查看: 1655|回復(fù): 0
四人搶答器源碼
ID:628922 發(fā)表于 2019-11-7 15:45 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
char s;
uchar num=0;
char time=20;         //搶答時(shí)間
char datitime=30;        //答題限時(shí)時(shí)間
uint tt,t1;        //T0,T1定時(shí)器定一秒時(shí)
bit flag,s_flag=1,b_flag,fall_flag;        //標(biāo)志位
bit K_startcountflag,K_timecountflag;        //時(shí)間調(diào)整標(biāo)志位
sbit K0=P3^0;
sbit beep=P3^7;         //蜂鳴器輸出口
sbit rled=P3^1;                //指示燈輸出口
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K_Time=P3^2;        //答題計(jì)時(shí)鍵
sbit K_startcount=P3^3;        //開始搶答時(shí)間調(diào)整鍵
sbit K_timecount=P3^4;        //答題計(jì)時(shí)時(shí)間調(diào)整鍵
void delay(uchar ms)
        uchar y;
        for(;ms>0;ms--)
                for(y=120;y>0;y--);
uchar code tabledu[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71
uchar code tablewe[]={0XFE,0XFD,0XFB,0XF7};
void T0_Init(void)
        TMOD=0X01;
        TH0=(65536-2000)/256;
        TL0=(65536-2000)%256;
        TH1=(65536-2000)/256;
        TL1=(65536-2000)%256;
        ET0=1;
            ET1=1;
        EA=1;
        P0=0;
void Key_Scan(void)                //開始鍵掃描
        if(K0==0)
                delay(10);
                if(K0==0)
                        while(!K0);
                        TR0=1;
                        s=time;
                        tt=0;
                        flag=1;
                        s_flag=1;
                        b_flag=1;
                        num=0;
                        beep=1;
                        rled=1;
                        fall_flag=0;        //清除違規(guī)標(biāo)志位
                        K_startcountflag=0;
                        K_timecountflag=0;
void Scan(void)                //四路熱鍵掃描(哪個(gè)鍵先按下,哪個(gè)優(yōu)先級(jí)最高)
        if(K1==0)
                delay(10);
                if(K1==0)
                        while(!K1);
                        num=1;                //數(shù)碼管顯示1號(hào)"1"
                        TR0=0;                //關(guān)閉定時(shí)器0,時(shí)間停止
            TR1=1;                //打開定時(shí)器1,使揚(yáng)聲器響一聲
                        s_flag=0;        //關(guān)閉開始鍵標(biāo)志位,使再按其他三個(gè)鍵不會(huì)響應(yīng)
        if(K2==0)                        //下面三個(gè)鍵的處理同上
                delay(10);
                if(K2==0)
                        while(!K2);
                        num=2;
                        TR0=0;
                        TR1=1;
                        s_flag=0;        //重要
        if(K3==0)
                delay(10);
                if(K3==0)
                        while(!K3);
                        num=3;
                        TR0=0;
                        TR1=1;
                        s_flag=0;
        if(K4==0)
                delay(10);
                if(K4==0)
                        while(!K4);
                        num=4;
                        TR0=0;
                        TR1=1;
                        s_flag=0;
void display(void)
        if(flag==1)                //開始鍵按下,開始計(jì)時(shí)搶答
                if(num!=0)        //如果有人搶答,則顯示相應(yīng)的幾號(hào)
                        P0=tabledu[num];        //顯示幾號(hào)搶到了
                        P2=tablewe[0];
                        delay(2);
                        P0=0;
                        P2=0XFF;
else                //否則沒人搶答,則前面不顯示幾號(hào)
                        P0=0;
                        P2=0XFF;
                P0=tabledu[s/10];                //下面為顯示搶答倒計(jì)時(shí)
                P2=tablewe[2];
                delay(2);
                P0=0;
                P2=0XFF;
                P0=tabledu[s%10];
                P2=tablewe[3];
                delay(2);
                P2=0XFF;
                P0=0;
void Time_Scan(void)                //調(diào)整時(shí)間鍵掃描
        if(K_startcount==0)                //搶答時(shí)間調(diào)整
                delay(10);
                if(K_startcount==0)
                        while(!K_startcount);
                        time++;
                        if(time==50)
                                time=20;
                        K_startcountflag=1;        //將搶答時(shí)間標(biāo)志位置1
                        K_timecountflag=0;        //同時(shí)關(guān)閉答題時(shí)間標(biāo)志位
        if(K_timecount==0)                //答題時(shí)間調(diào)整
                delay(10);
                if(K_timecount==0)
                        while(!K_timecount);
                        datitime++;
                        if(datitime==60)
                                datitime=30;
                        K_timecountflag=1;
                        K_startcountflag=0;
void main(void)
        T0_Init();
                Key_Scan();                //開始鍵掃描
                if((flag==0)&(s_flag==1))        //當(dāng)開始鍵沒按下及沒有人違規(guī)時(shí)才可進(jìn)行時(shí)間調(diào)整
                        Time_Scan();
                if((flag==1)&(s_flag==0))//當(dāng)開始鍵按下及有人搶答才進(jìn)行開始回答計(jì)時(shí)倒計(jì)時(shí)
                        if(K_Time==0)
                                delay(10);
                                if(K_Time==0)
                                        while(!K_Time);
                                        s=datitime;
                                        TR0=1;
                                        tt=0;
                                        TR1=1;
                if((flag==0)&(s_flag==1))        //違規(guī)
                        Scan();
                        if(num!=0)                //開始鍵沒有按下時(shí),有人按下了搶答器,則置違規(guī)標(biāo)志位
                                fall_flag=1;
                                rled=0;
                if((flag==1)&(s_flag==1))        //如果開始鍵按下且搶答鍵沒有人按下,則進(jìn)行八路搶答鍵掃描
                        Scan();
                display();                //顯示到數(shù)碼管上
void timer0(void) interrupt 1
        TH0=(65536-2000)/256;        //2ms
        if(b_flag)        //開始(START)鍵按下,嘟一聲(長1秒),表示開始搶答
                beep=~beep;
        beep=1;
        if(s<5)        //搶答時(shí)間快到報(bào)警,隔1秒響一聲且紅燈閃爍,響三聲
                if(s%2==0)
                        b_flag=1;
                        rled=0;
                        b_flag=0;
                        rled=1;
        tt++;
        if(tt==500)                //1秒
                tt=0;
                s--;
                b_flag=0;        //關(guān)閉開始鍵按下響一秒的嘟聲
                if(s==-1)
                        s=20;
                        TR0=0;
                        flag=0;        //顯示F FF
                        s_flag=1;
                        num=0;
rled=1;
void timer1(void) interrupt 3        //定時(shí)器1處理有人按下?lián)尨鹌鬣揭宦?長1秒)
beep=~beep;
t1++;
if(t1==500)
t1=0;
TR1=0;
