指紋模塊:AS608
單片機(jī):德飛萊stm32f103zet6(M3S)
需要中文字庫(kù)。
自己學(xué)習(xí)弄的,as608模塊給的是正點(diǎn)原子32的例程,沒(méi)有德飛萊32的,因此在正點(diǎn)原子戰(zhàn)艦版例程上進(jìn)行了修改,可以在德飛萊板子上運(yùn)行。
因?yàn)樗接邢蓿牡暮艽植冢皇腔颈A袅斯δ埽?jiàn)諒。
有錯(cuò)誤請(qǐng)留言。
有疑問(wèn)請(qǐng)留言。
侵刪
新建:
newxxx 接收 0x6e 0x65 0x77
fir st 發(fā)送 0x66 0x69 0x72
sec ond 發(fā)送 0x73 0x65 0x63
suc cess 發(fā)送 0x73 0x75 0x63
fai l 發(fā)送 0x66 0x61 0x69
nof inger 發(fā)送 0x6e 0x6f 0x66
dif 發(fā)送 兩次指紋不一
sam 發(fā)送 兩次指紋一致
識(shí)別:
rec ognize-xxx 發(fā)送 0x72 0x65 0x63
yes
no
刪除:
delxxx 接收 0x64 0x65 0x6c
delall 接收 0x64 0x65 0x6c 0x61 0x6C 0x6C
com plete 發(fā)送 0x63 0x6f 0x6d
連接失敗 error 發(fā)送 0x65 0x72 0x72
單片機(jī)源程序如下:
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "lcd.h"
- #include "key.h"
- #include "beep.h"
- #include "touch.h"
- #include "malloc.h"
- #include "usmart.h"
- #include "sdio_sdcard.h"
- #include "w25qxx.h"
- #include "ff.h"
- #include "exfuns.h"
- #include "fontupd.h"
- #include "text.h"
- #include "usart2.h"
- #include "AS608.h"
- #include "timer.h"
- #include "adc.h"
- #include "switch.h"
- #define usart2_baund 57600//串口2波特率,根據(jù)指紋模塊波特率更改
- SysPara AS608Para;//指紋模塊AS608參數(shù)
- u16 ValidN;//模塊內(nèi)有效指紋個(gè)數(shù)
- u8** kbd_tbl;
- u8 unlock=0;
- u8 lock=0;
- float ADC_ConvertedValueLocal;
- extern __IO uint16_t ADC_ConvertedValue;
- const u8* kbd_menu[15]={"刪指紋"," : ","錄指紋","1","2","3","4","5","6","7","8","9","DEL","0","Enter",};//按鍵表
- const u8* kbd_delFR[15]={"返回"," : ","清空指紋","1","2","3","4","5","6","7","8","9","DEL","0","Enter",};//按鍵表
- void Add_FR(u8 fingerid); //錄指紋
- void Del_FR(void); //刪除指紋
- void press_FR(void);//刷指紋
- void ShowErrMessage(u8 ensure);//顯示確認(rèn)碼錯(cuò)誤信息
- void AS608_load_keyboard(u16 x,u16 y,u8 **kbtbl);//加載虛擬鍵盤(pán)
- u8 AS608_get_keynum(u16 x,u16 y);//獲取鍵盤(pán)數(shù)
- u16 GET_NUM(void);//獲取數(shù)值
- int main(void)
- u8 ensure;
- // u8 key_num;
- char *str;
- ADC1_Init();
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級(jí)分組2
- delay_init(); //初始化延時(shí)函數(shù)
- uart_init(115200); //初始化串口1波特率為115200,用于支持USMART
- usart2_init(usart2_baund);//初始化串口2,用于與指紋模塊通訊
- // usart4_init(9600);//初始化串口3上位機(jī)
- PS_StaGPIO_Init(); //初始化FR讀狀態(tài)引腳
- BEEP_Init(); //初始化蜂鳴器
- KEY_Init(); //按鍵初始化
- LCD_Init(); //LCD初始化
- W25QXX_Init(); //初始化W25Q128
- tp_dev.init(); //初始化觸摸屏
- usmart_dev.init(72); //初始化USMART
- my_mem_init(SRAMIN); //初始化內(nèi)部?jī)?nèi)存池
- exfuns_init(); //為fatfs相關(guān)變量申請(qǐng)內(nèi)存
- f_mount(fs[1],"1:",1); //掛載FLASH.
