單片機型號STC8A8K64S4A12,字庫芯片W25Q128(用原子戰艦的板子把字庫寫到w25q128里面),OLED是0.96寸SPI接口的。
程序根據原子的OLED實驗和漢字顯示實驗修改的,可以顯示12,16,24的字符和漢字。
oled接線:
sbit OLED_CS = P0^3;
sbit OLED_RS = P0^4;
sbit OLED_RST = P0^5;
sbit OLED_SDIN = P0^6;
sbit OLED_SCLK = P0^7;
W25Q128接線:
cs接P2^2
mosi接P2^3
miso接P2^4
clk接P2^5
#include "stc8.h"
#include "oled.h"
#include "bmp.h"
#include "spi.h"
#include "flash.h"
u8 buffer[19]; //接收數組
int main(void)
u8 t=0;
SP=0X80; //調整堆棧指向 手冊286頁 詳解
Init_SPI(); //SPI初始化
OLED_Init(); //初始化OLED
OLED_Display_Off();
OLED_Display_On();
OLED_Fill(0,0,1,1,1);
OLED_ShowString(0,0,"ABCDEFGH",24);
OLED_Refresh_Gram(); //更新顯示到OLED
OLED_ShowString(0,24, "0.96' OLED TEST",16);
SPI_Flash_Read(buffer,100,16); //在地址100位置處讀取字符串并存入buffer數組中
OLED_ShowString(0,40,buffer,12);
OLED_ShowString(0,52,"ASCII:",12);
OLED_ShowString(64,52,"CODE:",12);
OLED_Clear();
Show_Str(0,0,128,16,"戰艦STM32F開發板",12,0);
Show_Str(0,18,128,16,"初級維修電工",16,0);
Show_Str(0,36,128,24,"中景園電子",24,0);
t=' ';
1中景園電子0.96OLED帶W25Q128.rar
(201.18 KB, 下載次數: 174)
2019-12-5 14:07 上傳
