查看: 2925|回復: 2
STM32 lcd子菜單的實現程序
ID:500655 發表于 2019-10-21 10:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
實現了一個stm32 上LCD屏幕的菜單選擇
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "lcd.h"
  5. #include "led.h"
  6. #include "key.h"
  7. #include "malloc.h"
  8. #include "sdio_sdcard.h"
  9. #include "w25qxx.h"
  10. #include "ff.h"
  11. #include "exfuns.h"
  12. #include "text.h"
  13. #include "pyinput.h"
  14. #include "touch.h"
  15. #include "string.h"
  16. #include "usmart.h"
  17. u16 kbdxsize;        //虛擬鍵盤按鍵寬度
  18. u16 kbdysize;//虛擬鍵盤按鍵高度
  19. u8  aaa;//一級菜單翻轉位
  20. vu8 key=0;
  21. u16 i;
  22. //數字表
  23. const u8* kbd_tbl[9]={"LED1","LED2","LED3","LED4","LED5","LED6","set","fun","close"};
  24. //字符表
  25. const u8* kbs_tbl[9]={"燈1","燈2","燈3","燈4","燈5","燈6","設置","功能","關閉"};
  26. void first_meau_1(void)
  27. {
  28.         POINT_COLOR=RED;
  29.         Show_Str(30,5,200,16,"led燈管控制",16,0);
  30.         Show_Str(30,20,200,16,"all點亮所有",16,0);
  31.         Show_Str(30,35,200,16,"fun進入功能",16,0);
  32.         Show_Str(30,50,200,16,"close關閉當前",16,0);
  33.         Show_Str(30,65,200,16,"circle1:校準  KEY0:切換",16,0);
  34.         Show_Str(30,90,200,16,"輸入:",16,0);
  35.         Show_Str(30,110,200,32,"結果:",16,0);
  36. }
  37. void first_meau_2(void)
  38. {
  39.   POINT_COLOR=RED;
  40.         Show_Str(30,5,200,16,"led control",16,0);
  41.         Show_Str(30,20,200,16,"all lights on",16,0);
  42.         Show_Str(30,35,200,16,"function",16,0);
  43.         Show_Str(30,50,200,16,"close now",16,0);
  44.         Show_Str(30,65,200,16,"circle1:adjust  KEY0:change",16,0);
  45.         Show_Str(30,90,200,16,"in:",16,0);
  46.         Show_Str(30,110,200,32,"out:",16,0);
  47. }
  48. void Init_all(void)
  49. {
  50.         delay_init();                     //延時函數初始化
  51.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置中斷優先級分組為組2:2位搶占優先級,2位響應優先級
  52.         uart_init(115200);                 //串口初始化為115200
  53.         usmart_dev.init(72);                //初始化USMART
  54.         KEY_Init();                                        //初始化按鍵
  55.         LCD_Init();                                           //初始化LCD
  56.         W25QXX_Init();                                //初始化W25Q128
  57.         tp_dev.init();                                //初始化觸摸屏
  58.         my_mem_init(SRAMIN);                //初始化內部內存池
  59.         exfuns_init();                                //為fatfs相關變量申請內存
  60.         f_mount(fs[0],"0:",1);                 //掛載SD卡
  61.         f_mount(fs[1],"1:",1);                 //掛載FLASH.
  62.         POINT_COLOR=RED;
  63.         while(font_init())                         //檢查字庫
  64.         {
  65.                 LCD_ShowString(30,50,200,16,16,"Font Error!");
  66.                 delay_ms(200);
  67.                 LCD_Fill(30,50,240,66,WHITE);//清除顯示
  68.         }
  69. }
  70. void secondMeau(void)
  71. {
  72.
  73.
  74. }
  75. //加載鍵盤界面
  76. //x,y:界面起始坐標
  77. void py_load_ui(u16 x,u16 y,u8 flag)
  78. {
  79.
