查看: 3957|回復: 7
單片機程序錯誤就是看不懂哪里錯了,提示syntax error語法錯誤
ID:627982 發表于 2019-11-2 18:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
總是提示這個括號有錯誤,如果我只有三個加法按鍵程序就沒有問題,但是我加了減法按鍵就提示錯誤。希望大佬看一下找一下錯誤。這個程序是按鍵加法減法數碼管顯示。
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
sbit KEY_IN_1  = P2^4;
sbit KEY_IN_2  = P2^5;
sbit KEY_IN_3  = P2^6;
sbit KEY_IN_4  = P2^7;
sbit KEY_OUT_1 = P2^3;
sbit KEY_OUT_2 = P2^2;
sbit KEY_OUT_3 = P2^1;
sbit KEY_OUT_4 = P2^0;
unsigned char code LedChar[] = {
    0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
    0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[6] = {
    0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
unsigned char code KeyCodeMap[4][4] = {
    { 0x31, 0x32, 0x33, 0x26 },
    { 0x34, 0x35, 0x36, 0x25 },
    { 0x37, 0x38, 0x39, 0x28 },
    { 0x30, 0x1B, 0x0D, 0x27 }
unsigned char KeySta[4][4] = {
    {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1}
void KeyDriver();
    EA = 1;
    ENLED = 0;
    ADDR3 = 1;
    TMOD = 0x01;
    TH0  = 0xFC;
    TL0  = 0x67;
    ET0  = 1;
    TR0  = 1;
    LedBuff[3] = LedChar[0];
            LedBuff[0] = LedChar[0];
    while (1)
        KeyDriver();
void KeyAction(unsigned char keycode)
           static unsigned char A = 0;
           static unsigned char B = 0;
           static unsigned char C = 0;
           static unsigned char D = 0;
           static unsigned char E = 0;
           static unsigned char F = 0;
           static unsigned char G = 0;
           static unsigned char H = 0;
           static unsigned char M = 0;
           static unsigned char K = 0;
           if((keycode==0x31)|(keycode==0x32)|(keycode==0x33)|(keycode==0x26))
                       if(keycode==0x31)
                                          A=A+1;
                                                       if(keycode==0x32)
                                          B=B+2;
                                                       if(keycode==0x33)
                                          C=C+3;
                                 if(keycode==0x26)
                                          D=D-1;
                                E=A+B+C;
                                LedBuff[0] = LedChar[G%10];
                                LedBuff[1] = LedChar[G/10%10];
                                LedBuff[2] = LedChar[G/100%10];
                     else if((keycode==0x34)|(keycode==0x35)|(keycode==0x36)|(keycode==0x25)
                       if(keycode==0x34)
                                          F=F+1;
                                if(keycode==0x35)
                                          G=G+2;
                                if(keycode==0x36)
                                          H=H+3;
                                if(keycode==0x25)
                                M=F+G+H;
                                LedBuff[3] = LedChar[H%10];
                                LedBuff[4] = LedChar[H/10%10];
                                LedBuff[5] = LedChar[H/100%10];//êy??1ü??ê?????
                     if(keycode==0x1b)
                                A=0;B=0;C=0;D=0;E=0;F=0;G=0;H=0;K=0;M=0;
                                LedBuff[1] = LedChar[0];
                                LedBuff[2] = LedChar[0];
                                LedBuff[4] = LedChar[0];
                                LedBuff[5] = LedChar[0];
                     }//??á?′|àí
void KeyDriver()
    unsigned char i, j;
    static unsigned char backup[4][4] = {
    for (i=0; i<4; i++)
        for (j=0; j<4; j++)
            if (backup[ i][j] != KeySta[ i][j])
            {                if (backup[ i][j] != 0)
                    KeyAction(KeyCodeMap[ i][j]);
                backup[ i][j] = KeySta[ i][j];
void KeyScan()
    unsigned char i;
    static unsigned char keyout = 0;
    static unsigned char keybuf[4][4] = {
        {0xFF, 0xFF, 0xFF, 0xFF},  {0xFF, 0xFF, 0xFF, 0xFF},
    keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
    keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
    keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
    keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
    for (i=0; i<4; i++)
        if ((keybuf[keyout][ i] & 0x0F) == 0x00)
        {   //á?D?4′?é¨?è?μ?a0£??′4*4ms?ú??ê?°′??×′ì?ê±£??éè??a°′?üò??è?¨μ?°′??
            KeySta[keyout][ i] = 0;
        else if ((keybuf[keyout][ i] & 0x0F) == 0x0F)
            KeySta[keyout][ i] = 1;
    keyout++;
    keyout = keyout & 0x03;
    switch (keyout)
        case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
        case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
        case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
        case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
        default: break;
void LedScan()
    static unsigned char i = 0;
    P0 = 0xFF;
    switch (i)
        case 0: ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break;
        case 1: ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break;
        case 2: ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]; break;
        case 3: ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break;
        case 4: ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]; break;
        case 5: ADDR2=1; ADDR1=0; ADDR0=1; i=0; P0=LedBuff[5]; break;
        default: break;
void InterruptTimer0() interrupt 1
    TH0 = 0xFC;
    TL0 = 0x67;
    LedScan();
    KeyScan();
ID:627982 發表于 2019-11-2 18:33 | 只看該作者
錯誤在else if(keycode==0x34)|(keycode==0x35)下的那個中括號,提示syntax error語法錯誤
ID:88256 發表于 2019-11-2 20:01 | 只看該作者
if括號需要配對,你的這句最后面就沒有反括號
ID:632603 發表于 2019-11-2 20:41 | 只看該作者
for (i=0; i<4; i++)
        for (j=0; j<4; j++)
} 其中的感嘆號!!用了中文感嘆號
ID:511890 發表于 2019-11-3 01:08 | 只看該作者
else if((keycode==0x34)|(keycode==0x35)|(keycode==0x36)|(keycode==0x25)這里少了個“)”,一般這種錯誤只要點擊錯誤提示就會跳到這里(有的編譯器會有誤差,但是差不多就是在出錯的語句前后),然后纖細檢查下語法就能發現錯誤。好的編譯器可能還會提升少了一個“)”。不過是英文的。
ID:437615 發表于 2019-11-3 08:01 來自觸屏版 | 只看該作者
地板說的對,你這個程序少了個括號
ID:627982 發表于 2019-11-3 16:19 | 只看該作者
hhdsdy 發表于 2019-11-2 20:01
else if((keycode==0x34)|(keycode==0x35)|(keycode==0x36)| ...
感謝,就是這里
ID:627982 發表于 2019-11-3 16:21 | 只看該作者
幻劍心 發表于 2019-11-3 01:08
else if((keycode==0x34)|(keycode==0x35)|(keycode==0x36)|(keycode==0x25)這里少了個“)”,一般這種錯 ...
謝謝,就是這里
