Verilog程序,實(shí)現(xiàn)LED逐漸變亮逐漸變暗功能- /*-----------------------------------------------------------
- filename:Breath_led.v
- Author: Terry
- Data:2019-02-17
- Version:0.1
- Description: ??????
- module Breath_led (
- input wire sys_clk,
- input wire reset,
- output reg [3:0]one_led,
- output reg o_1Mhz );
- parameter END_CNT1=99,
- END_CNT2=999,
- END_CNT3=999;
- reg [6:0] count_1Mhz; //49
- reg [10:0] count_1Khz; //999
- reg [10:0] count_1hz; //999
- reg flag_1khz;
- reg flag_state;
- // 0-49???????
- always @(posedge sys_clk or negedge reset )
- if (reset==0)
- count_1Mhz <= 0;
- else if(count_1Mhz==END_CNT1)
- count_1Mhz <= 0;
- else
- count_1Mhz <= count_1Mhz+1;
- // 1MHZ???????? ?????????????????????
- if (reset==0)
- o_1Mhz <= 0;
- o_1Mhz <= 1;
- else
- o_1Mhz <= 0;
- // ??1MHZ???м??? 1000??
- if (reset==0)
- count_1Khz <= 0;
- else if((o_1Mhz==1)&&(count_1Khz==END_CNT2))
- begin
- count_1Khz <= 0;
- flag_1khz <= 1;
- end
- else if(o_1Mhz==1)
- count_1Khz <= count_1Khz+1;
- else
- begin
- count_1Khz <= count_1Khz;
- flag_1khz <= 0;
- end
- // ??flag_1khz???????м??? 1000??
- if (reset==0)
- begin
- count_1hz <= 0;
- flag_state <=0;
- end
- else if((flag_1khz==1)&&(count_1hz==END_CNT3))
- begin
- count_1hz <= 0;
- flag_state <=~flag_state;
- end
- else if(flag_1khz==1)
- count_1hz <= count_1hz+1;
- else
- begin
- count_1hz <= count_1hz;
- // flag_1khz <= 0; //同一個(gè)寄存器在兩個(gè)always中賦值會(huì)出錯(cuò)
- end
- if (reset==0)
- one_led <= 0;
- else if ((count_1Khz>count_1hz)&&(flag_state==1))
- one_led <=4'b1111 ;
- else if ((count_1Khz>count_1hz)&&(flag_state==0))
- one_led <=4'b0000 ;
- else if ((count_1Khz<=count_1hz)&&(flag_state==1))
- one_led <=4'b0000;
- else if ((count_1Khz<=count_1hz)&&(flag_state==0))
- else
- one_led<=one_led;
- endmodule
復(fù)制代碼 全部資料51hei下載地址:
Breath_led.rar
(3.06 MB, 下載次數(shù): 30)
2019-11-8 14:26 上傳
點(diǎn)擊文件名下載附件
Verilog
評(píng)分
查看全部評(píng)分
