查看: 2093|回復: 0
我用的是并口通訊測試語音模塊的ASR 但是一直不對
回帖獎勵 50 黑幣 回復本帖可獲得 50 黑幣獎勵! 每人限 1 次
ID:381002 發表于 2019-11-1 22:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
   #include"reg511.h"
#include "intrins.h"
#define uint8 unsigned char
#define uint16 unsigned int
#define uint32 unsigned long
sbit        LD_WR         = P3^6;
sbit        LD_RD        = P3^7;
sbit        LD_A0        = P1^1;
sbit    RSTB=P1^2;
sbit    CSB=P1^0;
sbit out_1=P2^0;
sbit out_2=P2^1;
sbit out_3=P2^2;
sbit out_4=P2^3;
sbit out_5=P2^4;
sbit out_6=P2^5;
sbit out_7=P2^6;
sbit out_8=P2^7;
#define chu_yu        1
#define ke_shou        2
#define you_du        3
#define qi_ta        4
#define guan        0
#define MIC_VOL 0x43
#define CLK_IN                        33.1776        /* user need modify this value according to clock in */
#define LD_PLL_11                        (uint8)((CLK_IN/2.0)-1)
#define LD_PLL_ASR_19                 (uint8)(CLK_IN*32.0/(LD_PLL_11+1) - 0.51)
#define LD_PLL_ASR_1B                 0x48
#define LD_PLL_ASR_1D                 0x1f
#define LD_ASR_NONE                                14
#define LD_ASR_RUNING                        15
#define LD_ASR_FOUNDOK                    17
#define LD_ASR_FOUNDZERO                 12
#define LD_ASR_ERROR                        11
#define LD_MODE_ASR_RUN                0x08
#define LD_MODE_IDLE                0x00
uint8  idata nLD_Mode = LD_MODE_IDLE;                //        用來記錄當前是在進行ASR識別還是在播放MP3
uint8  idata nAsrStatus=0;
uint8  gu=0;
void  delay(unsigned long uldata)
        unsigned int j  =  0;
        unsigned int g  =  0;
        for (j=0;j<5;j++)
                for (g=0;g<uldata;g++)
                        _nop_();
                        _nop_();
                        _nop_();
void LD_WriteReg( unsigned char address, unsigned char dataout )
        P0 = address;
        LD_A0 = 1;
        CSB = 0;
        LD_WR = 0;
_nop_();_nop_();_nop_();
        LD_WR = 1;
        CSB = 1;
        P0 = dataout;
        LD_A0 = 0;
        CSB = 0;
        LD_WR = 0;
        LD_WR = 1;
        CSB = 1;
unsigned char LD_ReadReg( unsigned char address )
        unsigned char datain;
        P0 = address;
        LD_A0 = 1;
        CSB = 0;
        LD_WR = 0;
        LD_WR = 1;
        CSB = 1;
        LD_A0 = 0;
        CSB = 0;
        LD_RD = 0;
        datain = P0;
        LD_RD = 1;
        CSB = 1;
        return datain;
void LD_reset()
        RSTB=1;
        delay(1);
        RSTB=0;
        delay(1);
        RSTB=1;
        delay(1);
        CSB=0;
        delay(1);
        CSB=1;
        delay(1);
void LD_Init_Common(void)
        LD_ReadReg(0x06);
        LD_WriteReg(0x17, 0x35);
         delay(10);
        LD_ReadReg(0x06);
        LD_WriteReg(0x89, 0x03);
        delay(5);
        LD_WriteReg(0xCF, 0x43);
        delay(5);
        LD_WriteReg(0xCB, 0x02);
        /*PLL setting*/
        LD_WriteReg(0x11, LD_PLL_11);
        LD_WriteReg(0x1E,0x00);
  //!!注意,下面三個寄存器,會隨晶振頻率變化而設置不同
    //!!注意,請根據使用的晶振頻率修改參考程序中的
        LD_WriteReg(0x19, LD_PLL_ASR_19);
        LD_WriteReg(0x1B, LD_PLL_ASR_1B);
        LD_WriteReg(0x1D, LD_PLL_ASR_1D);
        delay(10);
        LD_WriteReg(0xCD, 0x04);
        LD_WriteReg(0x17, 0x4c);
        delay(5);
        LD_WriteReg(0xB9, 0x00);
        LD_WriteReg(0xCF, 0x4F);
        LD_WriteReg(0x6F, 0xFF);
void LD_Init_ASR(void)
                   nLD_Mode=LD_MODE_ASR_RUN;
                LD_Init_Common();
                LD_WriteReg(0xBD,0x00);
                LD_WriteReg(0x17,0x48);
                delay( 10 );
                LD_WriteReg(0x3C,0x80);
                LD_WriteReg(0x3E,0x07);
                LD_WriteReg(0x38,0xff);
                LD_WriteReg(0x3A,0x07);
                LD_WriteReg(0x40,0x00);
                LD_WriteReg(0x42,0x08);
                LD_WriteReg(0x44,0x00);
                LD_WriteReg(0x46,0x08);
                delay( 1 );
        uint8 LD_Check_ASRBusyFlag_b2(void)
        uint8 j;
        uint8 flag = 0;
        for (j=0; j<10; j++)
                if (LD_ReadReg(0xb2) == 0x21)
                        flag = 1;
                        break;
                delay(10);
        return flag;
uint8 LD_AsrAddFixed(void)
        uint8 k, flag;
        uint8 nAsrAddLength;
        const char sRecog[5][13] = {"chu yu", "ke shou",
        "you du", "qi ta", "guan"};
        const uint8 pCode[5] = {chu_yu, ke_shou, you_du, guan};
        flag = 1;
        for (k=0; k<5; k++)
                if(LD_Check_ASRBusyFlag_b2() == 0)
                        flag = 0;
                        break;
                LD_WriteReg(0xc1, pCode[k] );
                LD_WriteReg(0xc3, 0 );
                LD_WriteReg(0x08, 0x04);
                delay(1);
                LD_WriteReg(0x08, 0x00);
                delay(1);
                for (nAsrAddLength=0; nAsrAddLength<20;
