只需一步,快速開(kāi)始
查看: 2811|回復(fù): 0
EMWIN燈控實(shí)驗(yàn)源程序
ID:517846 發(fā)表于 2019-10-27 20:47 | 顯示全部樓層 |閱讀模式
簡(jiǎn)單燈控實(shí)驗(yàn)
單片機(jī)源程序如下:
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "key.h"
  4. #include "sys.h"
  5. #include "ILI93xx.h"
  6. #include "usart.h"
  7. #include "24cxx.h"
  8. #include "flash.h"
  9. #include "touch.h"
  10. #include "timer.h"
  11. #include "malloc.h"
  12. #include "GUI.h"
  13. #include "ff.h"
  14. #include "MMC_SD.h"
  15. #include "fontupd.h"
  16. #include "exfuns.h"
  17. #include "includes.h"
  18. #include "Button_USE.h"
  19. #include "WM.h"
  20. #include "DIALOG.h"
  21. //任務(wù)優(yōu)先級(jí)
  22. #define START_TASK_PRIO                                3
  23. //任務(wù)堆棧大小
  24. #define START_STK_SIZE                                 128
  25. //任務(wù)控制塊
  26. OS_TCB StartTaskTCB;
  27. //任務(wù)堆棧
  28. CPU_STK START_TASK_STK[START_STK_SIZE];
  29. //任務(wù)函數(shù)
  30. void start_task(void *p_arg);
  31. //TOUCH任務(wù)
  32. //設(shè)置任務(wù)優(yōu)先級(jí)
  33. #define TOUCH_TASK_PRIO                                4
  34. //任務(wù)堆棧大小
  35. #define TOUCH_STK_SIZE                                128
  36. //任務(wù)控制塊
  37. OS_TCB TouchTaskTCB;
  38. //任務(wù)堆棧
  39. CPU_STK TOUCH_TASK_STK[TOUCH_STK_SIZE];
  40. //touch任務(wù)
  41. void touch_task(void *p_arg);
  42. //LED0任務(wù)
  43. //設(shè)置任務(wù)優(yōu)先級(jí)
  44. #define LED0_TASK_PRIO                                 5
  45. //任務(wù)堆棧大小
  46. #define LED0_STK_SIZE                                128
  47. //任務(wù)控制塊
  48. OS_TCB Led0TaskTCB;
  49. //任務(wù)堆棧
  50. CPU_STK LED0_TASK_STK[LED0_STK_SIZE];
  51. //led0任務(wù)
  52. void led0_task(void *p_arg);
  53. //EMWINDEMO任務(wù)
  54. //設(shè)置任務(wù)優(yōu)先級(jí)
  55. #define EMWINDEMO_TASK_PRIO                        6
  56. //任務(wù)堆棧大小
  57. #define EMWINDEMO_STK_SIZE                        512
  58. //任務(wù)控制塊
  59. OS_TCB EmwindemoTaskTCB;
  60. //任務(wù)堆棧
  61. CPU_STK EMWINDEMO_TASK_STK[EMWINDEMO_STK_SIZE];
  62. //emwindemo_task任務(wù)
  63. void emwindemo_task(void *p_arg);
  64. int main(void)
  65. {
  66.         OS_ERR err;
  67.         CPU_SR_ALLOC();
  68.
  69.         delay_init();                    //延時(shí)函數(shù)初始化
  70.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);         //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
  71.         uart_init(115200);                 //串口初始化為115200
  72.         LED_Init();                            //LED端口初始化
  73.         TFTLCD_Init();                        //LCD初始化
  74.         KEY_Init();                                 //按鍵初始化
  75.         mem_init();                                //初始化內(nèi)部?jī)?nèi)存池
  76.         TP_Init();                                //觸摸屏初始化
  77.
