#include "reg52.h"
#include "onewire.h"
#include "ds1302.h"
sfr AUXR=0x8e;
unsigned char code ds[]={50,59,23};
unsigned char shijian[7];
unsigned char code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff};
void smg_xianshi(uchar yi,er,san,si,wu,liu,qi,ba);
void delay(uint x);
uchar yi,er,san,si,wu,liu,qi,ba;
void readtime();
void dsinit();
void allinit();
uchar key_panjian();
void Timer0Init(void);
void zhongduan();
uchar tab1[10];
uchar jiemian=0x10,ww=0,qiehuan_flag=0; //10自動界面//20時鐘界面//30溫度顯示界面 //40溫度采集顯示界面//
uint tt=0;
uchar k=0,aa;
uchar q=0;
uint times=0;
uchar work_flag=0,work_end=0,p=0;
void readtime()
unsigned char i;
unsigned char addr=0x81;
Ds1302_Single_Byte_Write(0x8e,0x00);
for(i=0;i<7;i++)
shijian[i]=Ds1302_Single_Byte_Read(addr);
addr=addr+2;
Ds1302_Single_Byte_Write(0x8e,0x80);
void dsinit()
unsigned char i;
unsigned char addr=0x80;
for(i=0;i<7;i++)
Ds1302_Single_Byte_Write(addr,ds[i]);
addr=addr+2;
void delay(uint x)
uchar i;
while(x--)
for(i=0;i<120;i++);
P2=0xc0;
P0=0x01;
P2=0xe0;
P0=tab[yi];
delay(10);
P2=0xc0;
P0=0x02;
P2=0xe0;
P0=tab[er];
delay(10);
P2=0xc0;
P0=0x04;
P2=0xe0;
P0=tab[san];
delay(10);
P2=0xc0;
P0=0x08;
P2=0xe0;
P0=tab[si];
delay(10);
P2=0xc0;
P0=0x10;
P2=0xe0;
P0=tab[wu];
delay(10);
P2=0xc0;
P0=0x20;
P2=0xe0;
P0=tab[liu];
delay(10);
P2=0xc0;
P0=0x40;
P2=0xe0;
P0=tab[qi];
delay(10);
P2=0xc0;
P0=0x80;
P2=0xe0;
P0=tab[ba];
delay(10);
uchar j=0,flag=0,flag1=0,ls1=0,qi=0,ba=1;
uchar set_time=1;
dsinit();
allinit();
Timer0Init();
j=key_panjian();
switch(jiemian)
case 0x10:
// times=200;
yi=11,er=11,san=11,si=11,wu=11,liu=10; //11//
switch(j)
case 1:
break;
case 2:
break;
case 3:
work_flag=1;
jiemian=0x20;
q=0;
break;
case 4:
set_time++;
if(set_time>4)
set_time=1;
if(set_time==1)
qi=0;
ba=1;
times=200;
else if(set_time==2)
qi=0;
ba=5;
times=1000;
else if(set_time==3)
qi=3;
ba=0;
times=6000;
else if(set_time==4)
qi=6;
ba=0;
times=12000;
break;
default:break;
break;
case 0x20:
readtime();
yi=shijian[2]/10;er=shijian[2]%10; //22//
si=shijian[1]/10;wu=shijian[1]%10;
qi=shijian[0]/10;ba=shijian[0]%10;
if(shijian[0]%2==0)
san=11;
liu=11;
san=10;
liu=10;
if(work_end==1)
jiemian=0x30; //55//
break;
case 0x30:
yi=10,er=0,san=0,si=11,wu=11,liu=10; //66//
qi=tab1[9]/10;
ba=tab1[9]%10;
switch(j)
case 1:
break;
case 2:
work_end=0;
P2=0x80;P0=0xff;P2=0x1f; //77//
jiemian=0x40;
break;
case 3:
break;
case 4:
break;
default:break;
break;
case 0x40:
if(qiehuan_flag!=0) //88//
qiehuan_flag=0;
qi=tab1[p]/10;
ba=tab1[p]%10;
yi=10,er=(p+1)/10,san=(p+1)%10,si=11,wu=11,liu=10;
p++;
if(p>9)
p=0;
switch(j)
case 1:
qiehuan_flag=0xff;
jiemian=0x10;
if(times==200)
qi=0;
ba=1;
else if(times==1000)
qi=0;
ba=5;
else if(times==6000)
qi=3;
ba=0;
else if(times==12000)
qi=6;
ba=0;
break;
case 2:
break;
case 3:
break;
case 4:
break;
default:break;
break;
default:break;
smg_xianshi(yi,er,san,si,wu,liu,qi,ba);
//判鍵子程序//
uchar key_panjian()
uchar i,key=0;
P3=0x0f;
i=P3;
i=i&0x0f;
if(i!=0x0f)
delay(20);
i=P3;
i=i&0x0f;
if(i!=0x0f)
switch (i)
case 0x0e:key=1;break;
case 0x0d:key=2;break;
case 0x0b:key=3;break;
case 0x07:key=4;break;
default: break;
i=P3;
i=i&0x0f;
while(i!=0x0f)
P3=0x0f;
i=P3;
i=i&0x0f;
return key;
void allinit()
P2=0XA0;
P0=0X00;//關閉蜂鳴器,繼電器
P2=0X80;
P0=0XFF;//關閉LED燈
void Timer0Init(void) //5毫秒@11.0592MHz
AUXR |= 0x80; //定時器時鐘1T模式
TMOD &= 0xF0; //設置定時器模式
TL0 = 0x00; //設置定時初值
TH0 = 0x28; //設置定時初值
TF0 = 0;
EA=1;
ET0=1; //清除TF0標志
TR0=1; //定時器0開始計時
void zhongduan() interrupt 1
aa++;
ww++;
tt++;
if(work_flag==1)
if(tt>=times)
tt=0;
k=RD_temper();
if(q<10)
tab1[q++]=k;
q=0;
work_flag=0;
work_end=1; //33//
if((work_end==1)&&(aa==200))
aa=0;
P2=0x80;P0=0xfe;P2=0x1f;
else if((work_end==1)&&(aa==100))
if(jiemian==0x40)
if(ww==200)
ww=0;
qiehuan_flag=1;
// else if(ww==100)
// qiehuan_flag=0;
