查看: 2004|回復: 2
請問這個程序有什么問題嗎?想做一個小鳥歸巢的花樣流水燈程序,但不知道哪里有問題...
ID:647007 發表于 2019-11-22 09:08 | 顯示全部樓層 |閱讀模式
#include <REGX52.H>
#define uchar unsigned char;
#define uint unsigned int;
uchar step = 0, Timer = 0;
uint i = 0, j = 0;
        TMOD = 0x01;
        TH0 = -9;
        ET0 = 1;
        EA = 1;
        TR0 = 1;
        step = 0;
        i = 0;
        j = 0;
                P0 = 0x00;
                while (step == 0)
                        if (Timer == 100)
                                P0 = 0x01 << i;
                                i = i + 1;
                                if (i == 8)
                                        i = 0;
                                Timer = 0;
                                j++;
                                break;
                while (step == 1)
                        if (Timer == 100)
                                P0 = 0x80 | (0x01 << i);
                                i = i + 1;
                                if (i == 6)
                                        j = 7;
                                i = i & 7;
                                Timer = 0;
                                break;
                while (step == 2)
                        if (Timer == 100)
                                P0 = 0xC0 | (0x01 << i);
                                i = i + 1;
                                if (i == 5)
                                        j = 7;
                                Timer = 0;
                                break;
                while (step == 3)
                        if (Timer == 100)
                                P0 = 0xE0 | (0x01 << i);
                                i = i + 1;
                                if (i == 4)
                                        j = 7;
                                Timer = 0;
                                break;
                while (step == 4)
                        if (Timer == 100)
                                P0 = 0xF0 | (0x01 << i);
                                i = i + 1;
                                if (i == 3)
                                        j = 7;
                                Timer = 0;
                                break;
                while (step == 5)
                        if (Timer == 100)
                                P0 = 0xF8 | (0x01 << i);
                                i = i + 1;
                                if (i == 2)
                                        j = 7;
                                Timer = 0;
                                break;
                while (step == 6)
                        if (Timer == 100)
                                P0 = 0xFC | (0x01 << i);
                                i = i + 1;
                                if (i == 1)
                                        j = 7;
                                Timer = 0;
                                break;
                while (step == 7)
                        if (Timer == 100)
                                P0 = 0xFE;
                                Timer = 0;
                                j = 7;
                                break;
                while (step == 8)
                        if (Timer == 100)
                                P0 = 0xFF;
                                Timer = 0;
                                j = 7;
                                break;
                while (step == 9)
                        if (Timer == 100)
                                P0 = ~P0;
                                Timer = 0;
                        j = 7;
      i = 0;
                        break;
        if (j == 7)
                        step++;
                        j = 0;
                        if (step == 10)
                                step = 0;
void IntT0() interrupt 1
        TH0 = -9;
        Timer++;
想做一個小鳥歸巢的花樣流水燈程序,但不知道哪里有問題導致protues仿真效果不正確...
ID:332444 發表于 2019-11-22 11:09 | 顯示全部樓層
電路圖是怎樣的?
ID:470332 發表于 2019-11-22 13:58 | 顯示全部樓層
TH0 = -9;     為什么要等于-9
