查看: 1326|回復: 0
有誰能幫忙寫下這個程序的注釋(每一行) 求幫助
ID:638551 發表于 2019-11-15 11:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define KEY_IO P3
#define LCD_IO P0
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
sbit SPK = P1^2;//定義蜂鳴器
sbit LED = P2^4;//定義LED
bit new_s, modify = 0;
char t0, sec = 50, min = 59, hour = 23;
char code LCD_line1[] = "THE CLOCK";
char code LCD_line2[] = "Timer: 00:00:00 ";
char Timer_buf[] = "23:59:50";
void delay(uint z)//延時函數
    uint  x, y;
    for(x = z; x > 0; x--)  for(y = 100; y > 0; y--);
void W_LCD_Com(uchar com)//寫指令
    LCD_RS = 0;
        LCD_IO = com;//RS和RW都為低電平,寫入指令
    LCD_EN = 1;
        delay(5); LCD_EN = 0;
void W_LCD_Dat(uchar dat)
    LCD_RS = 1;  LCD_IO = dat;
    LCD_EN = 1;  delay(5); LCD_EN = 0;
void W_LCD_STR(uchar *s)
    while(*s)  W_LCD_Dat(*s++);
void W_BUFF(void)
    Timer_buf[7] = sec % 10 + 48; Timer_buf[6] = sec / 10 + 48;
    Timer_buf[4] = min % 10 + 48; Timer_buf[3] = min / 10 + 48;
    Timer_buf[1] = hour % 10 + 48;Timer_buf[0] = hour / 10 + 48;
    W_LCD_Com(0xc0 + 7); W_LCD_STR(Timer_buf);
uchar read_key(void)
    uchar  x1, x2;
    KEY_IO = 255;
    x1 = KEY_IO;
    if (x1 != 255) {
      delay(100);
      x2 = KEY_IO;
      if (x1 != x2)  return 255;
      while(x2 != 255) x2 = KEY_IO;
      if      (x1 == 0x7f)  return 0;
      else if (x1 == 0xbf)  return 1;
      else if (x1 == 0xdf)  return 2;
      else if (x1 == 0xef)  return 3;
      else if (x1 == 0xf7)  return 4;
    return 255;
void Init()
    LCD_RW = 0;
    W_LCD_Com(0x38); delay(50);
    W_LCD_Com(0x0c);
    W_LCD_Com(0x06);
    W_LCD_Com(0x01);
    W_LCD_Com(0x80); W_LCD_STR(LCD_line1);
    W_LCD_Com(0xC0); W_LCD_STR(LCD_line2);
    TMOD = 0x01;
    TH0 = 0x4c;
    TR0 = 1;
    PT0 = 1;
    ET0 = 1;
    EA = 1;
    uint i, j;
    uchar Key;
    Init();
    while(1)  {
      if (new_s) {
        new_s = 0;    sec++;  sec %= 60;
        if(!sec)  {   min++;  min %= 60;
          if(!min)  { hour++; hour %= 24;}
        W_BUFF();
        if (!sec && !min) {
          for (i = 0; i < 200; i++) {
            SPK = 0; for (j = 0; j < 100; j++);
            SPK = 1; for (j = 0; j < 100; j++);
      Key = read_key();
      switch(Key) {
      case  0: modify = 1; break;
      case  1: if(modify) {min++;  min %= 60;  W_BUFF(); break;}
      case  2: if(modify) {hour++; hour %= 24; W_BUFF(); break;}
      case  3: modify = 0; break;
void timer0(void) interrupt 1
    TH0 = 0x4c;
    t0++; t0 %= 20;
    if(t0 == 0)  {new_s = 1; LED = ~LED;}
    if(modify)  LED = 0;
