查看: 4054|回復: 0
基于MSP430單片機的可調恒流源Proteus仿真程序設計
* 實驗說明:
*     通設置系統主時鐘(MCLK=8Mhz ) 、輔助時鐘(ACLK=8Mhz )、
*      子系統時鐘(SMCLK=8Mhz )
#include <MSP430x24x.h>
#include <string.h>
/**************定義接口************************/
#define LCDIO     P1OUT
#define LCD1602_RS_1  P2OUT|=1
#define LCD1602_RS_0  P2OUT&=~1
#define LCD1602_EN_1   P2OUT|=2
#define LCD1602_EN_0   P2OUT&=~2
#define PWM_1   P2OUT|=8
#define PWM_0   P2OUT&=~8
/**************定義函數************************/
void LCD_write_command(unsigned char command);//寫入指令函數
void LCD_write_dat( unsigned char dat);//寫入數據函數
void LCD_set_xy( unsigned char x, unsigned char y );//設置顯示位置函數
void LCD_dsp_char( unsigned char x,unsigned char y, char dat);//顯示一個字符函數
void LCD_dsp_string(unsigned char X,unsigned char Y,const char *s);//顯示字符串函數
void LCD_init(void);//初始化函數
void delay_nms(unsigned int n);//延時函數
void TCL5615_DAC(unsigned int Data);
//變量定義
unsigned char Disbuf[12],flag;
int DAC_num = 5;
unsigned char KEY_OPEN_OR_STOP_times = 1;
//ADC采集函數
void RefreshDis0(unsigned int Data0)
  if( Data0 < 10 )
    Disbuf[0] = 0x30 + Data0/100%10;
    Disbuf[1] = '.';
    Disbuf[2] = 0x30 + Data0/10%10;
    Disbuf[3] = 0x30 + Data0%10;
    Disbuf[4] = 'V';
    Disbuf[1] = '.';
    Disbuf[4] = 'V';
//ADC采集函數
void RefreshDis1(unsigned int Data1)
    Disbuf[5] = 0x30 + Data1/100%10;
    Disbuf[6] = 0x30 + Data1/10%10;
    Disbuf[7] = 0x30 + Data1%10;
    Disbuf[8] = 0x30;
    Disbuf[9] = 'm';
    Disbuf[10] = 'A';
void P23_Onclick( void )
  //50mA
   DAC_num = DAC_num + 10;
   if( DAC_num > 420 )
     DAC_num = 420;
    TCL5615_DAC( DAC_num );                      //205 對應1.0V    410  對應2.0V   5---20mA
void P24_Onclick( void )
  //50mA
   DAC_num = DAC_num - 10;
   if( DAC_num < 5 )
     DAC_num = 5;
void P25_Onclick( void )
    DAC_num = 5;
void P26_Onclick( void )
  //10mA
   DAC_num = DAC_num + 2;
   if( DAC_num > 420 )
     DAC_num = 420;
void P27_Onclick( void )
    //10mA
   DAC_num = DAC_num - 2;
   if( DAC_num < 5 )
     DAC_num = 5;
//電壓顯示函數
void Display( void )
    LCD_write_command( 0x80 );
    LCD_write_dat('V');
    LCD_write_dat(':');
    LCD_write_dat( Disbuf[0] );
    LCD_write_dat( Disbuf[1] );
    LCD_write_dat( Disbuf[2] );
    LCD_write_dat( Disbuf[3] );
    LCD_write_dat( Disbuf[4] );
    LCD_write_dat( ' ' );
    LCD_write_dat('I');
    LCD_write_dat(':');
    if( Disbuf[5] != 0x30 )
      LCD_write_dat( Disbuf[5] );
    if( Disbuf[6] != 0x30 )
      LCD_write_dat( Disbuf[6] );
    LCD_write_dat( Disbuf[7] );
    LCD_write_dat( Disbuf[8] );
    LCD_write_dat( Disbuf[9] );
    LCD_write_dat( Disbuf[10] );
void Display_Set( void )
   LCD_write_command( 0x80 + 0x40 );
   LCD_write_dat( 'S' );
   LCD_write_dat( 'e' );
   LCD_write_dat( 't' );
   LCD_write_dat( ':' );
   if( KEY_OPEN_OR_STOP_times == 1 )
     LCD_write_dat( 'O' );
     LCD_write_dat( 'P' );
     LCD_write_dat( 'E' );
     LCD_write_dat( 'N' );
   if( KEY_OPEN_OR_STOP_times == 2 )
     LCD_write_dat( 'T' );
/*******延時函數************/
void delayms(uint t)
    uint i;
    while(t--)
      for(i=1330;i>0;i--);//進過參數的調整
/*******檢查忙函數*************/
void LCD_check_busy()      //實踐證明,在我的LCD1602上,檢查忙指令通過率極低,以
