#include "1602.h"
#include "delay.h"
#include <intrins.h>
#define _NOP() _nop_()
sbit RS = P2^4;
sbit RW = P2^5;
sbit EN = P2^6;
#define DataPort P0
#define DataPIN P0
#define CLR_RS (RS=0)
#define SET_RS (RS=1)
#define CLR_RW (RW=0)
#define SET_RW (RW=1)
#define CLR_EN (EN=0)
#define SET_EN (EN=1)
LcdReset();
DelayMs(10);
sprintf(temp,"1111111111111111");//???????
DispStr(0,0,(unsigned char *)temp);//??????
DispStr(0,1,(unsigned char *)temp);//??????
?????????DispStr
?? ?????????????λ???????????????????
?? ????x--λ?????????
y--λ?????????
ptr--???????????λ??????
void DispStr(uchar x,uchar y,uchar *ptr)
uchar *temp;
uchar i,n = 0;
temp = ptr;
while(*ptr++ != '\0') n++; //???????????Ч????????
for (i=0;i<n;i++)
Disp1Char(x++,y,temp);
if (x == 0x10)
break;
?????????DispNchar
?? ?????????????λ???????????N?????
y--λ?????????
n--???????
ptr--?????????λ??????
void DispNChar(uchar x,uchar y, uchar n,uchar *ptr)
uchar i;
for (i=0;i<n;i++)
Disp1Char(x++,y,ptr);
if (x == 0x10)
x = 0;
y ^= 1;
?????????LocateXY
?? ??????????????????λ??????????
y--λ?????????
void LocateXY(uchar x,uchar y)
uchar temp;
temp = x&0x0f;
y &= 0x01;
if(y) temp |= 0x40; //??????2??
temp |= 0x80;
LcdWriteCommand(temp,1);
?????????Disp1Char
?? ????????λ???????????
y--λ?????????
data--????????????
void Disp1Char(uchar x,uchar y,uchar data1)
LocateXY( x, y );
LcdWriteData( data1 );
?????????LcdReset
?? ?????1602????????и?λ????
void LcdReset(void)
// DataDir = 0xFF; //??????????????
LcdWriteCommand(0x38, 0); //?漲???λ????
DelayMs(5);
DelayMs(5);
DelayMs(5);
LcdWriteCommand(0x38, 1); //?????????
LcdWriteCommand(0x08, 1); //??????
LcdWriteCommand(0x01, 1); //???????
LcdWriteCommand(0x06, 1); //д???????岻???
LcdWriteCommand(0x0c, 1); //????????????α??????
void LcdClear(void)
LcdWriteCommand(0x01,1);
DelayMs(5);
?????????LcdWriteCommand
?? ???????????д??????
?? ????cmd--????
chk--????????????1???????0??????
void LcdWriteCommand(uchar cmd,uchar chk)
if (chk) WaitForEnable(); // ????????
CLR_RS;
CLR_RW;
_NOP();
DataPort = cmd; //????????д????????
_NOP();
SET_EN; //??????????????
_NOP();
_NOP();
CLR_EN;
?????????LcdWriteData
?? ??????????????????д?????????
?? ????data--??????????
void LcdWriteData( uchar data1 )
WaitForEnable(); //?????????
SET_RS;
CLR_RW;
SET_EN;
_NOP();
DataPort = data1; //?????????д????????
_NOP();
_NOP();
_NOP();
CLR_EN;
?????????WaitForEnable
?? ??????1602?????????????
void WaitForEnable(void)
unsigned int later=0;
DataPort=0xff;
CLR_RS;
SET_RW;
_NOP();
SET_EN;
_NOP();
_NOP();
// while((DataPIN&Busy)!=0);
while(((DataPIN&0x80)!=0)&&(later<1000))
DelayUs2x(2);
later++;
CLR_EN;
