查看: 4308|回復: 2
PCF8591+單片機波形發生器源碼
程序源碼
附錄 2   程序代碼
#include<reg51.h>
#include<intrins.h>
#include<math.h>
#define  uchar  unsigned  char
#define  uint  unsigned   int
unsigned long Result,i;
sbit SDA=P1^1;    //PCF8591 接口
sbit SCL=P1^0;
unsigned int a=0;            //波形采樣點值
unsigned int b=0;
unsigned  int c=0;
unsigned  int bx_chang=0;
unsigned  int n=40;  //頻率計算值
unsigned char TH;
unsigned char TL;
unsigned int mode=0; //0為調節幅度 1為調節頻率
unsigned int fd=6;         //幅度初值  3.0V
unsigned int  x;         //采樣點的間隔
unsigned int u;                 //lcd刷屏變量
sbit CS =P3^5;                  //LCD接口
sbit SID=P3^6;
sbit SCLK=P3^7;
sbit PSB=P1^5;
sbit p20=P2^0; //波形調節
sbit p21=P2^1; //增加        頻率、幅度
sbit p22=P2^2; //減少        頻率、幅度
sbit p32=P3^2; //頻率幅度選擇
        //sin波形數組
uchar code tosin[256]={
            0x80,0x83,0x86,0x89,0x8D,0x90,0x93,0x96,0x99,0x9C,0x9F,0xA2,0xA5,0xA8,0xAB,0xAE,
                        0xB1,0xB4,0xB7,0xBA,0xBC,0xBF,0xC2,0xC5,0xC7,0xCA,0xCC,0xCF,0xD1,0xD4,0xD6,0xD8,
                        0xDA,0xDD,0xDF,0xE1,0xE3,0xE5,0xE7,0xE9,0xEA,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4,0xF5,
                        0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFD,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                        0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFD,0xFC,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6,
                        0xF5,0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEA,0xE9,0xE7,0xE5,0xE3,0xE1,0xDF,0xDD,0xDA,
                        0xD8,0xD6,0xD4,0xD1,0xCF,0xCC,0xCA,0xC7,0xC5,0xC2,0xBF,0xBC,0xBA,0xB7,0xB4,0xB1,
                        0xAE,0xAB,0xA8,0xA5,0xA2,0x9F,0x9C,0x99,0x96,0x93,0x90,0x8D,0x89,0x86,0x83,0x80,
                        0x80,0x7C,0x79,0x76,0x72,0x6F,0x6C,0x69,0x66,0x63,0x60,0x5D,0x5A,0x57,0x55,0x51,
                        0x4E,0x4C,0x48,0x45,0x43,0x40,0x3D,0x3A,0x38,0x35,0x33,0x30,0x2E,0x2B,0x29,0x27,
                        0x25,0x22,0x20,0x1E,0x1C,0x1A,0x18,0x16,0x15,0x13,0x11,0x10,0x0E,0x0D,0x0B,0x0A,
                        0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
                        0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
                        0x0A,0x0B,0x0D,0x0E,0x10,0x11,0x13,0x15,0x16,0x18,0x1A,0x1C,0x1E,0x20,0x22,0x25,
                        0x27,0x29,0x2B,0x2E,0x30,0x33,0x35,0x38,0x3A,0x3D,0x40,0x43,0x45,0x48,0x4C,0x4E,
                        0x51,0x55,0x57,0x5A,0x5D,0x60,0x63,0x66,0x69,0x6C,0x6F,0x72,0x76,0x79,0x7C,0x80
void delay(unsigned int z)                                //延遲函數
{   unsigned int x,y;
     for(x=z;x>0;x--)
       for(y=125;y>0;y--) ;
//***************************************************LCD顯示函數組
void SendByte(unsigned char Dbyte)                                     //LCD字節傳送
     unsigned char i;
         CS=1;
     for(i=0;i<8;i++)
     {        SCLK = 0;
            if((Dbyte<<i)&0x80)
                SID=1;
                SID=0;
                SCLK = 1;
       SCLK = 0;
         CS=0;
void Lcd_WriteCmd(unsigned char Cbyte )                   //LCD的數據與指令傳送
     delay(10);
     SendByte(0xf8);
     SendByte(0xf0&Cbyte);
     SendByte(0xf0&(Cbyte<<4));
void Lcd_WriteData(unsigned char Dbyte )
     delay(10);
     SendByte(0xfa);
     SendByte(0xf0&Dbyte);
     SendByte(0xf0&(Dbyte<<4));
void InitLCD()                                    //LCD初始化
        Lcd_WriteCmd(0x30);
        Lcd_WriteCmd(0x06);
        Lcd_WriteCmd(0x0c);
        Lcd_WriteCmd(0x04);
        Lcd_WriteCmd(0x01);
        Lcd_WriteCmd(0x02);
        Lcd_WriteCmd(0x80);
void xianshi(unsigned char x,unsigned char y,unsigned char *stri)        //LCD數據傳送地址
        if(x==1)      Lcd_WriteCmd(0x80+y-1);
        else if(x==2) Lcd_WriteCmd(0x90+y-1);
        else if(x==3) Lcd_WriteCmd(0x88+y-1);
        else if(x==4) Lcd_WriteCmd(0x98+y-1);
while(*stri>0)
                Lcd_WriteData(*stri);
                stri++;
void delayp()                         //延遲函數
void delay_1ms(uint z)
    uint x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--)
//****************************************I2C協議
void start()//開始信號
    SDA=1;
    delayp();
    SCL=1;
    delayp();
    SDA=0;
    delayp();
void stop() //停止信號
    SDA=0;
    delayp();
    SCL=1;
    delayp();
    SDA=1;
    delayp();
void respons()//應答    相當于一個智能的延時函數
    uchar i;
    SCL=1;
    delayp();
