單片機(jī)源程序如下:
- #include "led.h"
- #include "delay.h"
- #include "key.h"
- #include "sys.h"
- #include "lcd.h"
- #include "usart.h"
- #include "hc05.h"
- #include "usart3.h"
- #include "string.h"
- #include "usmart.h"
- #include "beep.h"
- #include "adc.h"
- #include "tsensor.h"
- //顯示ATK-HC05模塊的主從狀態(tài)
- void HC05_Role_Show(void)
- if(HC05_Get_Role()==1)LCD_ShowString(30,140,200,16,16,"ROLE:Master"); //主機(jī)
- else LCD_ShowString(30,140,200,16,16,"ROLE:Slave "); //從機(jī)
- //顯示ATK-HC05模塊的連接狀態(tài)
- void HC05_Sta_Show(void)
- if(HC05_LED)LCD_ShowString(120,140,120,16,16,"STA:Connected "); //連接成功
- else LCD_ShowString(120,140,120,16,16,"STA:Disconnect"); //未連接
- int main(void)
- short temp;
- u8 key;
- u8 sendmask=0;
- //u8 sendcnt=0;
- u8 sendbuf[20];
- u8 reclen=0;
- delay_init(); //延時函數(shù)初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級,2位響應(yīng)優(yōu)先級
- uart_init(115200); //串口初始化為9600
- LED_Init(); //初始化與LED連接的硬件接口
- KEY_Init(); //初始化按鍵
- LCD_Init(); //初始化LCD
- usmart_dev.init(72); //初始化USMART
- BEEP_Init();
- T_Adc_Init(); //ADC初始化
- POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
- LCD_ShowString(30,280,200,16,16,"TEMPERATE: 00.00C");
- LCD_ShowString(30,310,200,16,16,"SMOKE: ");
- delay_ms(1000); //等待藍(lán)牙模塊上電穩(wěn)定
- while(HC05_Init()) //初始化ATK-HC05模塊
- LCD_ShowString(30,90,200,16,16,"ATK-HC05 Error!");
- delay_ms(500);
- LCD_ShowString(30,90,200,16,16,"Please Check!!!");
- delay_ms(100);
- LCD_ShowString(30,110,200,16,16,"ATK-HC05 Standby!");
- LCD_ShowString(30,160,200,16,16,"Send:");
- LCD_ShowString(30,180,200,16,16,"Receive:");
- POINT_COLOR=BLUE;
- HC05_Role_Show();
- delay_ms(100);
- USART3_RX_STA=0;
- while(1)
- HC05_Sta_Show();
- temp=Get_Temprate(); //得到溫度值
- //if(temp>70)
- //{LCD_ShowString(30+10*8,310,16,16,16,"DANGER");
- //LED0=1;
- //BEEP=0;}
- if(temp<0)
- temp=-temp;
- LCD_ShowString(30+10*8,280,200,16,16,"-"); //顯示負(fù)號
- else
- LCD_ShowString(30+10*8,280,16,16,16," "); //無符號
- LCD_ShowxNum(30+11*8,280,temp/100,2,16,0); //顯示整數(shù)部分
- LCD_ShowxNum(30+14*8,280,temp%100,2,16, 0X80); //顯示小數(shù)部分
- LED1=1;
- if(PBin(13))
- {LED0=1;BEEP=0;LCD_ShowString(30+6*8,310,200,16,16," SAFE! ");LED1=0;
- else if(PBin(13)==0||temp>70)
- {LED0=0;
- BEEP=1;
- LCD_ShowString(30+6*8,310,200,16,16,"DANGER!");
- LED1=1;}
- delay_ms(250);
- key=KEY_Scan(0);
- if(key==KEY1_PRES) //切換模塊主從設(shè)置
- key=HC05_Get_Role();
- if(key!=0XFF)
- key=!key; //狀態(tài)取反
- if(key==0)HC05_Set_Cmd("AT+ROLE=0");
- else HC05_Set_Cmd("AT+ROLE=1");
- HC05_Role_Show();
- HC05_Set_Cmd("AT+RESET"); //復(fù)位ATK-HC05模塊
- delay_ms(200);
- else if(BEEP==1)
- sendmask=1; //發(fā)送/停止發(fā)送
- else if
- (BEEP==0)
- {LCD_Fill(30+40,160,240,160+16,WHITE);
- sendmask=0;}//清除顯示
- delay_ms(10);
- if(sendmask) //定時發(fā)送
- sprintf((char*)sendbuf,"Danger\r\n");
- LCD_ShowString(30+40,160,200,16,16,sendbuf); //顯示發(fā)送數(shù)據(jù)
- u3_printf("Danger\r\n"); //發(fā)送到藍(lán)牙模塊
- HC05_Sta_Show();
- delay_ms(10);
- if(USART3_RX_STA&0X8000) //接收到一次數(shù)據(jù)了
- LCD_Fill(30,200,64,64,WHITE); //清除顯示
- reclen=USART3_RX_STA&0X7FFF; //得到數(shù)據(jù)長度
- USART3_RX_BUF[reclen]=0; //加入結(jié)束符
- if(reclen==9||reclen==8) //控制DS1檢測
- if(strcmp((const char*)USART3_RX_BUF,"+LED0 ON")==0)LED0=0; //打開LED1
- if(strcmp((const char*)USART3_RX_BUF,"+LED0 OFF")==0)LED0=1;//關(guān)閉LED1
- if(strcmp((const char*)USART3_RX_BUF,"+BEEP ON")==0) BEEP=1;
- if(strcmp((const char*)USART3_RX_BUF,"+BEEP OFF")==0) BEEP=0;
- LCD_ShowString(30,200,209,16,16,USART3_RX_BUF);//顯示接收到的數(shù)據(jù)
- USART3_RX_STA=0;
1.7z
(254.9 KB, 下載次數(shù): 129)
2019-11-15 01:32 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
