s)
                                        case 0xe0: key=4*j+0; break;        //第1列
                                            case 0xd0: key=4*j+1; break;        //第2列
                                         case 0xb0: key=4*j+2; break;        //第3列
                                         case 0x70: key=4*j+3; break;        //第4列
                                         default:        break;
                          k=(k<<1)|0x01;                //循環(huán)掃描,
                          P2=k;                                        //每次僅向一行送0掃描
             }//for
                   }//if
                      P1=tab[key];                                //數(shù)據(jù)送數(shù)碼管顯示數(shù)據(jù)口
                wei1=0;                                                        //選中片選
                delay(10);
          }//while
* 名稱(chēng) : delay()
void delay(unsigned char t)//延時(shí)函數(shù)
        unsigned char a;
        while( --t != 0)
                  for(a=0;a<125;a++);
* 名稱(chēng) : 判斷鍵的否被按下,通過(guò)返回值確定
bit key_certain(void)//判斷鍵的否被按下,通過(guò)返回值確定
        P2=0xf0;
        if(P2!=0xf0)
            delay(20);
             if(P2 != 0xf0)//延時(shí)去抖動(dòng),再次確認(rèn)鍵被按下,鍵按下返回值為1,否則為0
                     return 1;
                     return 0;
             return 0;
