查看: 4922|回復: 3
這個錯誤WARNING L16: UNCALLED SEGMENT是為什么,不存在沒使用的函數
ID:643273 發表于 2019-11-16 17:52 | 顯示全部樓層 |閱讀模式
請求援助;
這個是為什么,不存在沒使用的函數
#include<reg52.h>
#include<intrins.h>
#include<stdio.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit adwr=P3^6;
sbit adrd=P3^7;
uchar flag,a;
unsigned char flag_uart,flag_time,flag_on,a,i,t0_num,ad_val;
float ad_vo;
uchar code table[]={0x3f,0x06,0x5b,0x4f,
      0x66,0x6d,0x7d,0x07,
      0x7f,0x6f,0x77,0x7c,
      0x39,0x5e,0x79,0x71};
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void init()
TMOD=0X21;
// SCON=0x50;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TH1=0xfd;
TL1=0xfd;
TR1=1;
ET0=1;
SM0=0;
SM1=1;
REN=1;
EA=1;
ES=1;
void display(uchar value)
uchar bai,shi,ge;
bai=value/100;
shi=value%100/10;
ge=value%10;
dula=1;
P0=table[bai];
dula=0;
P0=0xff;
wela=1;
P0=0x7e;
wela=0;
delayms(5);
dula=1;
P0=table[shi];
dula=0;
P0=0xff;
wela=1;
P0=0x7d;
wela=0;
delayms(5);
dula=1;
P0=table[ge];
dula=0;
P0=0xff;
wela=1;
P0=0x7b;
wela=0;
delayms(5);
uchar get_ad()
uchar adval;
adwr=1;
_nop_();
adwr=0;
_nop_();
adwr=1;
P1=0xff;
adrd=1;
_nop_();
adrd=0;
_nop_();
adval=P1;
adrd=1;
return adval;
init();
wela=1;
P0=0x7f;
wela=0;
while(1);
  if(flag_uart==1)
   flag_uart=0;
   ES=0;
   T1=1;
   switch(flag_on)
    case 0: puts("Turn on ad!\n");
        TR0=1;break;
    case 1: printf("Turn off ad!\n");
           TR0=0;break;
    case 2: puts("Error!\n");
           break;
   while(!TI);
   TI=0;
   ES=1;
  if (flag_time==1)
   flag_time=0;
   ad_val=get_ad();
   ad_vo=(float)ad_val*5.0/256;
   ES=0;
   TI=1;
   printf("The voltage is %f\n",ad_vo);
   while(!TI);
   TI=0;
   ES=1;
  display(ad_val);
void timer0() interrupt 1
t0_num++;
if(t0_num==20)
  t0_num=0;
  flag_time=1;
void ser() interrupt 4
RI=0;
a=SBUF;
flag_uart=1;
if(a==1)
flag_on=0;
else if(a==2)
flag_on=1;
flag_on=2;
然后就出現這個了
:Build target 'Target 1'
compiling AD采集數碼管顯示.c...
AD采集事牘芟允?C(22): warning C290: missing return value
AD采集事牘芟允?C(38): warning C290: missing return value
linking...
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?_DISPLAY?AD采糭數_牘_顯示
    SEGMENT: ?PR?GET_AD?AD采糭數_牘_顯示
    SEGMENT: ?PR?PRINTF?PRINTF
    SEGMENT: ?PR?_PUTS?PUTS
Program Size: data=50.1 xdata=0 code=2952
creating hex file from "計算機與單片機互動"...
"計算機與單片機互動" - 0 Error(s), 6 Warning(s).
ID:25310 發表于 2019-11-17 08:13 | 顯示全部樓層
WARNING L16:  ******    這個不用理會,就是有函數沒調用,嫌麻煩可以設置到不顯示。
ID:155507 發表于 2019-11-17 09:22 | 顯示全部樓層
程序有問題
init();
wela=1;
P0=0x7f;
wela=0;
while(1);  <---- 紅字這里錯了,去掉 ;
  if(flag_uart==1)
ID:643273 發表于 2020-3-19 09:32 | 顯示全部樓層
好的呢,謝謝大佬們