{                                          //至于不能正常使用LCD。因此我沒有再用檢查忙函數。而使
        P1DIR=0x00;
        LCDIO=0xff;
        LCD1602_RS_0;                 //要用200次循環便能完成。
        LCD1602_EN_1;
        while(P1IN&0x80);
        LCD1602_EN_0;
        P1OUT=0x00;
        P1DIR=0xFF;
/**************寫指令函數********************************/
        LCD1602_RS_0;
        LCDIO=command;
        LCD1602_EN_1;
        LCD1602_EN_0;
        delayms(1);
/****************寫數據函數************************/
      LCD1602_RS_1;
      LCDIO=dat;
      LCD1602_EN_1;
      LCD1602_EN_0;
      delayms(1);
      LCD1602_RS_0;
/***************設置顯示位置**************************/
        unsigned char address;
        if (y == 1)
             address = 0x80+x;
        else if (y == 2)
               address=0x80+0x40+x;
        LCD_write_command(address);
/****************顯示一個字符**********************/
        LCD_set_xy( x, y );
        LCD_write_dat(dat);
/***************顯示字符串函數***************/
       uchar len,List;
       len=strlen(s);
       LCD_set_xy( X, Y );
       for(List=0;List<len;List++)
       LCD_write_dat(s[List]);
/********** 延時**********************/
       unsigned int i=0,j=0;
       for (i=n;i>0;i--)
       for (j=0;j<1;j++);
/************初始化函數****************/
void LCD_init(void)
      LCD1602_EN_0;
      //CLEARSCREEN;//clear screen
      LCD_write_command(0x38);//set 8 bit data transmission mode
      delayms(1);
      delayms(1);
      delayms(1);
      LCD_write_command(0x06);//open display (enable lcd display)
      delayms(1);
      LCD_write_command(0x0C);//set lcd first display address
      delayms(1);
      LCD_write_command(0x01);//clear screen
      delayms(1);
      LCD_dsp_string(1,1,"  LCD TEST   ");//在第一行第一列顯示"LCD TEST"
      LCD_dsp_string(1,2,"  SUCCSEEE!  ");//在第一行第一列顯示"LCD TEST"
      delayms(500);
      delayms(1);
//ADC
#define ADCST0          P5OUT &= ~BIT4
#define ADCST1         P5OUT |= BIT4
#define ADCALE0         P5OUT &= ~BIT5
#define ADCALE1         P5OUT |= BIT5
#define ADCEOC0         P5OUT &= ~BIT6
#define ADCEOC1         P5OUT |= BIT6
#define ADCOE0          P5OUT &= ~BIT7
#define ADCOE1          P5OUT |= BIT7
#define LED_0          P5OUT &= ~BIT3
#define LED_1          P5OUT |= BIT3
unsigned int  ADC1;
void ADC_START(void)
  ADCALE1;
  ADCST1;
  delayms(1);
   ADCALE0;
  ADCST0;
   delayms(1);
char ADC_READ()
  uchar data;
   data=0x00;
   delayms(1);
   ADCOE1;
  ADC_START();
   delayms(5);
  data=P4IN;
   ADCOE0;
  return data;
// DAC
#define SET_DIN   do{P3OUT |= BIT0;}while(0)      //串行數據輸入
#define CLR_DIN   do{P3OUT &= ~(BIT0);}while(0)      //串行數據輸入
#define SET_SCLK  do{P3OUT |= BIT1;}while(0)     //串行時鐘輸入
#define CLR_SCLK  do{P3OUT &= ~(BIT1);}while(0)     //串行時鐘輸入
#define SET_CS    do{P3OUT |= BIT2;}while(0)      //低電平有效
#define CLR_CS    do{P3OUT &= ~(BIT2);}while(0)      //低電平有效
/*****************************************軟件延時******************************/
#define CPU_F ((double)16000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
  unsigned char i;
  Data <<= 6;     //移除高6位,int型數據有16位,該DA是10位
  CLR_SCLK;    //在片選有效前,時鐘信號要為低
  CLR_CS;        //片選有效
  for(i=0;i<12;i++)       //每次轉換需要10個時鐘下降沿
    if(Data&0x8000)     //取最高位數據,模擬串行數據