    while((SDA==1)&&(i<250))
        i++;
    SCL=0;
    delayp();
void init() //初始化
    SDA=1;
    delayp();
    SCL=1;
    delayp();
void write_byte(uchar date) //寫一字節數據
    uchar i,temp;
    temp=date;
    for(i=0;i<8;i++)
        temp=temp<<1; //左移一位 移出的一位在CY中
        SCL=0;          //只有在scl=0sda能變化值
        delayp();
        SDA=CY;
        delayp();
        SCL=1;
        delayp();
    SCL=0;
    delayp();
    SDA=1;
    delayp();
void write_add(uchar date)            //D/A轉換
    start();
    write_byte(0x90);
    respons();
    write_byte(0x40);
    respons();
    write_byte(date);
    respons();
    stop();
int main()//************************************************主函數
    TMOD = 0x01;
        TH0 = (65536-99000/n)/256;             //定時時間
        TL0 = (65536-99000/n)%256;
        TH1 = (65536-5000)/256;
        TL1 = (65536-5000)%256;
        EA = 1;
        ET0 = 1;
        ET1 = 1;
        TR0 = 1;
        TR1 = 1;
    init();
                PSB=0;
                InitLCD();
//*******************************************顯示模塊
for(u=0;u<9;u++)
        xianshi(1,1,"信號發生器");
                xianshi(2,1,"波形:");
        if(bx_chang==0)                xianshi(2,4,"sin");
        if(bx_chang==1)                       xianshi(2,4,"Square");
        if(bx_chang==2)                       xianshi(2,4,"Triangle");
        if(mode==0)
                xianshi(3,1,"幅度:");
                       Lcd_WriteData(0x30+(fd*5/10));
                xianshi(3,5,".");
                      Lcd_WriteData(0x30+(fd*5%10));
                xianshi(3,6,"V");
              if(mode==1)
                xianshi(3,1,"頻率:");
                        Lcd_WriteData(0x30+(n/2/100));
                            Lcd_WriteData(0x30+(n/2/10));
                            Lcd_WriteData(0x30+(n/2%10));
                        xianshi(3,8,"HZ");
//**************************************************************8
void refresh_f( void ) interrupt 1           //定時器中斷
  if(n>=0&&n<40)
{        x=14;
        TH0 = (65536-92900/n)/256;
        TL0 = (65536-92900/n)%256;
  else if (n>=40&&n<80)
{        x=15;
        TH0 = (65536-97920/n)/256;
        TL0 = (65536-97920/n)%256;
//*************************************正弦波形
     a=a+x;
               if(a<256&&bx_chang==0)
              write_add(tosin[a]*0.1*fd);
                if(a>=256)
                          a=0;
//************************************方波波形
        b=b+x;
                  if(b<128&&bx_chang==1)
              write_add(0x00*0.1*fd);
        if(b>=128&&b<256&&bx_chang==1)
                   write_add(0xff*0.1*fd);
        if(b>=256)
           b=0;
//*************************************三角波波形
         c=c+x;
                  if(c<128&&bx_chang==2)
                write_add(c*0.2*fd);
         if(c>=128&&c<256&&bx_chang==2)
         write_add((-c+256)*0.2*fd);
        if(c>=256)
           c=0;
//********************************************定時器中斷   按鍵中斷
void refresh_zd( void ) interrupt 3
        TH1 = (65536-5000)/256;                   //5000us
//*******************************************8
        if(p32==0)                  //頻率或者幅度調節選擇
                     delay_1ms(1000);
                         if(p32==0)
                         mode=mode+1;
                         if(mode>=2)
                         mode=0;
         if(p20==0)                  //波形選擇
                   delay_1ms(1000);
                   bx_chang=bx_chang+1;
                   if(bx_chang>=3)
                   bx_chang=0;
//*******************************************頻率調節
                 if(p21==0&&mode==1)
                   delay_1ms(1000);
                   n=n+2;
                   if(n>=120)
                   n=1;
                 if(p22==0&&mode==1)
                   delay_1ms(1000);
                   n=n-2;
                   if(n<=0)
                   n=120;
//*******************************************幅度調節
                 if(p21==0&&mode==0)
                   delay_1ms(1000);
                   fd=fd+1;
                   if(fd>=10)
                   fd=1;
                 if(p22==0&&mode==0)
                   delay_1ms(1000);
                   fd=fd-1;
                   if(fd<=1)
                   fd=10;
波形發生器.doc
245.21 KB, 下載次數: 30, 下載積分: 黑幣 -5
附錄 2 程序代碼.doc
19.23 KB, 下載次數: 26, 下載積分: 黑幣 -5
ID:253767 發表于 2019-11-7 08:03 | 只看該作者
謝謝分享!!!
ID:662861 發表于 2019-12-12 22:43 | 只看該作者
我怎么沒有顯示波形呢大佬
