#include <AT89X51.H> unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71,0x00}; unsigned char second; unsigned char keycnt; unsigned int tcnt; void main(void) { unsigned char i,j; TMOD=0x02; ET0=1; EA=1; second=0; P0=dispcode[second/10]; P2=dispcode[second%10]; while(1) { if(P3_5==0) { for(i=20;i>0;i--) for(j=248;j>0;j--); if(P3_5==0) { keycnt++; switch(keycnt) { case 1: TH0=0x06; TL0=0x06; TR0=1; break; case 2: TR0=0; break; case 3: keycnt=0; second=0; P0=dispcode[second/10]; P2=dispcode[second%10]; break; } while(P3_5==0); } } } } void t0(void) interrupt 1 using 0 { tcnt++; if(tcnt==400) { tcnt=0; second++; if(second==100) { second=0; } P0=dispcode[second/10]; P2=dispcode[second%10]; } }