  78.         OSInit(&err);                        //初始化UCOSIII
  79.         OS_CRITICAL_ENTER();        //進(jìn)入臨界區(qū)
  80.         //創(chuàng)建開(kāi)始任務(wù)
  81.         OSTaskCreate((OS_TCB         * )&StartTaskTCB,                //任務(wù)控制塊
  82.                                  (CPU_CHAR        * )"start task",                 //任務(wù)名字
  83.                  (OS_TASK_PTR )start_task,                         //任務(wù)函數(shù)
  84.                  (void                * )0,                                        //傳遞給任務(wù)函數(shù)的參數(shù)
  85.                  (OS_PRIO          )START_TASK_PRIO,     //任務(wù)優(yōu)先級(jí)
  86.                  (CPU_STK   * )&START_TASK_STK[0],        //任務(wù)堆棧基地址
  87.                  (CPU_STK_SIZE)START_STK_SIZE/10,        //任務(wù)堆棧深度限位
  88.                  (CPU_STK_SIZE)START_STK_SIZE,                //任務(wù)堆棧大小
  89.                  (OS_MSG_QTY  )0,                                        //任務(wù)內(nèi)部消息隊(duì)列能夠接收的最大消息數(shù)目,為0時(shí)禁止接收消息
  90.                  (OS_TICK          )0,                                        //當(dāng)使能時(shí)間片輪轉(zhuǎn)時(shí)的時(shí)間片長(zhǎng)度,為0時(shí)為默認(rèn)長(zhǎng)度,
  91.                  (void           * )0,                                        //用戶補(bǔ)充的存儲(chǔ)區(qū)
  92.                  (OS_OPT      )OS_OPT_TASK_STK_CHK|OS_OPT_TASK_STK_CLR, //任務(wù)選項(xiàng)
  93.                  (OS_ERR         * )&err);                                //存放該函數(shù)錯(cuò)誤時(shí)的返回值
  94.         OS_CRITICAL_EXIT();        //退出臨界區(qū)
  95.         OSStart(&err);  //開(kāi)啟UCOSIII
  96.         while(1);
  97. }
  98. //開(kāi)始任務(wù)函數(shù)
  99. void start_task(void *p_arg)
  100. {
  101.         OS_ERR err;
  102.         CPU_SR_ALLOC();
  103.         p_arg = p_arg;
  104.         CPU_Init();
  105. #if OS_CFG_STAT_TASK_EN > 0u
  106.    OSStatTaskCPUUsageInit(&err);          //統(tǒng)計(jì)任務(wù)
  107. #endif
  108.
  109. #ifdef CPU_CFG_INT_DIS_MEAS_EN                //如果使能了測(cè)量中斷關(guān)閉時(shí)間
  110.     CPU_IntDisMeasMaxCurReset();
  111. #endif
  112. #if        OS_CFG_SCHED_ROUND_ROBIN_EN  //當(dāng)使用時(shí)間片輪轉(zhuǎn)的時(shí)候
  113.          //使能時(shí)間片輪轉(zhuǎn)調(diào)度功能,時(shí)間片長(zhǎng)度為1個(gè)系統(tǒng)時(shí)鐘節(jié)拍,既1*5=5ms
  114.         OSSchedRoundRobinCfg(DEF_ENABLED,1,&err);
  115. #endif
  116.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_CRC,ENABLE);//開(kāi)啟CRC時(shí)鐘
  117.         GUI_Init();                          //STemWin初始化
  118.