      SET_DIN;
      CLR_SCLK;
      SET_SCLK;
      CLR_DIN;           //數據在時鐘上升沿到來前準備好
      CLR_SCLK;
      SET_SCLK;
    Data <<= 1;          //數據左移,為下一次取數據做準備
    CLR_SCLK;
  SET_CS;                    //片選失效
delayms(1);
void P22_Onclick( void )
    KEY_OPEN_OR_STOP_times++;
    if( KEY_OPEN_OR_STOP_times > 2 )
void main(void)
    WDTCTL=WDTPW + WDTHOLD; // 關閉看門狗
    P1DIR=0xFF;            // 設置方向
    P1SEL=0;            // 設置為普通I/O 口
    P2DIR=0x03;            // 設置方向
   // P2SEL=0;            // 設置為普通I/O 口
    P3DIR=0xFF;            // 設置方向
    //-----配合機械按鍵,啟用內部上拉電阻-----
    P2REN |= BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                     //啟用P3.5內部上下拉電阻
    P2OUT |= BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                     //將電阻設置為上拉
    //-----配置P3.5中斷參數-----
    P2DIR &= ~BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                    // P3.5設為輸入(可省略)
    P2IES |= BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                     // P3.5設為下降沿中斷
    P2IE  |= BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                    // 允許P3.5中斷
    P1OUT=0x00;
    P5DIR |= BIT7+BIT4+BIT5+BIT6+BIT3;
    delayms(200);
    LCD_init();         //LCD1602初始化
    /****設置AD寄存器****/
    ADC12CTL0=ADC12ON+SHT0_2;//打開AD轉換內核,參考電壓3.3V
    ADC12CTL1=SHP;
    ADC12IE=0X01;//使能中斷允許
    ADC12CTL0|=ENC;
    P6SEL|=0x01;//P6.0電壓輸入
    P6DIR = 0xFE;
    flag=0;
    ADC12CTL0|=ADC12SC;//啟動ADC轉換器
    _BIS_SR(LPM0_bits+ GIE);//進入低功耗睡眠模式
         LED_1;
        ADC1=ADC_READ();
        RefreshDis0(15-((ADC1*10)+25));
         Display();
         Display_Set();
        if(flag == 1)
            flag=0;
         KEY_OPEN_OR_STOP_times = 2;
         LED_0;
/****ADC12中斷服務****/
#pragma vector=ADC12_VECTOR
__interrupt void ADC12_ISR(void)
   RefreshDis1(ADC12MEM0/8);
   flag=1;
   LPM0_EXIT;
* 名       稱:P2_IODect()
* 功       能:判斷具體引發中斷的IO,并調用相應IO的中斷事件處理函數
* 說       明:該函數兼容所有8個IO的檢測,請根據實際輸入IO激活“檢測代碼”。
void P2_IODect()
    unsigned int Push_Key=0;
    //-----排除輸出IO的干擾后,鎖定唯一被觸發的中斷標志位-----
    Push_Key=P2IFG&(~P2DIR);
    //-----延時一段時間,避開機械抖動區域-----
     delayms(5);                  //消抖延時
    //----判斷按鍵狀態是否與延時前一致-----
    if((P2IN&Push_Key)==0)                      //如果該次按鍵確實有效
        //----判斷具體哪個IO被按下,調用該IO的事件處理函數-----
        switch(Push_Key)
               case BIT2:     P22_Onclick();      break;
               case BIT3:     if(KEY_OPEN_OR_STOP_times == 1) P23_Onclick();      break;
               case BIT4:     if(KEY_OPEN_OR_STOP_times == 1)P24_Onclick();      break;
               case BIT5:     if(KEY_OPEN_OR_STOP_times == 1)P25_Onclick();      break;
               case BIT6:     if(KEY_OPEN_OR_STOP_times == 1)P26_Onclick();      break;
               case BIT7:     if(KEY_OPEN_OR_STOP_times == 1)P27_Onclick();      break;
            default:                              break;      //任何情況下均加上default
#pragma vector = PORT2_VECTOR
__interrupt void PORT2_ISR(void)
    //-----啟用Port2事件檢測函數-----
    P2_IODect();                                //檢測通過,則會調用事件處理函數
    P2IFG=0;                                    //退出中斷前必須手動清除IO口中斷標志
全部資料51hei下載地址:
恒流源.rar (341.46 KB, 下載次數: 80)
