查看: 1457|回復: 0
iTOP-IMX6Q開發板設備樹-RFID驅動-修改手冊
ID:245207 發表于 2019-10-15 10:43 | 顯示全部樓層 |閱讀模式
本文檔基于迅為iTOP-IMX6開發板
1.內核
拷貝rc522驅動到iTOP-iMX6_android6.0.1/kernel_imx/drivers/spi目錄下。
打開iTOP-iMX6_android6.0.1/kernel_imx/drivers/spi/Makefile
添加:
obj-$(CONFIG_SPI_RC522)       += rc522.o
iTOP-iMX6_android6.0.1/kernel_imx/drivers/spi/Kconfig
在文件末尾添加:
config SPI_RC522
        tristate "RC522 Module driver support"
        help
          This supports RC522 Module drivers.
2.修改設備樹文件
iTOP-iMX6_android6.0.1/kernel_imx/arch/arm/boot/dts/imx6qdl-sabresd.dtsi
(1)添加:
&ecspi2 {
        fsl,spi-num-chipselects = <1>;
        cs-gpios = <&gpio2 27 0>;
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_ecspi2>;
        status = "okay";
        rfid: rc522@0 {
                #address-cells = <1>;
                #size-cells = <1>;
                compatible = "rc522";
                spi-max-frequency = <10000000>;
                reg = <0>;
pinctrl_ecspi2: ecspi2grp {
                        fsl,pins = <
                                MX6QDL_PAD_EIM_OE__ECSPI2_MISO          0x100b1
                                MX6QDL_PAD_EIM_CS1__ECSPI2_MOSI         0x100b1
                                MX6QDL_PAD_EIM_CS0__ECSPI2_SCLK         0x100b1
                                MX6QDL_PAD_EIM_LBA__GPIO2_IO27          0x1b0b0
(2)注釋語句
MX6QDL_PAD_EIM_CS1__GPIO2_IO24 0x80000000