  119.         OS_CRITICAL_ENTER();        //進(jìn)入臨界區(qū)
  120.         //STemWin Demo任務(wù)
  121.         OSTaskCreate((OS_TCB*     )&EmwindemoTaskTCB,
  122.                                  (CPU_CHAR*   )"Emwindemo task",
  123.                  (OS_TASK_PTR )emwindemo_task,
  124.                  (void*       )0,
  125.                  (OS_PRIO          )EMWINDEMO_TASK_PRIO,
  126.                  (CPU_STK*    )&EMWINDEMO_TASK_STK[0],
  127.                  (CPU_STK_SIZE)EMWINDEMO_STK_SIZE/10,
  128.                  (CPU_STK_SIZE)EMWINDEMO_STK_SIZE,
  129.                  (OS_MSG_QTY  )0,
  130.                  (OS_TICK          )0,
  131.                  (void*       )0,
  132.                  (OS_OPT      )OS_OPT_TASK_STK_CHK|OS_OPT_TASK_STK_CLR,
  133.                  (OS_ERR*     )&err);
  134.         //觸摸屏任務(wù)
  135.         OSTaskCreate((OS_TCB*     )&TouchTaskTCB,
  136.                                  (CPU_CHAR*   )"Touch task",
  137.                  (OS_TASK_PTR )touch_task,
  138.                  (void*       )0,
  139.                  (OS_PRIO          )TOUCH_TASK_PRIO,
  140.                  (CPU_STK*    )&TOUCH_TASK_STK[0],
  141.                  (CPU_STK_SIZE)TOUCH_STK_SIZE/10,
  142.                  (CPU_STK_SIZE)TOUCH_STK_SIZE,
  143.                  (OS_MSG_QTY  )0,
  144.                  (OS_TICK          )0,
  145.                  (void*       )0,
  146.                  (OS_OPT      )OS_OPT_TASK_STK_CHK|OS_OPT_TASK_STK_CLR,
  147.                  (OS_ERR*     )&err);
  148.         //LED0任務(wù)
  149.         OSTaskCreate((OS_TCB*     )&Led0TaskTCB,
  150.                                  (CPU_CHAR*   )"Led0 task",
  151.                  (OS_TASK_PTR )led0_task,
  152.                  (void*       )0,
  153.                  (OS_PRIO          )LED0_TASK_PRIO,
  154.                  (CPU_STK*    )&LED0_TASK_STK[0],
  155.                  (CPU_STK_SIZE)LED0_STK_SIZE/10,
  156.                  (CPU_STK_SIZE)LED0_STK_SIZE,
  157.                  (OS_MSG_QTY  )0,
  158.                  (OS_TICK          )0,
  159.                  (void*       )0,
  160.                  (OS_OPT      )OS_OPT_TASK_STK_CHK|OS_OPT_TASK_STK_CLR,
  161.                  (OS_ERR*     )&err);
  162.         OS_TaskSuspend((OS_TCB*)&StartTaskTCB,&err);                //掛起開(kāi)始任務(wù)
  163.         OS_CRITICAL_EXIT();        //退出臨界區(qū)
  164. }
  165. //EMWINDEMO任務(wù)
  166. void emwindemo_task(void *pdata)
  167. {
  168.         GUI_CURSOR_Show();
  169.         //更換皮膚
  170.         BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
  171.         CHECKBOX_SetDefaultSkin(CHECKBOX_SKIN_FLEX);
  172.         DROPDOWN_SetDefaultSkin(DROPDOWN_SKIN_FLEX);
  173.         FRAMEWIN_SetDefaultSkin(FRAMEWIN_SKIN_FLEX);
  174.         HEADER_SetDefaultSkin(HEADER_SKIN_FLEX);
  175.         MENU_SetDefaultSkin(MENU_SKIN_FLEX);
  176.         MULTIPAGE_SetDefaultSkin(MULTIPAGE_SKIN_FLEX);
  177.         PROGBAR_SetDefaultSkin(PROGBAR_SKIN_FLEX);
  178.         RADIO_SetDefaultSkin(RADIO_SKIN_FLEX);
  179.         SCROLLBAR_SetDefaultSkin(SCROLLBAR_SKIN_FLEX);
  180.         SLIDER_SetDefaultSkin(SLIDER_SKIN_FLEX);
  181.         SPINBOX_SetDefaultSkin(SPINBOX_SKIN_FLEX);
  182.         while(1)
  183.         {
  184.                 Main_task();
  185.         }
  186. }
  187. //TOUCH任務(wù)
  188. void touch_task(void *p_arg)
  189. {
  190.         OS_ERR err;
  191.         while(1)
  192.         {
  193.                 GUI_TOUCH_Exec();
  194.                 OSTimeDlyHMSM(0,0,0,5,OS_OPT_TIME_PERIODIC,&err);//延時(shí)5ms
  195.         }
  196. }
  197. //LED0任務(wù)
  198. void led0_task(void *p_arg)
  199. {
  200.         OS_ERR err;
  201.         while(1)
  202.         {
  203.                 LED0 = !LED0;
  204.                 OSTimeDlyHMSM(0,0,0,500,OS_OPT_TIME_PERIODIC,&err);//延時(shí)500ms
  205.         }
  206. }
EMWIN燈控實(shí)驗(yàn).7z (1.71 MB, 下載次數(shù): 21)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
