查看: 2484|回復: 1
數(shù)碼管實現(xiàn)萬年歷鬧鐘和計時器
ID:642752 發(fā)表于 2019-11-26 11:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
    sbit wela=P2^7;
sbit dula=P2^6;
   sbit key1=P3^0;
   sbit key2=P3^1;
   sbit key3=P3^2;
   sbit key4=P3^3;
sbit beep=P2^3;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x00};
void delayms(uint);
void display(uchar,uchar,uchar,uchar,uchar,uchar);
void display1(uchar,uchar,uchar,uchar,uchar,uchar,uchar,uchar);
void display2(uchar,uchar,uchar,uchar);
void display3(uchar,uchar,uchar,uchar,uchar,uchar);
void keycan();
void juzhen();
void tiaonaozhong();
uchar num1,num2,num3,shi1,shi2,fen1,fen2,miao1,miao2;
uchar nian1,nian2,nian3,nian4,yue1,yue2,ri1,ri2;
uint num=0,a=0,b=8,d=24,e=11,f=2019;
uchar qian,bai,shi,ge;
uchar shi3,shi4,fen3,fen4,miao3,miao4;
uint numm=0,aa=0,bb=0;
uint key,c=1;
     TMOD=0x01;
     TH0=(65536-45872)/256;
     TL0=(65536-45872)%256;
       TH1=(65536-45872)/256;
                            TL1=(65536-45872)%256;
     EA=1;
     ET0=1;
     TR0=1;
              ET1=1;
        miao1=num/10;
              miao2=num%10;
     fen1=a/10;
     fen2=a%10;
     shi1=b/10;
     shi2=b%10;
        ri1=d/10;
               ri2=d%10;
               yue1=e/10;
               yue2=e%10;
               nian1=f/1000;
               nian2=f%1000/100;
               nian3=f%1000%100/10;
               nian4=f%1000%100%10%10;
     miao3=numm/10;
              miao4=numm%10;
     fen3=aa/10;
     fen4=aa%10;
     shi3=bb/10;
     shi4=bb%10;
    if(numm==num&&bb==b&&aa==a)  //鬧鐘響
     {beep=0;}
    if(numm==num&&b==bb+2&&aa==a)  //自動關鬧鐘
     {beep=1;}
    keycan();
    juzhen();
    tiaonaozhong();
      if(c%4==1)
    nian1=16;nian2=16;nian3=16;nian3=16;nian4=16;
    yue1=16;yue2=16;ri1=16;ri2=16;
    qian=16;bai=16;shi=16;ge=16;
    shi3=16;shi4=16;fen3=16;fen4=16;miao3=16;miao4=16;
        display(shi1,shi2,fen1,fen2,miao1,miao2);
     if(c%4==2)
     shi1=16;shi2=16;fen1=16;fen2=16;miao1=16;miao2=16;
        display1(nian1,nian2,nian3,nian4,yue1,yue2,ri1,ri2);
     if(c%4==3)
    nian1=16;nian2=16;nian3=16;nian4=16;
        display2(qian,bai,shi,ge);
     if(c%4==0)
       display3(shi3,shi4,fen3,fen4,miao3,miao4);
     if(c==5)
      {c=1;}
     if(e==13)
     {e=1;}
void display(uchar shi1,uchar shi2,uchar fen1,uchar fen2,uchar miao1,uchar miao2)
    dula=1;
          P0=table[shi1];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfe;
          wela=0;
          delayms(1);
          dula=1;
          P0=table[shi2];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfd;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[fen1];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfb;
          wela=0;
          delayms(1);
          dula=1;
          P0=table[fen2];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xf7;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[miao1];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xef;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[miao2];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xdf;
          wela=0;
          delayms(1);
void display1(uchar nian1,uchar nian2,uchar nian3,uchar nian4,uchar yue1,uchar yue2,uchar ri1,uchar ri2)
          dula=1;
          P0=table[nian1];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfe;
          wela=0;
          delayms(1);
          dula=1;
          P0=table[nian2];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfd;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[nian3];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfb;
          wela=0;
          delayms(1);
          dula=1;
          P0=table[nian4];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xf7;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[yue1];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xef;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[yue2];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xdf;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[ri1];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xbf;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[ri2];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0x7f;
