查看: 4439|回復: 3
Arduino+LM35+卡爾曼濾波+i2C_lcd
ID:330820 發表于 2019-10-22 17:48 | 顯示全部樓層 |閱讀模式
Arduino+LM35+kalman+i2C_lcd, 加入卡爾曼濾波顯示溫度比較度穩定,
可顯示小數後三位。
  1. /*
  2. This sample code demonstrates how to use the SimpleKalmanFilter object.
  3. Use a potentiometer in Analog input A0 as a source for the reference real value.
  4. Some random noise will be generated over this value and used as a measured value.
  5. The estimated value obtained from SimpleKalmanFilter should match the real
  6. reference value.
  7. SimpleKalmanFilter(e_mea, e_est, q);
  8. e_mea: Measurement Uncertainty
  9. e_est: Estimation Uncertainty
  10. q: Process Noise
  11. https://github.com/denyssene/SimpleKalmanFilter
  12. */
  13. #include <SimpleKalmanFilter.h>
  14. SimpleKalmanFilter simpleKalmanFilter(1, 1, 0.1);
  15. #include <LiquidCrystal_I2C.h>
  16. LiquidCrystal_I2C lcd(0x3f,16,2); //(0x20,16,2)
  17. const long SERIAL_REFRESH_TIME = 100;
  18. long refresh_time;
  19. float tempC;
  20. int tempPin = A0;
  21. void setup(){
  22. Serial.begin(9600);
  23. lcd.begin();
  24. lcd.print("Temp =");
  25. lcd.setCursor(0, 1);
  26. lcd.print("TempKa=");
  27. }
  28. void loop(){
  29. if (millis() > refresh_time) { // 每100ms發送到串行輸出
  30. tempC=0;
  31. tempC = analogRead(tempPin); //從傳感器讀取值
  32. tempC += analogRead(tempPin);
  33. tempC += analogRead(tempPin);
  34. tempC += analogRead(tempPin);
  35. tempC =tempC/4;
  36. tempC = (5.0 * tempC * 100.0)/1024.0; //將模擬數據轉換為溫度
  37. // 用卡爾曼濾波器計算估計值
  38. float kal_tempC = simpleKalmanFilter.updateEstimate(tempC);
  39. Serial.print(tempC); // 使用串行繪圖儀進行良好的可視化
  40. Serial.print(",");
  41. Serial.println(kal_tempC);
  42. //將結果到lcd顯示
  43. lcd.setCursor(7, 0);
  44. lcd.print(tempC,3);
  45. lcd.print(" C");
  46. lcd.setCursor(7, 1);
  47. lcd.print(kal_tempC,3);
  48. lcd.print(" C");
  49. refresh_time = millis() + SERIAL_REFRESH_TIME;
  50. }
  51. }
卡爾曼濾波顯示溫度比較
卡爾曼濾波顯示溫度比較
ID:328014 發表于 2019-10-22 18:04 | 顯示全部樓層
好東東 能分享下源程序嗎?
ID:234938 發表于 2019-11-26 19:14 | 顯示全部樓層
感謝樓主分享!有個問題,樓主能否幫著解決一下?程序上傳到Mega2560上運行正常,溫度顯示正常22度左右;上傳到MICRO上,溫度卻顯示為483度,請問樓主,這是什么原因?接線都反復檢查了,對著呢。謝謝!
ID:687881 發表于 2020-6-17 15:40 | 顯示全部樓層
試了一下卡爾曼濾波來測溫度,果然 不錯。
