Z51F0811RFX
Zilog’s Z51F0811 MCU
Z51F0811 MCU Feature Set
High-Performance 8-Bit CISC Core (2 clocks per machine cycle)
8 KB On-Chip Flash Memory
512 Bytes SRAM
256 Bytes Data EEPROM @ 300,000 cycle endurance
Operating Frequency: 0–12 MHz
Operating Voltage: 1.8V–5.5V
On-Chip 8 MHz RC Oscillator with Programmable Clock Divider
Power-Saving Modes (Idle, Stop1, Stop 2)
Configurable Timers
o Timer/Counter (8 bits x 4 channels or 16 bits by 2 channels) plus 16-bit Internal Timer/Counter
o 10-bit PWM with Timer and 3 Complementary Pairs with Deadband Insertion
o Basic Interval Timer
Watchdog Timer
Watch Timer
Universal Synchronous/Asynchronous Receiver/Transmitter (2-channel USART/SPI/I2C)
Dedicated Serial Peripheral Interface
12-bit ADC with 8 to 15 Input Channels
Analog Comparator
Buzzer Driver Port
Up to 30 GPIO pins, configurable as push-pull, pull-up or open-drain
Multiple Interrupts from Multiple Sources via Priority Setting
Programmable Brown-Out Detector
Low-Frequency Subactive Mode
Operating Temperature: –40°C to 85°C
Packages: 32-Pin QFN, 28-Pin TSSOP, 20-Pin TSSOP, 16-Pin TSSOP
Lead-Free Manufacture
Zilog’s Z8051 Family of MCUs: flexible, industry-standard MCU solutions backed by Zilog’s long-term
commitment to supporting our customers.
| 制造商型號:Z51F0811RFX | | 介紹:IC MCU 8BIT 8KB FLASH 16TSSOP | | 最低購買量:1 | | 廠家:Zilog | | 包裝:Tray | | 系列:Z8051 | | 零件狀態:Active | | 核心處理器:8051 | | 核心尺寸:8-Bit | | 速度:12MHz | | 連接性:I?C, SPI, UART/USART | | 外設:Brown-out Detect/Reset, POR, PWM, WDT | | I/O 數:14 | | 程序存儲容量:8KB (8K x 8) | | 程序存儲器類型:FLASH | | EEPROM 容量:512 x 8 | | RAM 容量:256 x 8 | | 電壓 - 電源(Vcc/Vdd):1.8V ~ 5.5V | | 數據轉換器:A/D 8x12b | | 振蕩器類型:Internal | | 工作溫度:-40°C ~ 85°C (TA) | | 安裝類型:Surface Mount | | 封裝/外殼:16-TSSOP (0.173", 4.40mm Width) | 供應商器件封裝:-
pb0238.pdf
2019-12-6 23:59 上傳
130.08 KB, 下載次數: 4
Z51F0811RFX