          wela=0;
          delayms(1);
void display2(uchar qian,uchar bai,uchar shi,uchar ge)
    dula=1;
          P0=table[qian];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfe;
          wela=0;
          delayms(1);
          dula=1;
          P0=table[bai];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfd;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[shi];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfb;
          wela=0;
          delayms(1);
          dula=1;
          P0=table[ge];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xf7;
          wela=0;
          delayms(1);
void display3(uchar shi3,uchar shi4,uchar fen3,uchar fen4,uchar miao3,uchar miao4)
    dula=1;
          P0=table[shi3];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfe;
          wela=0;
          delayms(1);
          dula=1;
          P0=table[shi4];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfd;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[fen3];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xfb;
          wela=0;
          delayms(1);
          dula=1;
          P0=table[fen4];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xf7;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[miao3];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xef;
          wela=0;
          delayms(1);
    dula=1;
          P0=table[miao4];
          dula=0;
          P0=0xff;
          wela=1;
          P0=0xdf;
          wela=0;
          delayms(1);
void tiaonaozhong()
    if(numm==60)
{numm=0;}
if(aa==60)
{aa=0;}
if(bb==24)
{bb=0;}
void delayms(uint xms)
           uint i,j;
           for(i=xms;i>0;i--)
            for(j=110;j>0;j--);
void keycan()     //獨立鍵盤
   if(key4==0)    //時間顯示切換鍵
   if(key4==0)
   c++;
  while(!key4);
void juzhen()    //矩陣
   uchar temp;
P3=0xfe;
temp=P3;
temp=temp&0xf0;
        if(temp!=0xf0)
//           delayms(10);
      temp=P3;
     temp=temp&0xf0;
     if(temp!=0xf0)
           temp=P3;
       switch(temp)
                 case 0xee:    //手動關鬧鐘
          beep=1;
          break;
       beep=1;
     case 0xde:       //計時清零
         qian=0;
       bai=0;
       shi=0;
        ge=0;
      num3=0;
          break;
     case 0xbe:    //按下停止計時
         TR1=0;
          break;
     case 0x7e:    //按下開始計時
         TR1=1;
          break;
       while(temp!=0xf0)
                  temp=P3;
      temp=temp&0xf0;
  P3=0xfd;
  temp=P3;
  temp=temp&0xf0;
       if(temp!=0xf0)
//    delayms(10);
    temp=P3;
       temp=temp&0xf0;
      if(temp!=0xf0)
         temp=P3;
      switch(temp)
       case 0xed:     //  調(diào)時
                  bb=bb+1;
      break;
       case 0xdd:     //  調(diào)分
               aa=aa+1;
      break;
       case 0xbd:    //   調(diào)秒
               numm=numm+1;
      break;
       case 0x7d:    //meiyongdao
            break;
      while(temp!=0xf0)
        temp=P3;
     temp=temp&0xf0;
void T0_time()interrupt 1
   TL0=(65536-45872)%256;   //50ms
    num1++;
      if(num1==20)  //1秒到了
    num1=0;
    num++;
    if(num==60)  // 一分鐘到了
      num=0;
      a++;
    if(a==60)  // 一小時到了
      a=0;
      b++;
    if(b==24)   //一天到了
     b=0;
     d++;
      if(d==31&&e==1|3|5|7|8|10|12) // d為天數(shù),e為月份,f為年份
      d=1;
      e++;
       if(d==28&&e==2&&f%4!=0) //平二月
          d=1;
       e++;
    if(d==29&&e==2&&f%4==0) //閏二月
          d=1;
       e++;
    if(d==30&&e==4|6|9|11)
          d=1;
       e++;
     if(e==12)    //一年到了
       f++;
    miao1=num/10;
             miao2=num%10;
    fen1=a/10;
    fen2=a%10;
    shi1=b/10;
    shi2=b%10;
    ri1=d/10;
    ri2=d%10;
    yue1=e/10;
    yue2=e%10;
    nian1=f/1000;
    nian2=f%1000/100;
  void T1_time()interrupt 3
   TL1=(65536-45872)%256;   //50ms
    num2++;
   if(num2==200)
     num2=0;
   num3++;
   if(num3==60)
    num3=0;
            shi=num3/10;
               ge=num3%10;
  if(shi==5&&ge==9)
       shi=0;
     ge=0;
    bai++;
  if(bai==9)
   qian++;
  if(qian==5)
    TR1=0;
收藏收藏3 分享淘帖 頂 踩
ID:1 發(fā)表于 2019-12-3 01:07 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