- POINT_COLOR=RED;
- while(font_init()) //檢查字庫(kù)
- LCD_ShowString(60,50,240,16,16,"Font Error!");
- delay_ms(200);
- LCD_Fill(60,50,240,66,WHITE);//清除顯示
- delay_ms(200);
- if(!(tp_dev.touchtype&0x80))//如果是電阻屏
- // Show_Str_Mid(0,30,"是否進(jìn)行觸摸屏校準(zhǔn)",16,240);
- // POINT_COLOR=BLUE;
- // Show_Str_Mid(0,60,"是:KEY2 否:KEY0",16,240);
- // while(1)
- // key_num=KEY_Scan(0);
- // if(key_num==KEY0_PRES)
- // break;
- // if(key_num==KEY2_PRES)
- // LCD_Clear(WHITE);
- // TP_Adjust(); //屏幕校準(zhǔn)
- // TP_Save_Adjdata();//保存校準(zhǔn)參數(shù)
- // break;
- /*加載指紋識(shí)別實(shí)驗(yàn)界面*/
- LCD_Clear(WHITE);
- POINT_COLOR=RED;
- Show_Str_Mid(0,0,"AS608指紋識(shí)別模塊測(cè)試程序",16,240);
- //Show_Str_Mid(0,20,"正點(diǎn)原子 @ALIENTEK",16,240);
- POINT_COLOR=BLUE;
- Show_Str_Mid(0,40,"與AS608模塊握手....",16,240);
- while(PS_HandShake(&AS608Addr))//與AS608模塊握手
- delay_ms(400);
- LCD_Fill(0,40,240,80,WHITE);
- Show_Str_Mid(0,40,"檢測(cè)到模塊!!!",16,240);
- delay_ms(800);
- Show_Str_Mid(0,40,"嘗試連接模塊...",16,240);
- LCD_Fill(30,40,240,100,WHITE);
- Show_Str_Mid(0,40,"通訊成功!!!",16,240);
- printf("連接成功");
- str=mymalloc(SRAMIN,30);
- sprintf(str,"波特率:%d 地址:%x",usart2_baund,AS608Addr);
- Show_Str(0,60,240,16,(u8*)str,16,0);
- ensure=PS_ValidTempleteNum(&ValidN);//讀庫(kù)指紋個(gè)數(shù)
- if(ensure!=0x00)
- ShowErrMessage(ensure);//顯示確認(rèn)碼錯(cuò)誤信息
- ensure=PS_ReadSysPara(&AS608Para); //讀參數(shù)
- if(ensure==0x00)
- mymemset(str,0,50);
- sprintf(str,"庫(kù)容量:%d 對(duì)比等級(jí): %d",AS608Para.PS_max-ValidN,AS608Para.PS_level);
- Show_Str(0,80,240,16,(u8*)str,16,0);
- else
- myfree(SRAMIN,str);
- AS608_load_keyboard(0,170,(u8**)kbd_menu);//加載虛擬鍵盤(pán)
- while(1)
- // key_num=AS608_get_keynum(0,170);
- // if(key_num)
- // if(key_num==1)Del_FR(); //刪指紋
- // if(key_num==3)Add_FR(); //錄指紋
- // GPIO_SetBits(GPIOB,GPIO_Pin_9);
- // GPIO_ResetBits(GPIOB,GPIO_Pin_9);
- ADC_ConvertedValueLocal =(float) ADC_ConvertedValue/4096*3.3;
- LCD_ShowxNum(0,120,ADC_ConvertedValueLocal*100,20,16,0);
- information();
- if(PS_Sta) //檢測(cè)PS_Sta狀態(tài),如果有手指按下
- press_FR();//刷指紋
- delay_ms(500);
- //加載按鍵界面(尺寸x,y為240*150)
- //x,y:界面起始坐標(biāo)(240*320分辨率的時(shí)候,x必須為0)
- u16 i;
- POINT_COLOR=RED;
- kbd_tbl=kbtbl;
- LCD_Fill(x,y,x+240,y+150,WHITE);
- LCD_DrawRectangle(x,y,x+240,y+150);
- LCD_DrawRectangle(x+80,y,x+160,y+150);
- LCD_DrawRectangle(x,y+30,x+240,y+60);
- LCD_DrawRectangle(x,y+90,x+240,y+120);
- POINT_COLOR=BLUE;
- for(i=0;i<15;i++)
