查看: 1295|回復: 0
想請大佬幫我在這段程序里加個鬧鐘(不改主要程序) 最好能加個蜂鳴器
ID:647180 發表于 2019-11-24 13:19 | 顯示全部樓層 |閱讀模式
本帖最后由 伊月 于 2019-11-24 13:29 編輯
#include <AT89X51.H>
void naozhong();
void alarm();
unsigned int tcount;
unsigned char m;
static unsigned char second,minute,hour;
unsigned char code fseg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char code segbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
unsigned char  disbuf[8]={0,0,0,0,0,0,0,0};
sbit SWITCH=P2^0;
sbit SET=P2^1;
sbit QUIT=P2^2;
sbit INC_h=P2^3;
sbit INC_f=P2^4;
uchar m,f,s,w;
uchar f_nao,s_nao;
bit flag_nao;
void sdata(void)
{unsigned char b,c,num;
  if(b==0)
   b++;
num=segbit[m];
   for(c=0;c<8;c++)
    {P3_2=0;
     P3_3=num&0x80;
     num<<=1;
     P3_2=1;
if(b==1)
     b--;
   if(m==2||m==5)
   {num=0xbf;}
    {num=fseg[disbuf[m]];}
   for(c=0;c<8;c++)
     {  P3_2=0;
    P3_3=num&0x80;
    num<<=1;
    P3_2=1;
      m++;
      if(m==8)
   {m=0;
//???0.1ms????λ//
void delay (unsigned char h)
  { while(h--);
  //???0.1ms????λ//
void out(void)
{P3_4=0;
  delay(50);
  P3_4=1;
  void bcon(void)
   {if(P3_5==0)
     {delay(100);
    if(P3_5==0)
     {second=0;
    while(P3_5==0);
  disbuf[0]=second%10;
disbuf[1]=second/10;
if(P3_6==0)
     {delay(100);
    if(P3_6==0)
     {minute++;
    while(P3_6==0);
    if(minute==60)
     {minute=0;
disbuf[3]=minute%10;
disbuf[4]=minute/10;
  if(P3_7==0)
     {delay(100);
    if(P3_7==0)
     {hour++;
    while(P3_7==0);
     if(hour==24)
      {hour=0;
disbuf[6]=hour%10;
disbuf[7]=hour/10;
disbuf[6]=hour%10;
disbuf[7]=hour/10;
   void guan_naozhong()interrupt 0
   flag_nao=~flag_nao;       //??????????
   while(!SWITCH)sdata;
   void naozhong() interrupt 2
f_nao=f;
s_nao=s;
while(QUIT)
sdata(s_nao,f_nao,0);
if(INC_h==0)
if(INC_h==0)
if(s_nao==24) s_nao=0;
else s_nao++;          //???????????
while(!INC_h)sdata(s_nao,f_nao,0);
else if(INC_f==0)
if(INC_f==0)
if(f_nao==59)f_nao,0;
else f_nao++;
while(!INC_f)
void main(void)
  TMOD=0x02;
  TH0=0x06;
  TL0=0x06;
  TR0=1;
  ET0=1;
  EA=1;
   bcon();
   sdata();
   out();
  while(1);
//?ж????//
void t0(void) interrupt 1 using 0
  { tcount++;
    if(tcount==4000)
   {tcount=0;
     second++;
   if(second==60)
    {second=0;
     minute++;
      if(minute==60)
    {minute=0;
     hour++;
     if(hour==24)
      {hour=0;
  //?ж????//
這是基于74hc595芯片的數碼管顯示時鐘 現在我想在它的原本的程序上再拓展一些功能
數碼管是八位的
