查看: 1494|回復: 0
51單片機控制步進電機正反轉
ID:399931 發表于 2019-11-23 23:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg51.h"
//Motor
unsigned char code Motor_l[]={0xfe,0xfc,0xfd,0xf9,0xfb,0xf3,0xf7,0xf6};//四相八拍,逆時針
unsigned char code Motor_r[]={0xf7,0xf3,0xfb,0xf9,0xfd,0xfc,0xfe,0xf6};//四相八拍,順時針
unsigned char MotorStep=0;
unsigned int  Speed=8,CT=0;
sbit SB1=P2^0;
sbit SB2=P2^1;
sbit SB3=P2^2;
bit a=1,b=1;
unsigned char code discode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x76,0x38,0x73,0x31,0x3e,0x6e,0x40,0x80};
/* 共陰碼:0:0; 1:1; 2:2; 3:3; 4:4; 5:5; 6:6; 7:7; 8:8; 9:9;
        10:A; 11:B; 12:C; 13:d;  14:E; 15:F; 16:H; 17:L; 18:P; 19:R;
        20:U; 21:Y; 22:-;23:.;*/
//#define speed 8   // 調整速度 數值不要設的太低 低了會引起震動。
void delay(unsigned int i)
                unsigned int k;
                for(k=0;k<i;k++);
void system_Ini()
    TMOD= 0x01;
                TH0 =(65536-100)/256;
                TL0 =(65536-100)%256;
                IE  = 0x8A;
    TR0 = 1;
{ system_Ini();
   P1=0xff;//         初始化馬達
                 if(a==0)P0=~discode[Speed-7];
                else P0=0xff;
                 if(SB1==0)
                delay(1000);
                if(SB1==0)
                        while(!SB1);
                        a=!a;
                if(SB2==0)
                delay(1000);
                if(SB2==0)
                        while(!SB2);
                        b=!b;
                        if(SB3==0)
                delay(1000);
                if(SB3==0)
                        while(!SB3);
                        Speed++;
                        if(Speed==14)Speed=8;
                if(a==0&&b==1)
                P1=Motor_l[MotorStep];
         else if(a==0&&b==0)
                 P1=Motor_r[MotorStep];
         else P1=0xff;
  void int_tim0(void) interrupt 1
        if( CT++==Speed)
          {MotorStep++;
                if(MotorStep==8)MotorStep=0;
           CT=0;
