查看: 3033|回復: 10
arduino+moc33021+bta16為什么啥只有半波控制,求大佬解疑
ID:633947 發表于 2019-11-1 17:54 | 顯示全部樓層 |閱讀模式
void up()
  digitalWrite(12, HIGH);
  delayMicroseconds(5000);
  digitalWrite(12, LOW);
  delayMicroseconds(1000);
void setup() {
  pinMode(2, INPUT);
  pinMode(12, OUTPUT);
  // put your setup code here, to run once:
  attachInterrupt(0, up, RISING);
void loop() {
  // put your main code here, to run repeatedly:
  delay(100);
這個是arduino代碼,檢測到過零后延時5ms控制moc3021開通。
不知道為什么只有在220v的負半波能開通可控硅,正的半波一點反應都沒有,可控硅觸發電路是參考的moc3021手冊推薦電路,是不是proteus仿真元件有問題?moc3021?bta16-600bw?
Arduino 328.rar
92.11 KB, 下載次數: 12
proteus項目文件
ID:633947 發表于 2019-11-4 09:37 | 顯示全部樓層
沒有人嗎?
ID:342822 發表于 2019-11-4 10:31 | 顯示全部樓層
這是Proteus 8 中的例程看一看吧
/* Main.ino file generated by New Project wizard
* Created:   mer ago 22 2018
* Processor: Arduino Uno
* Compiler:  Arduino AVR
int AC_LOAD = 3;    // Output to Opto Triac pin
int dimming = 128;  // Dimming level (0-128)  0 = ON, 128 = OFF
void setup()
  pinMode(AC_LOAD, OUTPUT);// Set AC Load pin as output
  attachInterrupt(0, zero_crosss_int, RISING);  // Choose the zero cross interrupt # from the table above
//the interrupt function must take no parameters and return nothing
void zero_crosss_int()  //function to be fired at the zero crossing to dim the light
  // Firing angle calculation : 1 full 50Hz wave =1/50=20ms
  // Every zerocrossing thus: (50Hz)-> 10ms (1/2 Cycle)
  // For 60Hz => 8.33ms (10.000/120)
  // 10ms=10000us
  // (10000us - 10us) / 128 = 75 (Approx) For 60Hz =>65
  int dimtime = (75*dimming);    // For 60Hz =>65
  delayMicroseconds(dimtime);    // Wait till firing the TRIAC
  digitalWrite(AC_LOAD, HIGH);   // Fire the TRIAC
  delayMicroseconds(10);         // triac On propogation delay (for 60Hz use 8.33)
  digitalWrite(AC_LOAD, LOW);    // No longer trigger the TRIAC (the next zero crossing will swith it off) TRIAC
void loop()  {
  for (int i=5; i <= 128; i++){
    dimming=i;
    delay(10);
ID:342822 發表于 2019-11-4 10:51 | 顯示全部樓層
檢測到過零后延時5ms控制moc3021開通????
用10ms試一試~~
ID:633947 發表于 2019-11-4 14:33 | 顯示全部樓層
taotie 發表于 2019-11-4 10:31
這個例子名稱叫什么,我想看看完整項目
ID:633947 發表于 2019-11-4 14:44 | 顯示全部樓層
可以看到單片機觸發信號應該是沒問題的,但是只有負半波可控硅開通了
ID:342822 發表于 2019-11-4 16:24 | 顯示全部樓層
jzli2019 發表于 2019-11-4 14:33
這個例子名稱叫什么,我想看看完整項目
Arduino Dimming 230V AC
ID:342822 發表于 2019-11-4 17:12 | 顯示全部樓層
按你的程序仿真沒得問題。。
ID:633947 發表于 2019-11-4 18:02 | 顯示全部樓層
taotie 發表于 2019-11-4 17:12
按你的程序仿真沒得問題。。
大佬,我把proteus8.7卸載了重新裝了proteus8.9,現在模擬也沒問題了。。。很莫名其妙啊
ID:633947 發表于 2019-11-4 18:03 | 顯示全部樓層
按你的程序仿真沒得問題。。
你用的是哪個版本,我感覺就是版本不對導致的。。。
ID:342822 發表于 2019-11-5 13:01 | 顯示全部樓層
jzli2019 發表于 2019-11-4 18:03
呵呵8.8
