查看: 1975|回復: 1
51單片機交通燈程序加Proteus電路圖
以下為程序:
#include<reg51.h>
sbit RED_A=P0^0;
sbit YELLOW_A=P0^1;
sbit GREEN_A=P0^2;
sbit RED_B=P0^3;
sbit YELLOW_B=P0^4;
sbit GREEN_B=P0^5;
uchar Flash_Count=0,Operation_Type=1;
void DelayMS(uint x)
   uchar i;
   while(x--) for(i=0;i<120;i++);
void Traffic_Light()
   switch(Operation_Type)
     case 1: RED_A=1;YELLOW_A=1;GREEN_A=0;
                 RED_B=0;YELLOW_B=1;GREEN_B=1;
                         DelayMS(2000);
                         Operation_Type=2;
                         break;
         case 2: DelayMS(300);
                 YELLOW_A=~YELLOW_A;GREEN_A=1;
                         if(++Flash_Count!=10) return;
                         Flash_Count=0;
                         Operation_Type=3;
                         break;
         case 3: RED_A=0;YELLOW_A=1;GREEN_A=1;
                 RED_B=1;YELLOW_B=1;GREEN_B=0;
                         DelayMS(2000);
                         Operation_Type=4;
                         break;
         case 4: DelayMS(300);
                 YELLOW_B=~YELLOW_B;GREEN_B=1;
                         Flash_Count=0;
                         Operation_Type=1;
  Traffic_Light();
以下是仿真圖:
ID:653987 發表于 2019-12-3 17:09 | 只看該作者
怎么控制黃燈閃爍的次數