  80.         POINT_COLOR=BLACK;
  81.         LCD_DrawRectangle(x,y,x+kbdxsize*3,y+kbdysize*3);
  82.         LCD_DrawRectangle(x+kbdxsize,y,x+kbdxsize*2,y+kbdysize*3);
  83.         LCD_DrawRectangle(x,y+kbdysize,x+kbdxsize*3,y+kbdysize*2);
  84.         POINT_COLOR=BLUE;
  85.         if(flag)
  86. {
  87.                   first_meau_2();
  88.             for(i=0;i<9;i++)
  89.              {
  90.                        Show_Str_Mid(x+(i%3)*kbdxsize,y+4+kbdysize*(i/3),(u8*)kbd_tbl[i],16,kbdxsize);        //Chinese
  91.              }
  92.
  93. }
  94.   else
  95. {
  96.                   first_meau_1();
  97.                         for(i=0;i<9;i++)
  98.              {
  99.                  Show_Str_Mid(x+(i%3)*kbdxsize,y+kbdysize/2+kbdysize*(i/3),(u8*)kbs_tbl[i],16,kbdxsize);          //English
  100.              }
  101. }
  102. }
  103.
  104. //按鍵狀態設置
  105. //x,y:鍵盤坐標
  106. //key:鍵值(0~8)
  107. //sta:狀態,0,松開;1,按下;
  108. void py_key_staset(u16 x,u16 y,u8 keyx,u8 sta)
  109. {
  110.         u16 i=keyx/3,j=keyx%3;
  111.         if(keyx>8)
  112.                 return;
  113.         if(sta)
  114.                 LCD_Fill(x+j*kbdxsize+1,y+i*kbdysize+1,x+j*kbdxsize+kbdxsize-1,y+i*kbdysize+kbdysize-1,GREEN);
  115.         else
  116.           LCD_Fill(x+j*kbdxsize+1,y+i*kbdysize+1,x+j*kbdxsize+kbdxsize-1,y+i*kbdysize+kbdysize-1,WHITE);
  117.
  118. }
  119. //得到觸摸屏的輸入
  120. //x,y:鍵盤坐標
  121. //返回值:按鍵鍵值(1~9有效;0,無效)
  122. u8 py_get_keynum(u16 x,u16 y)
  123. {
  124.         u16 i,j;
  125.         static u8 key_x=0;//0,沒有任何按鍵按下;1~9,1~9號按鍵按下
  126.         u8 key=0;
  127.         tp_dev.scan(0);
  128.         if(tp_dev.sta&TP_PRES_DOWN)                        //觸摸屏被按下
  129.         {
  130.                 for(i=0;i<3;i++)
  131.                 {
  132.                         for(j=0;j<3;j++)
  133.                         {
  134.                                  if(tp_dev.x[0]<(x+j*kbdxsize+kbdxsize)&&tp_dev.x[0]>(x+j*kbdxsize)&&tp_dev.y[0]<(y+i*kbdysize+kbdysize)&&tp_dev.y[0]>(y+i*kbdysize))
  135.                                 {
  136.                                         key=i*3+j+1;
  137.                                         break;
  138.                                 }
  139.                         }
  140.
  141.                         if(key)
  142.                         {
  143.                                 if(key_x==key)key=0;
  144.                                 else
  145.                                 {
  146.                                         py_key_staset(x,y,key_x-1,0);
  147.                                         key_x=key;
  148.                                         py_key_staset(x,y,key_x-1,1);
  149.                                 }
  150.                                 break;
  151.                         }
  152.                 }
  153.         }
  154.
  155.         else if(key_x)
  156.         {
  157.                 py_key_staset(x,y,key_x-1,0);
  158.                 key_x=0;
  159.         }
  160.         return key; //得到key值
  161. }
  162.