- if(i==1)//按鍵表第2個(gè)‘:’不需要中間顯示
- Show_Str(x+(i%3)*80+2,y+7+30*(i/3),80,30,(u8*)kbd_tbl[i],16,0);
- else
- Show_Str_Mid(x+(i%3)*80,y+7+30*(i/3),(u8*)kbd_tbl[i],16,80);
- //按鍵狀態(tài)設(shè)置
- //x,y:鍵盤(pán)坐標(biāo)
- //key:鍵值(0~14)
- //sta:狀態(tài),0,松開(kāi);1,按下;
- void AS608_key_staset(u16 x,u16 y,u8 keyx,u8 sta)
- u16 i=keyx/3,j=keyx%3;
- if(keyx>16)return;
- if(sta &&keyx!=1)//按鍵表第2個(gè)‘:’不需要清除
- LCD_Fill(x+j*80+1,y+i*30+1,x+j*80+78,y+i*30+28,GREEN);
- else if(keyx!=1)
- LCD_Fill(x+j*80+1,y+i*30+1,x+j*80+78,y+i*30+28,WHITE);
- if(keyx!=1)//不是‘:’
- Show_Str_Mid(x+j*80,y+7+30*i,(u8*)kbd_tbl[keyx],16,80);
- //得到觸摸屏的輸入
- //返回值:(1~15,對(duì)應(yīng)按鍵表)
- u16 i,j;
- static u8 key_x=0;//0,沒(méi)有任何按鍵按下
- u8 key=0;
- tp_dev.scan(0);
- if(tp_dev.sta&TP_PRES_DOWN)//觸摸屏被按下
- for(i=0;i<5;i++)
- for(j=0;j<3;j++)
- if(tp_dev.x[0]<(x+j*80+80)&&tp_dev.x[0]>(x+j*80)&&tp_dev.y[0]<(y+i*30+30)&&tp_dev.y[0]>(y+i*30))
- key=i*3+j+1;
- break;
- if(key)
- if(key_x==key)key=0;
- else
- AS608_key_staset(x,y,key_x-1,0);
- key_x=key;
- AS608_key_staset(x,y,key_x-1,1);
- break;
- }else if(key_x)
- key_x=0;
- return key;
- //獲取鍵盤(pán)數(shù)值
- u16 GET_NUM(void)
- u8 key_num=0;
- u16 num=0;
- while(1)
- key_num=AS608_get_keynum(0,170);
- if(key_num)
- if(key_num==1)return 0xFFFF;//‘返回’鍵
- if(key_num==3)return 0xFF00;//
- if(key_num>3&&key_num<13&&num<99)//‘1-9’鍵(限制輸入3位數(shù))
- num =num*10+key_num-3;
- if(key_num==13)num =num/10;//‘Del’鍵
- if(key_num==14&&num<99)num =num*10;//‘0’鍵
- if(key_num==15)return num; //‘Enter’鍵
- LCD_ShowNum(80+15,170+7,num,6,16);
- //顯示確認(rèn)碼錯(cuò)誤信息
- LCD_Fill(0,120,lcddev.width,160,WHITE);
- Show_Str_Mid(0,120,(u8*)EnsureMessage(ensure),16,240);
- //錄指紋
- u8 i,ensure ,processnum=0;
- u16 ID;
- while(1)
- switch (processnum)
- case 0:
- i++;
- LCD_Fill(0,100,lcddev.width,160,WHITE);
- Show_Str_Mid(0,100,"請(qǐng)按指紋",16,240);
- if(i==1)
- {printf("fir");}
- ensure=PS_GetImage();
- if(ensure==0x00)
- BEEP=1;
- ensure=PS_GenChar(CharBuffer1);//生成特征
- BEEP=0;
- if(ensure==0x00)
- Show_Str_Mid(0,120,"指紋正常",16,240);
- i=0;
- processnum=1;//跳到第二步
- }else ShowErrMessage(ensure);
- break;
- case 1:
- i++;
- Show_Str_Mid(0,100,"請(qǐng)按再按一次指紋",16,240);
- if(i==1)
- {printf("sec");}
- if(ensure==0x00)
- BEEP=1;
- ensure=PS_GenChar(CharBuffer2);//生成特征
- BEEP=0;
- if(ensure==0x00)
- i=0;
- processnum=2;//跳到第三步
- break;
- case 2:
- Show_Str_Mid(0,100,"正在對(duì)比兩次指紋",16,240);
- ensure=PS_Match();
- if(ensure==0x00)
