查看: 3648|回復: 0
STM32步進電機驅動算法(轉帖)
ID:657909 發表于 2019-12-6 23:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
部分核心代碼
  1. #define ACCELERATED_SPEED_LENGTH  3000    //定義加速度的點數(其實也是3000個細分步的意思),調這個參數改變加速點
  2. #define FRE_MIN 3000     //最低的運行頻率,調這個參數調節最低運行速度
  3. #define FRE_MAX 24000  //最高的運行頻率,調這個參數調節勻速時的最高速度
  4. int step_to_run;  //要運行的步數
  5. float fre[ACCELERATED_SPEED_LENGTH];  //數組存儲加速過程中每一步的頻率
  6. unsigned short period[ACCELERATED_SPEED_LENGTH]; //數組儲存加速過程中每一步定時器的自動裝載值
  7. void CalculateSModelLine(float fre[],  unsigned short period[],   float  len,  float fre_max,  float fre_min, float flexible)
  8. {
  9.     int i=0;
  10.     float deno ;
  11.     float melo ;
  12.     float delt = fre_max-fre_min;
  13.     for(; i<len; i++)
  14.     {
  15.         melo = flexible * (i-len/2) / (len/2);
  16.         deno = 1.0 / (1 + expf(-melo));   //expf is a library function of exponential(e)
  17.         fre[i] = delt * deno + fre_min;
  18.         period[i] = (unsigned short)(1000000.0 / fre[i]);    // 10000000 is the timer driver frequency
  19.     }
  20.    return ;
  21. }
  22. //主函數
  23. int main(void)
  24. {
  25.     u8 t;
  26.     delay_init();
  27.     NVIC_Config();
  28.     LED_Init();    //初始化IO口
  29.       TIM1_Int_Init(10,72); //設置定時器的頻率等
  30.     //PB8 9 12 13
  31.     //KEY_Init();
  32.     //SMG_io_init();
  33.     CalculateSModelLine(fre,period,ACCELERATED_SPEED_LENGTH,FRE_MAX,FRE_MIN,4);
  34.     TIM_Cmd(TIM1, ENABLE);
  35.     while(1)
  36.     {
  37.         }
  38. }
  39. 定時器初始化
  40. void TIM1_Int_Init(u16 arr,u16 psc)
  41. {
  42.     NVIC_InitTypeDef NVIC_InitStructure;
  43.     TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  44.     TIM_OCInitTypeDef  TIM_OCInitStructure;
  45.     TIM_DeInit(TIM1);                                           /*¸′λTIM1¶¨ê±Æ÷*/
  46.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);        /*¿aê±Öó*/
  47.     TIM_TimeBaseStructure.TIM_Period = arr;                     /*ê±ÖóμÎ′eμÄ′Îêy£¬1»êyÖD¶ÏÕaàïêÇ1msÖD¶Ïò»′Î*/
  48.     TIM_TimeBaseStructure.TIM_Prescaler = psc;                /* ·ÖÆμ720*/
  49.     TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  50.     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; /*¼Æêy·½ÏòÏòéϼÆêy*/
  51.     TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  52.     TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  53.        /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  54.     TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  55.     TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  56.     TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable; //2»ê1óÃNμÄêä3ö£¬ËùòÔòa1Øμô
  57.     TIM_OCInitStructure.TIM_Pulse = 0;   //μúò»′ÎûóDêä3öÂö3å
  58.     TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  59.     TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  60.     TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  61.     TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  62.     TIM_OC4Init(TIM1, &TIM_OCInitStructure);
  63.     TIM_OC4PreloadConfig(TIM1, TIM_OCPreload_Enable);
  64.     /* Clear TIM1 update pending flag  Çå3yTIM1òç3öÖD¶Ï±êÖ¾]  */
  65.     TIM_ClearFlag(TIM1, TIM_FLAG_Update);
  66.     NVIC_InitStructure.NVIC_IRQChannel = TIM1_UP_IRQn;          /*òç3öÖD¶Ï*/
  67.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  68.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  69.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  70.     NVIC_Init(&NVIC_InitStructure);
  71.         /* TIM1 counter enable */
  72.         TIM_Cmd(TIM1, DISABLE);
  73.         /* TIM1 Main Output Enable */
  74.         TIM_CtrlPWMOutputs(TIM1, ENABLE);
  75.         TIM_ClearFlag(TIM1, TIM_FLAG_Update);
  76.         TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);
  77. }
  78. //初始化定時器IO
  79. void LED_Init(void)
  80. {
  81.     GPIO_InitTypeDef  GPIO_InitStructure;
  82.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
  83.     //設置PA11為復用推挽輸出
  84.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  85.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  86.     GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_8 | GPIO_Pin_11 | GPIO_Pin_12;
  87.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  88.     //Âö3å¿ú+·½Ïò
  89.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  90.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  91.     GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_5;
  92.     GPIO_Init(GPIOB, &GPIO_InitStructure);
  93.       /* TIM1 Full remapping pins */
  94.     GPIO_PinRemapConfig(GPIO_FullRemap_TIM1, ENABLE);   //打開重映射
  95. }
  96. 定時器更新中斷
  97. int i = 0;
  98. void TIM1_UP_IRQHandler(void)
  99. {
  100.   TIM_ClearFlag(TIM1, TIM_FLAG_Update);
  101.     if(i < ACCELERATED_SPEED_LENGTH && g_motor_dir_s == 0) //加速,直到步數達到 ACCELERATED_SPEED_LENGTH
  102.     {
  103.         TIM1->ARR= period[i];
  104.         TIM1->CCR4= period[i]/2;
  105.         i++;
  106.     step_to_run = 20000;   //這里設置要跑的步數,當然可以寫在main函數中,這里沒有把加減速的步數算上
  107.     }
  108.     else if(step_to_run > 0) //勻速
  109.     {
  110.         step_to_run--;
  111.      }
  112.   else if(i > 0 && g_motor_dir_s == 1)  //電機減速
  113.   {
  114.         i--;
  115.         TIM1->ARR= period[i];
  116.         TIM1->CCR4= period[i]/2;
  117.     }
  118.     if(i == ACCELERATED_SPEED_LENGTH || i == 0)
  119.         {
  120.             g_motor_dir_s = (~g_motor_dir_s)&0x01;
  121.             }
  122. }