  163. int main(void)
  164. {
  165.         u8 i=0;
  166.         u8 circle1,circle2,circle3;//按鍵標志位
  167.         u8 inputstr[100];                //最大輸入100個字符+結束符
  168.         u8 inputlen;                //輸入長度
  169.   u8  ok=0;
  170.         Init_all();
  171.         if(lcddev.id==0X5310){kbdxsize=86;kbdysize=43;}//根據LCD分辨率設置按鍵大小
  172.         else if(lcddev.id==0X5510||lcddev.id==0X1963){kbdxsize=140;kbdysize=70;}
  173.         else {kbdxsize=60;kbdysize=40;}
  174.
  175.         memset(inputstr,0,7);        //全部清零
  176.         inputlen=0;                                //輸入長度為0
  177.
  178.                         while(1)
  179.                 {
  180.
  181.                         circle1=KEY_Scan(0);
  182.                         circle2 = circle1;
  183.                         while(circle2==KEY0_PRES)
  184.                          {
  185.
  186.                                  circle2=KEY_Scan(0);
  187.
  188.                          }
  189.                         if(circle1==KEY0_PRES)
  190.                         {
  191.                                  ok =~ok;
  192.                                  LCD_Clear(WHITE);
  193.                          }
  194.
  195.                                 i++;
  196.                                 delay_ms(10);
  197.
  198.                         if(aaa==1)
  199.                         {
  200.                                 secondMeau();
  201.                                 circle3=KEY_Scan(0);
  202.                                 if(circle3==KEY1_PRES)
  203.                                  {
  204.                                          aaa=0;
  205.                                  }
  206.                         }
  207.
  208.
  209.                         else
  210.                         {
  211.                                  py_load_ui(30,195,ok);
  212.                                  key=py_get_keynum(30,195);
  213.                                                          if(key)
  214.                                          {
  215.                                                          if(key==9)//刪除
  216.                                                  {
  217.        Show_Str(30,130,200,16,"關閉當前",16,0);
  218.        delay_ms(1000);
  219.        LCD_Fill(30,130,30+100,140+16,WHITE);
  220.        if(inputlen)
  221.        {
  222.        inputstr[inputlen-1]=' ';//添加結束符
  223.        inputlen--;
  224.        }
  225.
  226.                                                         }
  227.                                                         else
  228.                                                 {
  229.        if(key==8)
  230.        {
  231.        Show_Str(30,130,200,16,"進入下一功能",16,0);
  232.        delay_ms(1000);
  233.        LCD_Fill(30,130,30+100,140+16,WHITE);
  234.        LCD_Fill(30+40,90,30+40+48,110+16,WHITE);        //清除之前的顯示
  235.        delay_ms(1000);
  236.        LCD_Fill(0,0,2000,2000,WHITE);
  237.        Show_Str(30+40,90,200,16," ",16,0);
  238.        aaa=1;
  239.        }
  240.
  241.        if(key==7)
  242.        {
  243.        Show_Str(30,130,200,16,"設置地址",16,0);
  244.        delay_ms(1000);
  245.        Show_Str(30+40,90,200,16," ",16,0);
  246.
  247.        }
  248.
  249.                                                 inputstr[inputlen]=key+'0';//輸入字符
  250.                                                 if(inputlen<100)
  251.                                                 inputlen++;
  252.
  253.
  254.                                         }
  255.
  256.
  257.
  258.                                         LCD_Fill(30+40,90,30+40+48,110+16,WHITE);        //清除之前的顯示
  259.                                         if(key!=8&&key!=7)
  260.                                         {
  261.                                                  Show_Str(30+40,90,200,16,inputstr,16,0);        //顯示有效的數字串
  262.                                          }
  263.
  264.                                 }
  265. }
  266.      }
  267.         }
LCD顯示.7z (1.39 MB, 下載次數: 41)
ID:618759 發表于 2019-11-24 19:28 | 只看該作者
解決燃眉之急
ID:265664 發表于 2020-4-11 19:37 | 只看該作者
正好需要,,多謝