- Show_Str_Mid(0,120,"對(duì)比成功,兩次指紋一樣",16,240);
- printf("sam");
- processnum=3;//跳到第四步
- else
- Show_Str_Mid(0,100,"對(duì)比失敗,請(qǐng)重新錄入指紋",16,240);
- printf("dif");
- i=0;
- processnum=0;//跳回第一步
- delay_ms(1200);
- break;
- case 3:
- Show_Str_Mid(0,100,"生成指紋模板",16,240);
- ensure=PS_RegModel();
- if(ensure==0x00)
- Show_Str_Mid(0,120,"生成指紋模板成功",16,240);
- processnum=4;//跳到第五步
- }else {processnum=0;ShowErrMessage(ensure);}
- delay_ms(1200);
- break;
- case 4:
- // LCD_Fill(0,100,lcddev.width,160,WHITE);
- // Show_Str_Mid(0,100,"請(qǐng)輸入儲(chǔ)存ID,按Enter保存",16,240);
- // Show_Str_Mid(0,120,"0=< ID <=299",16,240);
- do
- // ID=GET_NUM();
- ID=fingerid;
- while(!(ID<AS608Para.PS_max));//輸入ID必須小于指紋容量的最大值
- ensure=PS_StoreChar(CharBuffer2,ID);//儲(chǔ)存模板
- if(ensure==0x00)
- Show_Str_Mid(0,120,"錄入指紋成功",16,240);
- printf("suc");
- PS_ValidTempleteNum(&ValidN);//讀庫(kù)指紋個(gè)數(shù)
- LCD_ShowNum(56,80,AS608Para.PS_max-ValidN,3,16);
- delay_ms(1500);
- LCD_Fill(0,100,240,160,WHITE);
- return ;
- break;
- delay_ms(500);
- if(i==8)//超過(guò)5次沒(méi)有按手指則退出
- // printf("nof");
- break;
- //刷指紋
- SearchResult seach;
- u8 ensure;
- char *str;
- if(ensure==0x00)//獲取圖像成功
- BEEP=1;//打開(kāi)蜂鳴器
- if(ensure==0x00) //生成特征成功
- BEEP=0;//關(guān)閉蜂鳴器
- ensure=PS_HighSpeedSearch(CharBuffer1,0,AS608Para.PS_max,&seach);
- if(ensure==0x00)//搜索成功
- Show_Str_Mid(0,100,"刷指紋成功",16,240);
- str=mymalloc(SRAMIN,50);
- sprintf(str,"確有此人,ID:%d 匹配得分:%d",seach.pageID,seach.mathscore);
- printf("rec");
- printf("%d",(seach.pageID/100)%10);
- printf("%d",(seach.pageID/10)%10);
- printf("%d",seach.pageID%10);
- Show_Str_Mid(0,140,(u8*)str,16,240);
- else
- else
- delay_ms(600);
- //刪除指紋
- void Del_FR(void)
- u8 ensure;
- u16 num;
- Show_Str_Mid(0,100,"刪除指紋",16,240);
- Show_Str_Mid(0,120,"請(qǐng)輸入指紋ID按Enter發(fā)送",16,240);
- Show_Str_Mid(0,140,"0=< ID <=299",16,240);
- delay_ms(50);
- AS608_load_keyboard(0,170,(u8**)kbd_delFR);
- num=GET_NUM();//獲取返回的數(shù)值
- if(num==0xFFFF)
- goto MENU ; //返回主頁(yè)面
- else if(num==0xFF00)
- ensure=PS_Empty();//清空指紋庫(kù)
- else
- ensure=PS_DeletChar(num,1);//刪除單個(gè)指紋
- if(ensure==0)
- Show_Str_Mid(0,140,"刪除指紋成功",16,240);
- printf("com");
- else
- delay_ms(1200);
- MENU:
- delay_ms(50);
as608 defly stm32.7z
(1.37 MB, 下載次數(shù): 65)
2019-12-5 16:00 上傳
點(diǎn)擊文件名下載附件
指紋例程
as608 單片機(jī)設(shè)計(jì).7z
(1.37 MB, 下載次數(shù): 57)
2019-12-5 16:00 上傳
點(diǎn)擊文件名下載附件
指紋密碼鎖
評(píng)分
查看全部評(píng)分
