查看: 2406|回復(fù): 5
STM32調(diào)用中斷服務(wù)函數(shù),如何利用官方給的庫函數(shù)進行松手檢測?
ID:327671 發(fā)表于 2019-11-19 09:49 | 顯示全部樓層 |閱讀模式
如題
ID:263427 發(fā)表于 2019-11-19 20:16
ID:25310 發(fā)表于 2019-11-20 09:35 | 顯示全部樓層
就是個中斷小程序吧!
ID:25310 發(fā)表于 2019-11-20 09:38 | 顯示全部樓層
主程序:
#include "stm32f10x.h"   // 相當于51單片機中的  #include <reg51.h>
#include "bsp_led.h"
#include "bsp_systick.h"
#include "bsp_exti.h"
void Delay( uint32_t count )
        for(; count!=0; count--);
int main(void)
        // 來到這里的時候,系統(tǒng)的時鐘已經(jīng)被配置成72M。
        LED_GPIO_Config();
        EXIT_Key_Config();
  GPIO_SetBits(LED_G_GPIO_PORT, LED_G_GPIO_PIN1);
          LED_G1_TOGGLE1;
                SysTick_Delay_ms(500);
                //Delay( 6000000 );
ID:25310 發(fā)表于 2019-11-20 09:39 | 顯示全部樓層
中斷GPIO初始化程序:
static void EXTI_NVIC_Config(void)
        NVIC_InitTypeDef NVIC_InitStruct;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
        NVIC_InitStruct.NVIC_IRQChannel = EXTI2_IRQn;
        NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 1;
        NVIC_InitStruct.NVIC_IRQChannelSubPriority = 1;
        NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStruct);
void EXIT_Key_Config(void)
        GPIO_InitTypeDef  GPIO_InitStruct;
        EXTI_InitTypeDef  EXTI_InitStruct;
        // 配置中斷優(yōu)先級
        EXTI_NVIC_Config();
        // 初始化GPIO
        RCC_APB2PeriphClockCmd(KEY1_INT_GPIO_CLK, ENABLE);
        GPIO_InitStruct.GPIO_Pin = KEY1_INT_GPIO_PIN;
        GPIO_InitStruct.GPIO_Mode =GPIO_Mode_IN_FLOATING; //GPIO_Mode_IPU;
        GPIO_Init(KEY1_INT_GPIO_PORT, &GPIO_InitStruct);
        // 初始化EXTI
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0);
        EXTI_InitStruct.EXTI_Line = KEY1_INT_GPIO_PIN;//EXTI_Line2;
        EXTI_InitStruct.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStruct.EXTI_Trigger = EXTI_Trigger_Rising;
        EXTI_InitStruct.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStruct);
ID:25310 發(fā)表于 2019-11-20 09:41 | 顯示全部樓層
中斷函數(shù):
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_it.h"
void EXTI2_IRQHandler (void)
        if(EXTI_GetITStatus(EXTI_Line2) != RESET)
                LED_G2_TOGGLE2;
        EXTI_ClearITPendingBit(EXTI_Line2);
ID:25310 發(fā)表于 2019-11-20 09:43 | 顯示全部樓層
程序文件架構(gòu)