                nAsrAddLength++)
                        if (sRecog[k][nAsrAddLength] == 0)
                        break;
                        LD_WriteReg(0x5, sRecog[k][nAsrAddLength]);
                LD_WriteReg(0xb9, nAsrAddLength);
                LD_WriteReg(0xb2, 0xff);
                LD_WriteReg(0x37, 0x04);
        return flag;
uint8 LD_AsrRun(void)
        LD_WriteReg(0x35,MIC_VOL);
        LD_WriteReg(0x1C,0x09);
        LD_WriteReg(0xBD,0x20);
        LD_WriteReg(0x08,0x01);
        delay( 1 );
        LD_WriteReg(0x08,0x00);
        delay( 1 );
        return 0;
        LD_WriteReg(0xB2, 0xff);
        LD_WriteReg(0x37,0x06);
        delay(5);
        LD_WriteReg(0x1C,0x0b);
        LD_WriteReg(0x29,0x10);
        EX0=1;
        return 1;
uint8 RunASR(void)
        uint8 i=0;
        uint8 asrflag=0;
        for (i=0; i<5; i++)
                LD_Init_ASR();
                delay(100);
                if (LD_AsrAddFixed()==0)
                        LD_reset();
                        delay(100);
                        continue;
                delay(10);
                if (LD_AsrRun() == 0)
                        LD_reset();
                        delay(100);
                        continue;
                asrflag=1;
                break;
        return asrflag;
uint8 LD_GetResult()
        return LD_ReadReg(0xc5 );
void mucinit()
        P2M1=0X00;
        P2M0=0XFF;
        P3M1=0XFA;
        P3M0=0XFF;
          IT0=1;
        EX0=1;
        EA=1;
void ProcessInt0()
        uint8 nAsrResCount=0;
        uint8 ucRegVal;
        EX0=0;
        ucRegVal = LD_ReadReg(0x2B);
        if(nLD_Mode == LD_MODE_ASR_RUN)
                // 語音識別產生的中斷
                // (有聲音輸入,不論識別成功或失敗都有中斷)
                LD_WriteReg(0x29,0) ;
                LD_WriteReg(0x02,0) ;
                if((ucRegVal & 0x10) &&
                        LD_ReadReg(0xb2)==0x21 &&
                        LD_ReadReg(0xbf)==0x35)
                        nAsrResCount = LD_ReadReg(0xba);
                        if(nAsrResCount>0 && nAsrResCount<=4)
                                nAsrStatus=LD_ASR_FOUNDOK;
                                nAsrStatus=LD_ASR_FOUNDZERO;
                LD_WriteReg(0x2b, 0);
            LD_WriteReg(0x1C,0);
                 ET0=1;
                return;
void ExtInt0Handler() interrupt 0
  ProcessInt0();
        uint8 nAsrRes;
    mucinit();
        LD_reset();
        nAsrStatus = LD_ASR_NONE;                //        初始狀態:沒有在作ASR
                switch(nAsrStatus)
                        case LD_ASR_RUNING:
                        case LD_ASR_ERROR:
                                break;
                        case LD_ASR_NONE:
                                nAsrStatus=LD_ASR_RUNING;
                                if (RunASR()==0)        //        啟動一次ASR識別流程:ASR初始化,ASR添加關鍵詞語,啟動ASR運算
                                        nAsrStatus = LD_ASR_ERROR;
                                break;
                        case LD_ASR_FOUNDOK:
                                nAsrRes = LD_GetResult();        //        一次ASR識別流程結束,去取ASR識別結果
                                if(nAsrRes==1)
                                           out_1=1;
                                           out_2=0;
                                           gu=1;
                                if(nAsrRes==2)
                                           out_3=1;
                                           out_4=0;
                                           gu=2;
                                if(nAsrRes==3)
                                           out_5=1;
                                           out_6=0;
                                           gu=3;
                                if(nAsrRes==4)
                                           out_7=1;
                                           out_8=0;
                                           gu=4;
                                if(nAsrRes==0)
                                        if(gu==1)
                                          out_1=0;
                                          out_2=1;
                                         if(gu==2)
                                          out_3=0;
                                          out_4=1;
                                         if(gu==3)
                                          out_5=0;
                                          out_6=1;
                                          if(gu==4)
                                          out_7=0;
                                          out_8=1;
                                break;
                        case LD_ASR_FOUNDZERO:
                             break;
                        default:
                                break;
                }// switch
        }// while
