查看: 3546|回復: 2
stm32 用dac輸出正弦波
ID:459169 發表于 2019-11-2 15:07 | 顯示全部樓層 |閱讀模式
  前段時間師兄拜托寫一個單片機代碼,由于之前沒整過,在這記錄一下。也希望可以幫助到正在學這個的朋友們.stm32F4并不支持自動生成正弦波,事先在正弦波上找500個點存在一個數組里,然后當每一個時鐘到來的時候,dac就會輸出電壓值。
   void sin_Generation(void)   {u16 n;for(n=0;n<tableSize;n++)   {sinTable[n] = (sin(2*PI*n/tableSize)+1)*2047;}
經過線性轉換后,數字輸入會轉換為 0 到 VREF+ 之間的輸出電壓。各 DAC 通道引腳的模擬輸出電壓通過以下公式確定:
DACoutput =Vref*dor/4095
接下來就是定時器和GPIO的配置,以及為了避免占用CPU的dma操作
    void TIM6_Configuration(void)
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
         TIM_PrescalerConfig(TIM6, 83, TIM_PSCReloadMode_Update);
          TIM_SetAutoreload(TIM6, 70)
          TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
        TIM_Cmd(TIM6, ENABLE)
定時器的arr值和psc值得·設置可以改變輸出波形的頻率,這里的頻率為50hz
void GPIO_Configuration(void)
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
void DAC_DMA_Configuration(void)
        DAC_InitTypeDef  DAC_InitStructure;
        DMA_InitTypeDef DMA_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
        DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;
        DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
        DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;
        DAC_Init(DAC_Channel_1, &DAC_InitStructure);
        DMA_DeInit(DMA1_Stream5);
        DMA_InitStructure.DMA_Channel = DMA_Channel_7;
        DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12R1_ADDRESS;
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&sinTable;
        DMA_InitStructure.DMA_BufferSize = tableSize;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
        DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
        DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
        DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
        DMA_Init(DMA1_Stream5, &DMA_InitStructure);
        DMA_Cmd(DMA1_Stream5, ENABLE);
        DAC_Cmd(DAC_Channel_1, ENABLE);
        DAC_DMACmd(DAC_Channel_1, ENABLE);
ID:634277 發表于 2019-11-2 21:05 | 顯示全部樓層
謝謝樓主!!!
ID:260044 發表于 2020-7-7 17:05 | 顯示全部樓層
時隔許久依舊謝謝大佬
