只需一步,快速開(kāi)始
查看: 1632|回復(fù): 3
關(guān)于單片機(jī)串口通信3的問(wèn)題
ID:508562 發(fā)表于 2019-11-21 11:27 | 顯示全部樓層 |閱讀模式
本帖最后由 tomli561 于 2019-11-21 16:53 編輯
在進(jìn)行通信時(shí),第一次主機(jī)向叢機(jī)發(fā)送數(shù)據(jù)的時(shí)候地址只判斷一次,但是之后再判斷就要進(jìn)行兩次地址判斷(有時(shí)候是連續(xù)兩次進(jìn)行判斷,有時(shí)候又是判斷一次卡主再按一下地址按鍵就判斷完進(jìn)入待發(fā)送數(shù)據(jù))
代碼如下:
#include <reg52.h>
#define KEY P0
sbit LED1 = P3^3;
sbit LED2 = P3^4;
sbit MCU1 = P2^0;
sbit MCU2 = P2^1;
sbit rs485dir = P3^2;
uchar x,b;
uchar dz[] = {0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08};
uchar code tab[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
                                        0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
uchar keyscan();
void delay(uint t);
void init();
uchar keyscan()          //鍵盤(pán)處理函數(shù)
        uchar a,c;
        KEY=0x0f;               //鍵盤(pán)口置00001111
        if(KEY!=0x0f)      //查詢鍵口值是否變化
                delay(20);       //去抖
                if(KEY!=0x0f)    //        有鍵按下
                        a=KEY;       //鍵值放在寄存器a中
                 KEY=0xf0;                //將鍵盤(pán)口置11110000
                 c=KEY;         //將第二次取得值放入寄存器c中
                 a=a|c;         //將兩個(gè)數(shù)據(jù)融合
                 switch(a)      //對(duì)比數(shù)據(jù)值
                         case  0xee  :  b=0;break;
                        case  0xde  :  b=1;break;
                        case  0xbe  :  b=2;break;
                        case  0x7e  :  b=3;break;
                        case  0xed  :  b=4;break;
                        case  0xdd  :  b=5;break;
                        case  0xbd  :  b=6;break;
                        case  0x7d  :  b=7;break;
                        case  0xeb  :  b=8;break;
                        case  0xdb  :  b=9;break;
                        case  0xbb  :  b=10;break;
                        case  0x7b  :  b=11;break;
                        case  0xe7  :  b=12;break;
                        case  0xd7  :  b=13;break;
                        case  0xb7  :  b=14;break;
                        case  0x77  :  b=15;break;
                        default:break;   //鍵值錯(cuò)誤處理
        return(b);   //將b作為返回值
void delay(uint t)
        uchar i,j;
        for(i=0;i<120;i++)
                for(j=0;j<t;j++);
void init()
        TMOD = 0x20;
        TH1 = 0xfd;
        TL1 = 0xfd;
        SCON = 0xd0;
        PCON = 0x00;
        TR1 = 1;
        rs485dir = 1;
        EA = 1;
//        ES = 1;
        MCU1 = 1;
        MCU2 = 1;
        KEY = 0x0f;
        uchar ADDR;
        uchar temp;
        init();
                P1 = 0XBF;
                temp++;
                while(temp!=ADDR)
                        LED1 = 1;
                        LED2 = 1;
                        TI = 0;
                        TB8 = 1;
                        rs485dir = 1;
                        delay(20);
                        while(!(MCU1^MCU2));
                        if(MCU1==0)
                                delay(50);
                                if(MCU1==1)
                                ADDR = dz[0];
                        if(MCU2==0)
                                delay(50);
                                if(MCU1==1)
                                ADDR = dz[1];
                        SBUF = ADDR;
                        while(!TI);
                        TI = 0;
                        rs485dir = 0;
                        delay(20);
                        LED1 = 0;
                        LED2 = 1;
                        P1 = tab[ADDR];
                        delay(20);
                        while(!RI);
                        temp = SBUF;
                        RI = 0;
                        delay(20);
                P1 = 0x40;
                rs485dir = 1;
                TB8 = 0;
                delay(10);
                while(KEY==0x0f);
                keyscan();
                SBUF = tab;
                while(!TI);
                TI = 0;
                P1 = 0xa4;
                LED1 = 0;
                LED2 = 1;
ID:123289 發(fā)表于 2019-11-21 22:02 | 顯示全部樓層
畫(huà)出流程圖,先在邏輯上走通。
ID:508562 發(fā)表于 2019-11-22 09:01 | 顯示全部樓層
yzwzfyz 發(fā)表于 2019-11-21 22:02
畫(huà)出流程圖,先在邏輯上走通。
這邏輯沒(méi)問(wèn)題啊
ID:123289 發(fā)表于 2019-11-23 10:04 | 顯示全部樓層
問(wèn)題就出在你畫(huà)不出流程圖
